Old 11-24-2015, 09:19 PM   #71
kodyo
Drives: Scion FR-S
Originally Posted by mcbrawr View Post
Does anyone have a link to the part # for the pinion bearings?
90366-35087
90366-30067
I believe those are the two for the pinion bearings.
90366-50001 is the one for the axle bearings I'm pretty sure.
I'd double check with a common parts diagram online, but those are the ones I ordered for my IS300 pumpkin, which should theoretically be the same ones in the stock diff.
EDIT
This is where I normally order from (has parts diagram):
http://www.toyotaonlineparts.com/aut...ferential-scat
This diagram is saying 90366-35170 & 90366-30108 in lieu of the above. I strongly suspect they might be identical. But if you are rebuilding an FRS pumpkin and not an IS300 pumpkin, probably not worth risking.
kodyo is offline   Reply With Quote
The Following 2 Users Say Thank You to kodyo For This Useful Post:
jcw99 (03-04-2016), mcbrawr (11-25-2015)
Old 06-02-2016, 01:47 PM   #72
kev60625
Drives: 2013 WRB Subaru BRZ
Thank you so much for this thread!
kev60625 is offline   Reply With Quote
Old 10-19-2016, 04:08 PM   #73
mrbbs
Drives: GT86
Thanks for the information!
Would you know the Toyota part number for the 4.875 final drive? Will it fit the standard 2017 carrier?
mrbbs is offline   Reply With Quote
Old 10-31-2016, 12:20 AM   #74
kodyo
Drives: Scion FR-S
Just use the 4.88 for the Mk3 Supra (1986-1992) from here:
http://weirperformance.com/finaldrivegears.html
The Following User Says Thank You to kodyo For This Useful Post:
Freeman (10-31-2016)
Old 02-10-2017, 02:28 PM   #75
allmotorrex
allmotorrex's Avatar
Drives: 08 4x4 offroad tacoma/ raven fr-s
Most of this talk is about the is300 diff so I want to ask and clarify this .....
I have 2 dedicated drift mk3 supras (both 88s) along with 3 spare diffs. 2 have the lsd and 1 does not. My frs is FI and I want a taller gear. Can I directly swap one of my supra diffs into my frs? Pumpkin for pumpkin?
allmotorrex is offline   Reply With Quote
Old 03-05-2017, 09:37 AM   #76
kodyo
Drives: Scion FR-S
Doubtful, but don't quote me on that. Only Supra part I've heard people use are specific to the ring/pinion gear sets inside the pumpkin.
Old 04-11-2018, 02:16 AM   #77
BurnetRhoades
BurnetRhoades's Avatar
Drives: 2013 "Hot Lava"
Bit of a necro, but I was watching a Smoking Tire segment where the car being driven was a heavily modified Honda where the final two or three gears were selected from different models of Honda/Acura to improve highway cruising after going with an aggressive final drive.
Has anyone done something similar so that once changing to a 4.56 or 4.88 a non-stock 5th and 6th gear is used so that revs between 60-70 are back at stock or, even better, better than stock? It would be great to be cruising at highway speeds and not hovering around 3K (prior to final drive swap).
2013 Hot Lava FRS :: OFT Stage 2+ :: JDL UEL Catless :: JDL Over-Frontpipe :: GReddy Evolution RS Catback :: Enkei "Tarmac Black" RPF1 :: Tein Flex-Z Coilovers :: 245/35r18 Conti DW :: RS*R R-LCA :: Racer-X Fab R-Toe Arms :: Mishimoto Intake Tube :: Mishimoto Oil Catch Can :: JDL FSTB :: Raceseng "Slammer" + RLO :: Diode Dynamics HID + Tail-as-Turn + DRL :: 5:AD Spoiler ::
BurnetRhoades is offline   Reply With Quote
Old 12-14-2018, 11:00 AM   #78
spitsnaugle
Drives: LS Swapped Scion FRS = 440HP
Resurrecting this thread. Not sure if this has been discussed but it appears we can use Nitro Gears&Axel 29-spline gears with a new flange for more gear ratios.
New Flange (ours is 60x60mm)
https://www.justdifferentials.com/YO...yfitkit-29.htm This also leave the option of using a 66x66 flange for a larger joints.
Gears: 3.90 | 3.73 | 3.58
spitsnaugle is offline   Reply With Quote
The Following User Says Thank You to spitsnaugle For This Useful Post:
rixter145 (03-22-2020)
Old 03-22-2020, 04:27 AM   #79
rixter145
Sleep Chomper
rixter145's Avatar
Do we need to get all of this to do a FD swap?
2012- 2016 Scion FR-S, use with Master install Kit MKTLC100-IFS, solid spacer SKCSTV6, and Yoke fit kit YOKTOYFITKIT-29.
rixter145 is offline   Reply With Quote
Old 03-22-2020, 10:46 AM   #80
86TOYO2k17
Drives: 2017 toyota 86
You just need the ring, pinion, shims, and crush spacer or solid spacer, depending on how many miles your diff has seal and bearing would be a good idea too.
What ratio are you thinking?
Old 03-22-2020, 02:16 PM   #81
rixter145
Sleep Chomper
rixter145's Avatar
Got it. I'm debating on the 3.9 vs 3.7.rebuilt my motor and I'm using a cd009 tranny. The gear ratio is a bit shorter so the 3.9 will give me the same speed as the 4.1 with stock tranny ratios
Sent from my H8314 using Tapatalk
Old 03-22-2020, 03:40 PM   #82
86TOYO2k17
If your going 3.9 or 3.7, then buy the rear diff with gears already installed way easier and cheaper
Old 03-22-2020, 03:41 PM   #83
rixter145
Sleep Chomper
rixter145's Avatar
I have a os giken LSD on my current pumpkin. Would need to swap it anyways
Old 03-22-2020, 03:49 PM   #84
86TOYO2k17
Ah then you’ll have to weigh your options, but the os giken is supposed to not mess with backlash and need reshiming, could possibly get the 3.9 diff assembly for 3-400$ and swap over the Giken since bearings are already pressed may be pretty easy DIY. Otherwise you’re looking at about 4-500$ just on labor swapping in ring and pinion if you’re pulling assembly yourself. Now if you can DIY everything thats a different story.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post:
Final Drive Discussion JimmyMac Engine, Exhaust, Transmission 118 08-07-2017 10:18 PM
Change gear ratio? Afdad120108 Engine, Exhaust, Transmission 61 08-17-2016 10:44 AM
Final Drive Calculations wootwoot Engine, Exhaust, Transmission 34 12-19-2014 04:06 AM
Change FD ratio to 4.56 by changing only pinion peachch Engine, Exhaust, Transmission 1 08-31-2013 01:25 PM
Correcting drive ratio for accurate speed AlexTheGreek Engine, Exhaust, Transmission 25 12-05-2012 01:13 AM
