Old 11-03-2013, 03:06 AM   #71
ft_sjo
Drives: GT86
Originally Posted by Kostamojen View Post
Why would you even do that?
Because it's easy to type random crap on the internet.
Old 11-03-2013, 03:12 AM   #72
PantsDants
Drives: Scion FR-S A/T, Whiteout
What he said. This mod, coupled with an upgraded radiator, should hold up just fine for anything you throw at it N/A. You may reevaluate later if you decide to go bonkers with forced induction though*.
The pros for this setup definitely outweigh the cons. With this, you get an oil warmer, oil cooler, and you don't have to worry about losing engine oil due to core or line leaks. It really seems like the way to go. I simply plan on installing just the oil cooler without upgrading the radiator as I don't see any track use in my immediate future. Regulating under hood temps via cooling the engine oil down as well as getting to operating temp faster is a big win for me. Plus the added peace of mind of reduced oil temps preventing degradation.
* Pretty much talking out my ass here.
PantsDants is offline   Reply With Quote
Old 11-03-2013, 07:27 AM   #73
CARNZ
CHECK ENGINE
Drives: 2004 STi
Based on my experiences so far, my coolant temp has not risen over 200 in hard driving. It will get up to ~210F sitting still before the fans kick on like usual, but never over heated or got hotter than 212F.
For some reason I can't log the oil temp parameter in BRZedit even though it shows it on the logger, I'm going to email epifan about that.
You may not even need to upgrade the radiator unless you are seeing over 210F on the track, but if you're tracking it you should have already upgraded the plastic end-tanked stocker anyway :P
i don't cry about crickets
CARNZ is offline   Reply With Quote
Old 11-03-2013, 08:28 AM   #74
imom
Drives: BRZ sold
Hi Carnz, can you please post the part number for the BRZ water bypass pipe the equivalent to the FXT 14050AA970. I can't find the part number online, Subaru's website only shows pictures and description, but not sure if this is the right one...would help if I could get the BRZ bypass pipe part number..I'm thinking of taking the pipe modified by a local shop and swapping it out when I'm ready to add the oil cooler.
Also you mentioned a bundle deal, what kind of pricing are you talking about? Please let me know.
Your write up has been helpful, but it's missing some steps for those that has never installed the oil cooler before... I don't see it in my head how the water is being diverted from the water pipe to the oil cooler and then back into the system...sorry just need to clear up how it's connected and whether I need to buy the 14050AA970 part or modify the BRZ version or buy the BRZ version and have it welded extra outlet. Thanks,
Lastly, do you think one gallon of the SOA868V9270 Subaru long life Coolant is enough...I hope this is the right part number.
imom is offline   Reply With Quote
Old 11-03-2013, 08:52 AM   #75
CARNZ
CHECK ENGINE
Drives: 2004 STi
15208AA130 is the part number for the BRZ oil filter.
You need Subaru Super Coolant not the Long Life Coolant. I will get the part number tomorrow at work.
I will also look up the BRZ bypass pipe Monday.
I have removed my bundle after finding that it all can be had cheaper from Heuberger than what my parts manager wanted to do.
Old 11-03-2013, 09:08 AM   #76
imom
Drives: BRZ sold
Sorry about that...too many part numbers to keep track... so I read your posts again, thinking of modified BRZ bypass pipe would be better in terms of no kinks...just have to pay a welder to do it and keep it stock looking.
If it's not too much work...a hand written diagram would be helpful....understand if you don't have time... your thread has been very helpful. Thanks!
Old 11-03-2013, 10:52 AM   #77
Kostamojen
Drives: 1993 Impreza w/ WRX Swap + FWD!
http://www.ft86club.com/forums/showp...8&postcount=27
Kostamojen is offline   Reply With Quote
Old 11-03-2013, 02:37 PM   #78
brn12345
brn12345's Avatar
Subaru has a few part numbers for different cars with different sized oil coolers. Maybe it would be useful if we can find a part number for a bigger capacity cooler from a different model that would work for us?
brn12345 is offline   Reply With Quote
Old 11-03-2013, 03:11 PM   #79
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
This will give Cusco competition, nice setup!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 11-03-2013, 04:02 PM   #80
Kostamojen
The 2014 Forest XT oil cooler is so far the only one specifically made for the top mounted oil filters on the FB/FA motors.
Its also the same one used on the STI concept:
Old 11-03-2013, 04:03 PM   #81
CARNZ
CHECK ENGINE
Drives: 2004 STi
Why not use the one made for the FA20?
Old 11-03-2013, 04:14 PM   #82
imom
Drives: BRZ sold
Is this the Forester XT inlet and outlet connection and what CARNZ had used for the BRZ set up? As shown in the first attachement from Kostamojen's picture?
Thank you Kostamojen for your proposal... your way seems to save the cost of getting another water bypass pipe
Kostamojen's water routing for the oil cooler picture (second attachment)
I still like to get get the full part number of the BRZ water bypass pipe in case I need to buy it.
Old 11-03-2013, 11:28 PM   #83
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
Because I already have a Perrin oil cooler
Thank you for the explanation. At first I had mixed(confused) feelings because my Perrin oil cooler has a different way of cooling down the oil level and wondered why the hell Subaru didnt do this in the first place. Using water temps to heat up the oil faster and then regulate the temps all makes sense now. I wonder if they will implement this idea for the 2015 versions.. guess well just have to wait and see.
LeeMaster is offline   Reply With Quote
Old 11-04-2013, 03:07 AM   #84
Acree
Acree's Avatar
Drives: 13 CSB BRZ Ltd
Excellent thread. Great job.
2011 BMW M3 (No torque dip)
2013 Subaru BRZ - SOLD - Build Thread
Acree is offline   Reply With Quote
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
