Old 08-12-2014, 03:41 AM   #71
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by Turdinator View Post
I wish we had vendors here in Australia
Fixed.
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
CSG David (08-12-2014), Turdinator (08-12-2014)
Old 08-25-2014, 03:47 AM   #72
Maverickgear
Drives: World Rally Blue BRZ
Was on a cheap set of coilovers and I must say I was not satisfied with the handling dynamics. It clearly made the handling worse than stock even with much alignment tuning.
So now I have decided to go the Swift/RCE Yellows + Bilstein route due to my budget. I'd just like to urge everyone who is deciding to get cheap coilovers in hope to improve handling, don't. Just don't.
Maverickgear is offline   Reply With Quote
The Following 3 Users Say Thank You to Maverickgear For This Useful Post:
Firestorm_86 (08-25-2014), Racecomp Engineering (08-25-2014), wparsons (09-03-2014)
Old 08-25-2014, 12:43 PM   #73
Calum
That Guy
Drives: 2013 asphalt FRS MT
How does the damping of the RCE T0's compare to the Bilstein or Koni damping?
Old 08-25-2014, 06:40 PM   #74
Griever423
Drives: 2020 BRZ PP
Originally Posted by Firestorm_86 View Post
~$1650
1. Swift Sport or Spec-R springs. ~$300
2. Camber bolts ~$35
3. Bilstein B8 struts ~$910
4. LCA's ~$375
5. Be done with my budget affordable one step at a time setup.
Listen to this man. More suspension that most will ever need.
Griever423 is offline   Reply With Quote
The Following User Says Thank You to Griever423 For This Useful Post:
Old 08-25-2014, 07:04 PM   #75
CSG David
CSG David's Avatar
@Firestorm_86 went this route:
http://www.ft86club.com/forums/showthread.php?t=72836
The Following 2 Users Say Thank You to CSG David For This Useful Post:
Firestorm_86 (08-25-2014), themajesticone (08-25-2014)
Old 08-25-2014, 09:30 PM   #76
Firestorm_86
Drives: FRS
Originally Posted by CSG David View Post
My writeup is above.
Firestorm_86 is offline   Reply With Quote
Old 09-02-2014, 01:53 PM   #77
ajc209
Drives: GT86 Cosworth
I am at a cross roads between the RCE Tarmac 0 coilovers or the Bilstein B8/RCE tarmac springs.......
ajc209 is offline   Reply With Quote
Old 09-02-2014, 03:07 PM   #78
2 very different feeling dampers.
The Bilsteins have a lot of low speed bump and run a lot of gas pressure.
The T zeros have less low speed but are still responsive and yet more high speed damping. Autocrossers tend to prefer the Bilsteins for this reason.
I will try to find the Bilstein development dyno plots to do a comparison.
Both are very capable and either way would be a big improvement over stock.
Myles
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
ajc209 (09-03-2014), Turkish (09-03-2014)
Old 09-02-2014, 04:06 PM   #79
^ also an advantage to the T0 is you'll have more bump travel (unless you run them super low).
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
ajc209 (09-03-2014)
Old 09-03-2014, 02:03 PM   #80
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
What about HSD Coilovers? I have them and for a DD it feels very comfortable.
Marcoscrdo is offline   Reply With Quote
Old 11-14-2014, 07:01 AM   #81
Jetbill
Drives: 2013 FRS, 2014 BMW 335 M-Sport
Myles
Please post the dyno plot for the Tarmac Zero.
Jetbill is offline   Reply With Quote
The ISC Suspension-NA N1 Coilover System for the BRZ/FRS ISC Suspension Brakes, Suspension, Chassis 17 04-29-2014 10:56 AM
Can shock-dynos tell you what the highest spring rate it can handle? fooddude Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 02-16-2014 05:43 PM
coilover shock body height adj garfull Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 05-19-2013 04:32 AM
