#57 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
Update: I went back to the dealer and talked to the excellent service rep that I originally set up the repair with. He said none of his notes were present, which is what I suspected. He said the regional parts manager made them put that clause in and say it wasn't warranty, probably to cover their ass. I asked for her name and contact info, and he said they weren't allowed to give it out, but to call SOA back and make sure to follow up.
At this point I don't know who changed the wording in the description of the problem from mine to something way more severe. He also confirmed it was her that said "the car's not designed to be shifted at 7000k RPM." What a crock. This is going to be a pain in the ass to fix, and I don't know exactly who a BBB complaint would be against if it was a regional parts manager who's screwing me. |
#58 |
Mentat
Drives: 2013 Scion FRS 6MT
LOL @ car is not designed to be shifted at 7k rpm. Maybe they should of lower the redline to 5k rpm and market the car with 150hp instead of 200hp.
| The Following User Says Thank You to Muaddib For This Useful Post: | sprintertrueno86 (11-26-2013) |
#59 |
I also just took a look at the service manual, which clearly says only use GL-3 in the manual trans and GL-5 in the rear dif.
They clearly put the wrong gear oil in my MT if it's not a typo. What used to be a grind in 4th now just has pretty rough/notchy shifting all over, especially going into 3rd (although no grind). I'm beyond fed up with this process and them screwing me/my car. I'm going to take it back and have them put the correct gear oil in, my bet is if they fill these stock with GL-4 or GL-5 that's one of the problems. |
#60 | |
Drives: SWP BRZ
#61 |
Drives: Scion FR-S (Asphalt)
Just thought I'd throw this out there. I have the same issue with my trans and have been getting the run around as well with the dealership. I'm not sure about with the BRZ, but my FRS has a three small booklets about warranties and maintenance that are with the service manual. All of them mention that there is a specific association to report to first that handles disputes with dealerships, lemon laws, and lawsuits. I'll take a look at see what the name was. might check in your manual to see if it says the same thing...
#62 | ||
#63 | |
Drives: 2013 Subaru BRZ
(API GL-3, SAE 75W-90)", but any GL-3 or later 75w-90 can be substituted. So GL-5 is acceptable. |
#64 |
You're right, but I've read numerous places that GL5 shouldn't be used in transmissions with brass parts. At this point I'm on the fence about replacing my fluid until the problem is resolved.
Sent from my Marconi Telegraph |
#65 |
Drives: Nevermorange FRS
This is a little more accurate:
PRO86 | WTCC | STL
| The Following User Says Thank You to rice_classic For This Useful Post: | Dipstik-sportech (10-01-2013) |
#66 | |
Drives: 2014 BRZ Limited DGM
| The Following 2 Users Say Thank You to dehydratedH2O For This Useful Post: | Dipstik-sportech (10-01-2013), strat61caster (09-30-2013) |
#67 |
Seeing these threads constantly are a huge downer. The mass market dealers and companies don't have much interest in dealing with the enthusiast crowd.
However, I don't expect anything else from a 25k car regardless of the manufacturer.
#68 | |
That guy
Drives: Ultramarine mt FR-S
You have no idea how i drive or shift. The speed shift was his term not mine, and I definately dont slam into gear on shifts like that. The tech however shifted slower than my 16 yead old auto civic winter beater. You can shift quickly without beating on the trans.
Ultramarine mt FR-S
P&L stage 1 turbo Prime Motoring Flex fuel Jr Tuned 506whp @17psi (e73) |
#70 |
| 5th Gear "Mini-Grind" | BRianZ | Issues | Warranty | Recalls / TSB | 63 | 07-18-2015 05:12 AM |
| Should this be covered by warranty and can Subaru repair this? | brzadmir | Issues | Warranty | Recalls / TSB | 16 | 08-01-2013 12:08 AM |
| New "Drive Clean" on wheel repair and fitment | SkAsphalt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 07-10-2013 05:59 PM |
| Top Gear Crashes Helicopter During Filming of "Top Gear Korea" Episode | SteveH | Other Vehicles & General Automotive Discussions | 7 | 02-13-2013 12:08 AM |
| 16" Subaru Steelies $39.99ea limited to 4 sets | Stav | Canada Classifieds | 5 | 01-03-2013 11:15 PM |
