Old 01-23-2014, 12:06 PM   #71
jamesm
Originally Posted by shiv@vishnu View Post
According to JR, it uses MAF, not SD hybrid. Same with Vortech and AVO.
i've never tuned one, but i do believe @nelsmar hit 5v rather quickly on the JR kit. again i havent experienced this myself, but based on my experience with a 3", and looking at their maf tube, it seems very reasonable to believe.
Old 01-23-2014, 12:24 PM   #72
CajunFRS
Drives: Challenger R/T, CRX SI,
This is good info for me because if I ever do pull the trigger I'm going for a smooth operation not big numbers.
I would like for my internals to see 100k inside of my motor.
Evo uses a hybrid SD/MAF so what about other cars.... GTR, STI, and GTI? I honestly think tuners should use whatever works for them. Long as the user experience is good and everything is running right.
CajunFRS is offline   Reply With Quote
Old 01-23-2014, 12:48 PM   #73
DJCarbine
Thupercharged
DJCarbine's Avatar
Can't find the info, but I wonder if the FRS factory tune is a MAF/SD hybrid...
2013 FRS
Vortech V3 11psi
Old 01-24-2014, 06:34 AM   #74
steve99
Originally Posted by TylerLieberman View Post
So if I buy an OFT now, the tunes on the device have this feature already correct?
Yes
Soft rev limit
Launch control
Flat foot shifting
Rough idle fix
DI Seal fix
Just check you ROM type supported
The Following 2 Users Say Thank You to steve99 For This Useful Post:
TylerLieberman (01-27-2014), xDanger_208x (01-24-2014)
Old 01-24-2014, 07:12 AM   #75
Malt
Drives: 2015 WRX
Why would the FRS be any different than the BRZ?
Malt is offline   Reply With Quote
Old 01-24-2014, 08:42 AM   #76
DJCarbine
Thupercharged
DJCarbine's Avatar
I meant the twins in general
2013 FRS
Vortech V3 11psi
Old 01-24-2014, 08:46 AM   #77
Malt
Drives: 2015 WRX
It only has a MAF stock. That's why there is all this talk about ecutek based SD conversions and wether it's necessary or not.
Old 01-24-2014, 08:49 AM   #78
DJCarbine
Thupercharged
DJCarbine's Avatar
The Frs/brz? They have MAF/MAP sensors stock
2013 FRS
Vortech V3 11psi
Old 01-24-2014, 08:50 AM   #79
Malt
Drives: 2015 WRX
If you knew then why did you ask? I can only assume it was to make someone look like an ass. Congratulations
Old 01-24-2014, 08:54 AM   #80
DJCarbine
Thupercharged
DJCarbine's Avatar
No, you read that completely wrong. I am trying to determine if the FRS/BRZ uses a MAF/SD hybrid tune from the factory. I'm not sure if the MAP sensor is for a limp mode if the MAF sensor is faulty, or if it uses the MAP sensor for fueling at high rpm. You were the one who jumped down my throat.
2013 FRS
Vortech V3 11psi
Old 01-24-2014, 09:04 AM   #81
Malt
Drives: 2015 WRX
Obviously there is intention lost in a text based means of translation. I apparently reacted to an assumption that was faulty just like you assumed I was jumping down your throat (not intended). Regardless, it's quite apparent that I do not have the knowledge set to answer the question but why would several of the aftermarket ecutek FI kits include an MAP sensor if it used one stock?
Possibly because of the same reason people swap to a larger diameter MAF tube (the factory parts are insufficient to deal with the increased airflow).
TLR, I need to stop talking about stuff I don't have first hand knowledge about.
The Following User Says Thank You to Malt For This Useful Post:
DJCarbine (01-24-2014)
Old 01-24-2014, 09:13 AM   #82
DJCarbine
Thupercharged
DJCarbine's Avatar
The FRS/BRZ has a map sensor that can read a few PSI above atmospheric, so boost in the 4-5psi range I think (someone correct me if its higher/lower). I'm not sure if the FRS/BRZ uses MAF/SD hybrid, but it would not be out of the question since the cars have both sensors stock and many OEM's use a hybrid MAF/SD.
I have noticed that the vortech (possibly the JRSC/Kraftwerks as well) carb tune kit does NOT include a MAP sensor... is this because you can't swap emissions sensors and still get CARB approved? I really don't know, and the info is hard to find.
Hell, if I didn't already have ECUTEK I would have been looking at the OFT because of the price
2013 FRS
Vortech V3 11psi
Old 01-24-2014, 09:40 AM   #83
jamesm
the stock ecu only uses the map sensor for fueling calculations during cranking. there are some necessary comps (like port mrp compensation) that use it, but generally it's more useful as an iat sensor in a blow-through setup lol.
The Following User Says Thank You to jamesm For This Useful Post:
Old 01-24-2014, 09:43 AM   #84
DJCarbine
Thupercharged
DJCarbine's Avatar
Good info!
2013 FRS
Vortech V3 11psi
#fanboysthread, oftsupportgroup, unichip ftw
ECUTek question ATSAaron Engine, Exhaust, Transmission 12 04-03-2014 06:37 PM
Ecutek's 86 jpit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 07-12-2013 12:35 PM
I need help on which ecutek I should get, stg 1 or 2 Frsexxxy Engine, Exhaust, Transmission 22 03-29-2013 10:45 PM
Which should I get ecutek stg 1 or stg 2? Frsexxxy Engine, Exhaust, Transmission 5 03-21-2013 01:10 PM
ECUTEK????? 20valvewynn83 Engine, Exhaust, Transmission 4 10-03-2012 09:34 PM
