Old 11-20-2013, 05:46 PM   #71
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
Originally Posted by jeebus View Post
lol, so I just took a "coffee break" and did some wot pulls. Pulls hard as hell. Fuel trims were solid at 0 at wot. I did notice that decel trims are looking even worse...-25 was common. So it's running rich as hell then. Won't that throw a code eventually too?
Decel is just that, decel. You aren't under power and the injectors are flirting with their min on-time. So you will often see big trims which is why suggest ignoring it. It is only under moderate to full load (when car is open loop, ie, STFT goes to 0) that LTFT's mean anything useful.
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
Luckrider (11-20-2013)
Old 11-20-2013, 05:55 PM   #72
jeebus
Drives: 2015 Mustang GT (on order)
sounds good. I'll play some more on my drive home (40 miles...much of it canyons)
Since I only got 11.2 gallons of e85 in there, at best my tank is e73 right now. At worst it's e60.
jeebus is offline   Reply With Quote
Old 11-20-2013, 05:56 PM   #73
Shiv@Openflash
Drives: 2013 FRS
That makes sense. You're lower E content will account for some of the negative fuel trims you are seeing too.
jeebus (11-20-2013)
Old 11-20-2013, 06:18 PM   #74
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by bfrank1972 View Post
Listen to this guy - read about some of the guys who had the flex fuel kits installed. Their ethanol content analyzer showed it definitely took a bit of driving before the effective ethanol percent went up any. Running gas with an e85 tune will run way too advanced and way too rich, running e85 on a gas tune is the opposite. Neither is good. Mad_sb/Shiv - does the ecu compensate (short term trims, closed loop) during easy driving when running the "wrong" map (I.e. when transitioning from one fuel to another)? I'm no expert, but I would think not since the AFR targets would be completely different right?
Sent from my iPad using Tapatalk - now Free
I watch the fuel trims so i know when to pull over and switch maps. Going from pump to E85 you can wait until the trims start going really negative. Depending on the mix, you may get a "system too [lean|rich]" code. The last time I switched i actually drove a way past where i would have normally pulled over and reflashed (because i was on the interstate). Fuel trims were able to keep it running fine, though i do not recommend driving around like that.
The Following 5 Users Say Thank You to mad_sb For This Useful Post:
bakerr6 (11-20-2013), bfrank1972 (11-20-2013), jeebus (11-20-2013), Luckrider (11-20-2013), WRB5titch (11-23-2013)
Old 11-20-2013, 08:41 PM   #75
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Anyone have an approximate change in milage with the corn juice?
Luckrider is offline   Reply With Quote
Old 11-20-2013, 09:53 PM   #76
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Got my tablet today. Flashed 1.34b and... dat rev limiter. This is a great tune -- can't wait to drain this tank and try some E85!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
Old 11-20-2013, 10:18 PM   #77
Malt
Drives: 2015 WRX
I was seeing around 31-32 mpg's a tank with 93. Currently I have about 100 miles on this tank of E85 and I'm sitting at 29.5 mpgs. Granted I don't drive like a retard on the streets, so depending on that your results might vary.
Malt is offline   Reply With Quote
The Following 3 Users Say Thank You to Malt For This Useful Post:
Cross (11-20-2013), Luckrider (11-20-2013), WRB5titch (11-21-2013)
Old 11-20-2013, 10:38 PM   #78
jeebus
Ok my e85 fuel trims are looking great. Remember I have a stock header.
High load LTFT is 0. AFR is 12.5
Cruise LTFT between 1 and -1, AFR 14.5
Decel LTFT no longer all crazy...now -1.5, AFR 20
Idle LTFT -1.5, STFT .78, AFR 14.7...shouldn't that be richer?
All feels great.
The Following User Says Thank You to jeebus For This Useful Post:
Old 11-21-2013, 09:44 AM   #79
Sterling Doc
Drives: 2002 911 Targa
With E85 maps now available, I could not resist any longer - ordered my tablet today. . I really like the process here - continuos, real time, open development.
