Old 10-01-2013, 05:25 PM   #71
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Whoever says you should drive it like a Yaris hasn't seen me drive my Vitz on autocross.
While I may not win my class, I don't finish last and I certainly beat out better cars with the Vitz all on stock ... everything.
Video here: [ame]http://youtu.be/y0uZJpGeEtg[/ame]
Results here:
http://www.wiredmotorsports.com/pitl/results.php
I competed in the last three events of the season and got better with it (my first season with the car).
As for the OP, I hope SOA steps up to the plate for this. Threads like this really are pushing me away from the twins and towards the MX5 or a used S2k.
Frost is offline   Reply With Quote
The Following User Says Thank You to Frost For This Useful Post:
strat61caster (10-01-2013)
Old 10-03-2013, 06:26 AM   #72
regal
Originally Posted by Dezoris View Post
However, I don't expect anything else from a 25k car regardless of the manufacturer.
$25k is a lot for a car. Why would anyone want to invest more in this thing than buying a Cayman?
I can name several <$20k cars that can take full on abuse starting with my Yaris.
At $25k this car had better hold up than Mustangs, Golf, Genesis, etc. And don't give me the this is a different kind of car BS. If a car can't get you back and forth to work reliably then everything is out the window.
I think the main reason this car has been so successful is the Toyota+Subaru (Japan) branding, their rep is building bullet proof cars.
If you're saying they failed at that and the car gets a bad rep, resale will tank and then the platform will go *POOF* IMHO.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 10-03-2013, 07:34 AM   #73
Dipstik-sportech
Dipstik-sportech's Avatar
That's bs right there. It shouldn't matter if it's a $500 or a $500,000 car it's brand new!!! I understand that first year cars will have teething problems but stand behind the product, don't jut say too f#$king bad you get what u pay for. What irritates me is that I believe I found what could be the cause of this and Subaru and Toyota (aisin trans=Toyota btw) and the don't seem to care. I'll be really pissed if they come out with a redesigned trans later and don't offer it to the people who's trannys are already failing.
Old 10-03-2013, 07:48 AM   #74
ZZT86
ZZT86's Avatar
Drives: BR86
The # on the door of the blue BRZ/86 ? is the wrong way around
ZZT86 is offline   Reply With Quote
Old 10-03-2013, 09:35 AM   #75
ZionsWrath
Thanks
ZionsWrath's Avatar
Originally Posted by Hawaiian View Post
character assassinate much?
You have no idea how i drive or shift. The speed shift was his term not mine, and I definately dont slam into gear on shifts like that. The tech however shifted slower than my 16 yead old auto civic winter beater.
You can shift quickly without beating on the trans.
This, in fact I'd say things such as a quick rev match down shift you can only hear and not feel if done properly in less than a second.
What about the South Africa TSB on injectors? It mentions shifting in less than .6 seconds if I recall correctly? Why would there be a TSB for an issue that involves "speed shifting" if it were considered abuse?
Old 10-03-2013, 12:04 PM   #76
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Originally Posted by Rabble View Post
Customer goodwill is a load of horseshit. That transmission is $8000 in parts alone. No dealership is going to eat those costs.
It sounds like they fucked something up and are trying to keep that off their corporate records. Keep pushing.
Retail is only $2,300 for a complete 6MT...and Goodwill is paid for by SOA, not the dealer.
Originally Posted by Mr.Zoolittle View Post
I was also upset when my cars brakes/rotors were replaced under "goodwill". The owner smoked the brakes and denied it. I will never buy a demo car again.
"smoked brakes" are not a result of a defect, which is all the warranty covers. Failure due to any other cause would result in a denial, or a repair as a goodwill gesture.
Originally Posted by vgi View Post
So turbo actually voids gearbox warranty?! Is this due to more hp/tq?
Yes, the warranty covers defects in the stock configuration. It is easy to surmise that a turbo increases the load on the transmission, something beyond what the factory intended it to do.
Originally Posted by Ralph Spoilsport View Post
It's worth noting... GL-5 absolutely does not belong in your transmission (unless also GL-4 rated, e.g. Motul). Maybe that was a typo?
The transmission fluid requirement is a GL-3/4 or better, GL-5 is fine.
Originally Posted by feldy View Post
So glad I went with Scion. Had crickets replaced, rubber weather striping, drivers side rear axle, both tail lights and the drivers side window visor replaced. Nothing denied so far. Even had the car on springs and koni shocks and was not denied axle warranty.
