Old 02-09-2015, 05:39 PM   #71
mkivalex
Drives: 13 Scion FRS, 93 JDM Toyota Supra
I doubt it will be less than 12k with the actual drivrtrain
mkivalex is offline
Old 02-09-2015, 07:14 PM   #72
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by cf6mech View Post
Having difficulties with the production headers......they are now sending them back for the fourth time and having problems with the turnaround times with the manufacture......Vorshlag is very anal about not only getting them right,.. but perfect. They could easily take a ball peen hammer and dent them in one last interference area but they refuse to work that way or expect customers too,.... last sticking point is the steering column shaft touching on drivers side header, passenger side was good first try...pulleys and all accessories are routed and cooling system is done......wiring for the GM engine ECU I do believe starts this week. the proposed start up date is first week of March......its been a long wait If this wasn't going to be a Kit that could be purchased from Vorshlag I would of been driving it early last fall...... (taking one for the team)....they already had perfectly designed and engineered headers fitted from scratch ( long tubes ) in August. They got sent out to make a production run to copy.....that's were the headache lies and is also why my costs are down, allowing to do the development work for the kit, custom long tube headers run about 5k from vorshlag I've been told. For me and kit buyers it will be substantially less than half that with a production run instead of a one off design. The headers alone on similar LS conversions are worth another 50Hp.
Bless you for your sacrifice!
Lonewolf is offline
Old 02-09-2015, 09:33 PM   #73
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If weapons grade can sell the total swap kit for $9k and make huge profit, Vorshlag will probably price under them to get more buyers. Swapping out the engine and trans and selling, could net you maybe $4k. All of which would be put forward to the swap.
cdrazic93 is offline
Old 02-09-2015, 09:38 PM   #74
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I wouldn't trust them with my toaster after seeing this thread.
http://www.ft86club.com/forums/showthread.php?t=80300
Andrew025 is offline
Old 02-10-2015, 02:11 AM   #75
M23
Drives: 86
Weapons Grade Performance.... Busted!
M23 is offline
Old 02-10-2015, 07:54 AM   #76
robr
Drives: 2013 FRS, with boost by ATS Racing
You aren't very familiar with Vorshlag, are you? They are the definition of the moment when the pursuit of perfection gets in the way of everything else. And their prices reflect that. And they don't care about, nor make any claims to, being lower priced than any other company.
robr is offline
Old 02-10-2015, 10:43 AM   #77
mkivalex
I dont expect it to be cheap, but I hope its reasonable because I WILL be doing this to the FRS in the future.
mkivalex is offline
Old 02-10-2015, 11:43 AM   #78
NOHOME
Drives: RAVEN
I kinda followed as WGP did the LS2 swap showing very little detail and no results. An informed comsumer would have more questions than asnwers when it come to their product and its final result.
By comparison the Vorslag stuff is artwork on display. I am going to guess that a Vorslag swap is going to net out at net out around 20k by the time you are all finished.
I am also waiting/expecting V8 Roadsters to jump into the fray. While they may still be on the fence waiting to see if the twins sell a critical mass of cars that would make it worthwhile, ( figure 1 out of 10,000 owners do a swap after year 5?)they do have a great track record of making Miata V8 conversions for the masses. They also sell a kit to put the LFX V6 in a Miata so that should be a doodle into the wide bay of the Twins.
NOHOME is offline
Old 02-10-2015, 06:22 PM   #79
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Weapons Grade Performance is a hack shop and they do sh!t work. Go talk to the guys at Vorshlag about what they think about the WGP kit. It's comical.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline
Old 02-10-2015, 06:30 PM   #80
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I completely agree, they do half assed work. I was only comparing prices. not companies.
Old 02-10-2015, 07:15 PM   #81
M23
Drives: 86
You can kinda get a price estimate prediction from Vorshlag's currently available BMW swap kits and parts.
Vorshlag all the way if I was doing a swap.
M23 is offline
Old 02-12-2015, 09:16 AM   #82
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
^ I was just about to post that.
The Level 0 kit for an E36 is $3900. That's for the mounts, headers, transmission xmember, driveshaft, steering shaft, and bolts for those items. That does not include wiring, their accessory drive kit, CANBUS programming, any coolant/ac lines, or any other hard parts.
I can see all the parts being ~$8k, not including the motor or transmission. For what you're get, that still strikes me as an awesome deal.
Parting out HERE
civicdrivr is offline
Old 02-12-2015, 09:55 AM   #83
nelsmar
I would easily consider 8k for all the swap components. In reality compared to my turbo setup and build cost it really isn't all that different. And the transmission is going to withstand more power than with my setup...
My flickr - Canibeat
Local magazine scout
nelsmar is offline
Old 02-12-2015, 01:42 PM   #84
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Absolutely. You can build a solid LS for less then a used FA20. The swap parts are pricey, but once you get it in there, you have a much better platform to build upon.
This will most likely be the avenue I pursue when my motor blows (again).
Parting out HERE
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
