Old 11-20-2013, 03:22 PM   #71
CSG Mike
CSG Mike's Avatar
Originally Posted by SkullWorks View Post
to add further confusion to this fiasco...I had to get my ECU updated at Subaru inorder to renew registration, HOWEVER, upon pulling the file to prepare for reflashing I found that my ECU still had the original rom loaded. not the 01C file but the 00C file.
Yet they certified to the DMV via online submission and provided paperwork that the ECU had been updated...chew on that for a minute...
Ah, we had the exact same thing. It's a revised 00C tune... they ONLY change the portion that affects emissions.
2014 will be here in a week if u want to do some baselines.
Old 11-20-2013, 07:13 PM   #72
Tainen
Drives: First SWP BRZ-L
1st time issues seem to USUALLY be covered, so just track it, and then after you need to warranty it once.... sell it?
Or, consider it part of the expense of tracking.
As always, YMMV.
I've got aftermarket headers. So I doubt they'd cover it.
First white BRZ in the country
Limited SWP BRZ, 35% tint, clear bra, Nameless Performance downpipe, axelback, headers
Tainen is offline   Reply With Quote
Old 11-20-2013, 10:03 PM   #73
vgi
Drives: frs
Originally Posted by AyJay View Post
I'm highly interested what Subaru's does w/ the DI seals in this iteration of the FA20. If they do something different with it, perhaps it will clue us in to a possible solution for us.
http://www.autoblog.com/2013/11/20/2...u-wrx-2013-la/
Also, possible engine swap???
that is their own DI, not a toyota d4-s, so won't apply to us i would think.
man, the new WRX is UGLY. as much as loved the concept i think this is THE ugliest impreza, I even like the current one better than this new one.
so that would have to be only a possible engine swap. btw, what about that common DI engines sludge problem? have manufacturers fixes that yet.
vgi is offline   Reply With Quote
Old 11-20-2013, 11:25 PM   #74
ayau
Drives: Some rust bucket
Originally Posted by smbstyle View Post
I think Dave-ROR might have close to that on his by now? I'm at 9 track days, and will have about 15-20 racked up next year, so I'll keep everyone updated. Like I said in another thread, I haven't heard of anyone in the Southeast having issues, specifically Florida; it seems like all the west coast cars are duds? lol
@aCab had his seals melt, and he's from the midwest. I don't think's it's related to the quality of gas between California and the other states.
Old 11-21-2013, 12:15 AM   #75
jeebus
There was an update related to emissions that was required. Has nothing to do with this di seal fix
jeebus is offline   Reply With Quote
Old 11-21-2013, 09:15 AM   #76
brillo
Drives: 2013 Firestorm FR-S
so just to be clear, in your opinion, fixing the transient ignition tables with an aftermarket tune doesn't correct the problem?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 11-21-2013, 10:18 AM   #77
jeebus
There's only speculation on both sides for this, so you won't get a straight answer. Some say "yes", some say "no", some say "yes...but maybe damage was done before the tune was put on so the problem could still occur."
Old 11-21-2013, 11:24 AM   #78
CSG Mike
CSG Mike's Avatar
Latent damage would not continue to degrade, if the updated tables truly fixed the problem.
Old 11-21-2013, 11:59 AM   #79
jeebus
Again, debatable. Say the seals got brittle from knock but didn't fail. Then you get the ECU fix. Running at the track on a hot day, really spanking that motor, that seal finally says "I've had enough!!!".
Old 11-21-2013, 12:02 PM   #80
CSG Mike
CSG Mike's Avatar
I'll gladly replicate the problem for you on your own car, if you're really convinced that it doesn't happen.
acab, for example, did 10ish (?) track days AFTER getting a tune, before getting the issue; he only did 1 track day untuned. If 1 track day caused that damage...
Old 11-21-2013, 12:22 PM   #81
jeebus
I'm not convinced it doesn't happen. But I am convinced that none of us are 100% certain about whether or not the tune fixes it.
Old 11-21-2013, 12:37 PM   #82
autobrz
Drives: Mazda 3
it depends on the tune as well. If the seals are damaged by knock events even with stock tune, then shouldn't a tune to "fix" the seals problem be a detune to keep knock at bay in all situations not just transient retard?
autobrz is offline   Reply With Quote
Old 11-21-2013, 12:38 PM   #83
CSG Mike
CSG Mike's Avatar
I've seen enough tuned cars, using updated base maps, fail, that I'm not convinced that the tune fixes it.
Old 11-21-2013, 01:05 PM   #84
SkullWorks
Drives: SSM LT MT BRZ
Perhaps I should elaborate.
Subaru is only supposed to update to the newest applicable rom for any given car. Any rom newer than the release of the DI seal fix will include that fix.
Each Rom has an identifier, mine is the same as when it came from the factory.
I asked the rep specifically which rom image was loaded. he specifically referenced the ZA1JA00C rom....but that is not the image that was on my ECU
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 06:09 PM
Wind noise from door seal - possible fix nzer Issues | Warranty | Recalls / TSB 2 05-05-2013 02:36 PM
DetailersDomain.com - Clean Up - and Seal - Audi S4 DetailersDomain Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 03-08-2013 04:16 PM
Nitro seal applied bacon_cheese_beer Cosmetic Modification (Interior/Exterior/Lighting) 0 11-19-2012 12:22 PM
Whiteout FR-S | Detail + HD Nitro-seal MattR Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 09-20-2012 01:15 PM
