#71 | |
2014 will be here in a week if u want to do some baselines. |
#72 |
Drives: First SWP BRZ-L
I've got aftermarket headers. So I doubt they'd cover it.
First white BRZ in the country
![]() Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers |
#73 | |
Drives: frs
man, the new WRX is UGLY. as much as loved the concept i think this is THE ugliest impreza, I even like the current one better than this new one. so that would have to be only a possible engine swap. btw, what about that common DI engines sludge problem? have manufacturers fixes that yet. |
#74 | |
Drives: Some rust bucket
#75 | |
Drives: 2015 Mustang GT (on order)
#76 | |
Drives: 2013 Firestorm FR-S
so just to be clear, in your opinion, fixing the transient ignition tables with an aftermarket tune doesn't correct the problem?
2013 Firestorm FR-S, MTX, build date 1/13.
#77 |
There's only speculation on both sides for this, so you won't get a straight answer. Some say "yes", some say "no", some say "yes...but maybe damage was done before the tune was put on so the problem could still occur."
#78 |
Latent damage would not continue to degrade, if the updated tables truly fixed the problem.
#79 |
Again, debatable. Say the seals got brittle from knock but didn't fail. Then you get the ECU fix. Running at the track on a hot day, really spanking that motor, that seal finally says "I've had enough!!!".
#80 | |
acab, for example, did 10ish (?) track days AFTER getting a tune, before getting the issue; he only did 1 track day untuned. If 1 track day caused that damage... |
#81 | |
#82 |
Drives: Mazda 3
it depends on the tune as well. If the seals are damaged by knock events even with stock tune, then shouldn't a tune to "fix" the seals problem be a detune to keep knock at bay in all situations not just transient retard?
#83 |
#84 | |
Drives: SSM LT MT BRZ
Perhaps I should elaborate. Subaru is only supposed to update to the newest applicable rom for any given car. Any rom newer than the release of the DI seal fix will include that fix. Each Rom has an identifier, mine is the same as when it came from the factory. I asked the rep specifically which rom image was loaded. he specifically referenced the ZA1JA00C rom....but that is not the image that was on my ECU |
| Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
| Wind noise from door seal - possible fix | nzer | Issues | Warranty | Recalls / TSB | 2 | 05-05-2013 02:36 PM |
| DetailersDomain.com - Clean Up - and Seal - Audi S4 | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 3 | 03-08-2013 04:16 PM |
| Nitro seal applied | bacon_cheese_beer | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 11-19-2012 12:22 PM |
| Whiteout FR-S | Detail + HD Nitro-seal | MattR | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 6 | 09-20-2012 01:15 PM |