My BRZ has had 31 warranty claims (including the free maintenance), nothing denied...it's not a Scion vs Subaru issue.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
Old 10-03-2013, 12:49 PM   #77
DoomsdayJesus
In Autobahn withdrawl
DoomsdayJesus's Avatar
Drives: 2015 BRZ Limited Man., WRB
My main problem is apparently with a regional parts manager, but it's no secret the Subaru doesn't have the best warranty practices. You may just be lucky with your dealer and their region.
DoomsdayJesus is offline   Reply With Quote
Old 10-03-2013, 02:42 PM   #78
vgi
Drives: frs
well, the car was advertized as and shown as a track toy, so 'the normal' conditions should encounter for heavy braking and if the brakes are smoked - it is a manufacturing defect.
I would want to see an actual document from Subie or Scion defining exactly what "the normal conditions" are. Say... the car has 4 sits and I fit 3 250lbs bodies (somehow) and go to NYC downtown. is this considered normal? because I suspect my shocks would be shut after few hours of driving there.
yeah, I get that part. only most people complaining here have grinding boxes on stock cars. so it is easy to surmise they may be unlucky to develop this grinding (not related to extra hp/tq) after they install the turbo. i would assume shut synchros don't have much to do with hp/tq but rather RPMs and fluid used?
well, I guess it depends on who's filing those 31 claims and what he does for living. Obviously, common folks are at the mercy of dealership and subaru/toyota reps.
vgi is offline   Reply With Quote
Old 10-03-2013, 07:17 PM   #79
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
GL-5 isn't "better" than GL-4, it's different. Significantly, it's different in a way that can lead to poor synchronizer performance.
Ralph Spoilsport is offline   Reply With Quote
Old 10-04-2013, 06:33 AM   #80
regal
I think some GL-5 will corrode the brass synchros.
Why do so many people on here claim a replacement tranny is $2500? My dealer wants over $6k ?
Also when I bought this car everyone on here said this was a Toyota built transmission, people here and online reviewers were saying this is the best manual transmission short of BMW.
First the main casting of the tranny says "Subaru" and it is far from any BMW I've owned, how could so many have been so far off base?
Is there a difference between the manual transmission in the GT-86 vs the BRZ and Scion ?
Mods:
Old 10-04-2013, 07:03 AM   #81
Dipstik-sportech
It may say Subaru on one side but on the other it says Aisin. When my dealer was trying to get me internal parts they had to call Lexus to get some of the part numbers. Gotta love joint venture cars lol.
Old 10-04-2013, 09:45 AM   #82
Opie
Opie's Avatar
Subaru recommends using Subaru Extra-S 75W90 fluid in the BRZ. It is a synthetic GL-5 gear oil, same as specified for the STI transmissions. Both transmissions use brass synchronizers...as do most. Never seen one that suffered from corroded synchronizers.
Old 10-04-2013, 09:50 AM   #83
Opie
Opie's Avatar
I'll sell you 3 complete BRZ manual transmissions for $6,592.89, No seriously...or just 1 for $2,197.63...
http://mastrosubarusanfordparts1.rea...5918&makeid=32
Old 10-04-2013, 12:34 PM   #84
strat61caster
strat61caster's Avatar
All transmissions between variants are identical regardless of badge, they are all built by Aisin who builds/built transmissions for the following: Ford, Mazda, Volvo, Chrysler, Toyota, Alfa Romeo, Porsche*
[ame="http://en.wikipedia.org/wiki/List_of_Aisin_transmissions"]List of Aisin transmissions - Wikipedia, the free encyclopedia[/ame]
*Proof: http://www.aisin-ai.co.jp/english/news/20040916.html
ineedyourdiddly
5th Gear "Mini-Grind" BRianZ Issues | Warranty | Recalls / TSB 63 07-18-2015 05:12 AM
Should this be covered by warranty and can Subaru repair this? brzadmir Issues | Warranty | Recalls / TSB 16 08-01-2013 12:08 AM
New "Drive Clean" on wheel repair and fitment SkAsphalt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 07-10-2013 05:59 PM
Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode SteveH Other Vehicles & General Automotive Discussions 7 02-13-2013 12:08 AM
16" Subaru Steelies $39.99ea limited to 4 sets Stav Canada Classifieds 5 01-03-2013 11:15 PM