Sterling Doc is offline   Reply With Quote
The Following 4 Users Say Thank You to Sterling Doc For This Useful Post:
Garrett@Openflash (11-22-2013), Robert@Openflash (11-21-2013), Sargy (12-11-2013), Shiv@Openflash (11-21-2013)
Old 11-21-2013, 09:51 AM   #80
akyp
Drives: 2012 86
Hi,
The reason you are seeing what looks to be a problem with the XDF is because you are trying to view your 700G ROM in our XFD which is meant for 01G ROM type. Even our 700G tune is actually a 01G rom type since all are tunes are based on the latest factory ROM release. It was just named with "700G" in the name so that OpenFlash manager would allow it to be loaded (it doesn't allow changes of ROM IDs for safety's sake). In the case of the 700G and 01G ROM types, the share mostly the same mad locations with the exception of (but not limited to) VVT intake and exhaust base tables (which we don't even modify btw). So don't bother trying to view your original ROM with the XDF unless your original ROM is 01G type.
Cheers,
Shiv
Thanks for explaining. I flashed v1.34 and my engine is happy. Loving the soft rev limiter too!
akyp is offline   Reply With Quote
The Following User Says Thank You to akyp For This Useful Post:
Old 11-21-2013, 09:52 AM   #81
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
went from 1.31 stg 2 to the 1.34. idk what the map scaling has done but that mid range pulls way harder all the way to red line and the car hasnt even fully learned throttle trims yet. great work
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
Old 11-21-2013, 12:30 PM   #82
CamryDS
Drives: 2003 Camry Blue | 2013 FR-S White
I have to say this is OFT was the best impulse buy I did yet -- thanks @shiv@vishnu for the constant support! More and more enhancements each time I come on this board.
CamryDS is offline   Reply With Quote
The Following 2 Users Say Thank You to CamryDS For This Useful Post:
Robert@Openflash (11-21-2013), Shiv@Openflash (11-21-2013)
Old 11-21-2013, 09:39 PM   #83
krulux
Drives: 2013 Scion FRS
Happy customer here. Wow. Huge grin on my face tonight. !!!
I ordered the OFT 2 days ago. It was delivered about an hour ago. After eating I downloaded the software, installed and patched win8.
I walked outside and Read the stock ecu map from the car. Came back in and and plugged the OFT into my machine. Opened the manager and it updated in a snap.
I pointed the Manager to my previously downloaded 1.34 Stage1 map and uploaded to the OFT.
Walked back outside and plugged the OFT in, followed the on-screen directions, and let it Write to the ecu. Total time was about 15min tops.
I started the car and let it idle for about 1.5 mins. Eased out onto the road and drove gently for about 10mins and let the temperature rise to normal.
By then I was out in the sticks/backroads. Long graceful curves for miles. I opened the throttle to full for several 3/4/5 gear pulls and I still can't get the grin off my face.
Sweet Mother - my little FRS pulls like a banshee now. Very nice rasp from 4K to 6.5k sweetening up to 7Kish gear shift with an excellent exhaust growl at the top.
I want to give you guys at Vishnu a round of well-earned applause .
Fantastic job!!!
The OFT tablet looks to easily be the best upgrade my lil Whiteout FRS has seen thus far. I am very happy with my purchase. Extremely happy.
Thanks guys!
krulux is offline   Reply With Quote
The Following 4 Users Say Thank You to krulux For This Useful Post:
Garrett@Openflash (11-22-2013), Robert@Openflash (11-22-2013), Shiv@Openflash (11-21-2013), yuicebox (11-21-2013)
Old 11-21-2013, 09:41 PM   #84
bakerr6
Drives: 2013 raven black fr-s
All feels great.
I can confirm my numbers are similar. I wouldn't be concerned though tbh
bakerr6 is offline   Reply With Quote
The Following User Says Thank You to bakerr6 For This Useful Post:
jeebus (11-21-2013)
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
