#57 |
It's hard for me to explain and I think part of it is me being a shock nerd...but quality shocks matched well to the spring rate is one of the biggest things for me on the street. It's just something you feel over every bump, every time you enter a corner, and every time you power out. No matter how fast you're going. You don't have to be pushing the car hard trying to pass a 911 on the inside in a traffic circle to feel a difference. It's what your passengers feel too when you're taking them out to lunch. If you have to apologize because their head hit the ceiling...well then I'd feel embarrassed.
Which isn't to say the stock spring and shock package are "bad"...they're not. But if I'm going to improve things, that's what I want to improve on a car that I drive daily. RCE Yellows (and a few other springs) feel pretty good on the stock shocks. It's an improvement. Konis or Bilsteins bump things up a pretty noticeable notch. And a quality coilover system can be several notches better. Alignment is still HUGE. It needs to be right for your application and a crappy alignment means crappy handling. No way around that. It must be set well and you need some negative camber to handle well. For some that means bolts up front are good enough. If you are tracking the car often and definitely if you're competing in auto-x, then you will want all the camber that plates can give you. - Andy |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | CSG Mike (08-11-2014) |
#58 |
When I first got my car I did the cheapo route: Brz swift springs, camber bolts, and spc lca. Bouncy ride, but nothing too harsh. I spent about 500ish, I think.
Then I moved to some middle ground: hvt plates, st coils, and isc lca. Got em all for a little over $1500. Ride quality is meh, but my real advantage is the camber adjustment when I need it. If you're really on a budget, you could look into the wrx camber plates for around $100, camber bolts, and the newer version (at least newer to my old one) spc lca. Koni shocks are usually on sale, and just invest the rest in wheels and tires. Sent from my LG-P769 using Tapatalk
There is no great genius without a mixture of madness - Aristotle
#59 |
#60 | |
Drives: '13 UM86
1) Swift Spec-R Springs be? 2) Swift Spec-R Springs + HVT camber plates be? 3) Swift Spec-R Springs + HVT camber plates + SPL LCAs be? Would I be bouncing around with option 1 if i were to start off with that? |
| The Following User Says Thank You to themajesticone For This Useful Post: | Firestorm_86 (08-11-2014) |
#61 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | themajesticone (08-11-2014) |
#62 | |
Drives: FRS
http://counterspacegarage.com/produc...0-brz-frs.html but with RCE springs. |
#63 |
Drives: '13 UM86
My buddy has the Eibach sportlines and he is at 1.4" with the same rear spring rate. He drives that car everywhere so I think I should be fine then. I don't want strict comfort, but I don't want something that would make me grind my teeth haha.
| The Following User Says Thank You to themajesticone For This Useful Post: | CSG Mike (08-11-2014) |
#64 |
Drives: '13 UM86
Is there a thread that shows and explains what the maximum spring rates are that the stock shocks can capably support?
#65 |
| The Following 3 Users Say Thank You to CSG David For This Useful Post: |
#66 |
Drives: '13 UM86
#67 |
It's good to be skeptical and to ask questions, but it's also important to develop a sense of quality vs. performance vs. time vs. budget. Developing this sense will help you make a much more informed decision. Keep in mind stock suspension may seems lame, but it is the same suspension that engineers signed off and agreed upon after extensive testing all over the world and in various road conditions.
| The Following User Says Thank You to CSG David For This Useful Post: | themajesticone (08-12-2014) |
#68 |
Drives: FRS
Keeping that in mind...
~$1100 1. Bilstein B14's 2. Camber bolts or ~$1650 1. Swift Sport or Spec-R springs. ~$300 2. Camber bolts ~$35 3. Bilstein B8 struts ~$910 4. LCA's ~$375 5. Be done with my budget affordable one step at a time setup. or... ~$2300-2600 1. Get some RCE Tarmac 0's/KW v1 2. CasCam platers 3. LCA's oooooor... ~$3000 1. just get them Ohlins 2. LCA's Last edited by Firestorm_86; 08-12-2014 at 10:53 AM. |
#69 |
Señor Member
Great thread. It confirms a lot of what I had been feeling and the direction I want to head. I also love the mutual respect RCE and CSG show on the forums. Other vendors, particularly in the tuning section, could learn from you guys. I wish we had vendors like you here in Australia.
1974 TA22 Celica
2013 86 GT |
| The Following 4 Users Say Thank You to Turdinator For This Useful Post: | CSG David (08-12-2014), Firestorm_86 (08-12-2014), Racecomp Engineering (08-12-2014), themajesticone (08-12-2014) |
#70 | |
Drives: '13 UM86
http://www.mann-engineering.com/cata...sion/coilovers who works with http://www.ast-suspension.com/ but have done their own tuning to the coilovers themselves, if I have that right |
| The ISC Suspension-NA N1 Coilover System for the BRZ/FRS | ISC Suspension | Brakes, Suspension, Chassis | 17 | 04-29-2014 09:56 AM |
| Can shock-dynos tell you what the highest spring rate it can handle? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 02-16-2014 04:43 PM |
| coilover shock body height adj | garfull | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 05-19-2013 03:32 AM |
