Old 06-01-2016, 12:50 AM   #71
mchasteen1
Software Engineer
mchasteen1's Avatar
Drives: '14 FRS Monogram (Ultramarine)
Originally Posted by j_motion View Post
ok my Reverse light "" brake Light" wired to display the F1 style 3 blink -> solid is causing some problem.
I will do a little write up about the problem later
I meant to add a follow up to this, but I got distracted. The wiring DID cause issues for me as well. Powering the V with both the running lights AND the brake light caused feedback in the system that affected other lights (center console and parking/indicator lights for me).
The solution was to take the V off the brake light. That means I connected the red wire directly to the green wire so that it doesn't touch the board at all. Straight up red to green. I've had no problems since then.
mchasteen1 is offline   Reply With Quote
Old 06-01-2016, 02:55 AM   #72
j_motion
Drives: 14 BRZ Red premium
coool
Thanks for the solution.
Will find time to pull the 4th light to fix it up.
For now i just disconnect the brake light form splice to the rear tail light.
Ya i notice it a while back, but just didn't really pay much attention to it because it see so minor. Until i Drove behind a black truck and see my boomerang light turn on and off when step on and release broke.
But on the BRZ..
If you wire it up like how it is in my image.
The moment you step on brake.(well at least on my car)
The boomerang light and side marker will turn on. Also at the same time The clock display go blank.. and the air bag and driver seat sing on the right hand side of the clock will dim.
When you release the brake,
Clock display come back and other light not dimmed.
Boomerang light and side marker goes off.
Thex to Mchanteen1 one for the solution too
j_motion is offline   Reply With Quote
Old 06-22-2016, 10:32 PM   #73
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
going to try @Mchanteen1 method soon...
xDBOYx is offline   Reply With Quote
Old 06-26-2016, 12:52 PM   #74
T_Scott
T_Scott's Avatar
Drives: 2013 Raven FR-S
Hey all, I am looking into getting this reverse light, but I have a a few questions about it. What lights work with just the plug that comes with the reverse bar (if I don't wire anything)? I only really want the reverse lights and the V to glow when the headlights are on to match my Valenti tails. I don't care about the extra brake light.
Three pedals, six gears, and nothing but time.
T_Scott is offline   Reply With Quote
Old 06-26-2016, 12:55 PM   #75
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
If I remember correctly, the v and the triangle come on with parking lights and stay on with head lights, but then the triangle flashes with braking.
Most people rewire it so that the triangle turns off until braking so that the V is more distinct.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
blackfireball5 is offline   Reply With Quote
Old 06-28-2016, 04:04 PM   #76
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Wrote up a how-to, although its been discussed before. A lot of good info in the thread, but variances in photos etc makes it confusing.
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video
Video shows all three lighting variations that are typically used though.
The Following 4 Users Say Thank You to continuecrushing For This Useful Post:
czechm8 (06-28-2016), Maverick986 (08-16-2016), qitorr (08-22-2016), tato.valverde (06-29-2016)
Old 08-13-2016, 01:05 PM   #77
akiranakayama
Drives: 2013 Subaru BRZ Limited (CBS)
As a visual learner, I'm really heart broken that most of the pictures in the original post are now broken.
I do not like how the Valenti 4th brake lights function as they come. Solid -v- on with running/headlights and a red triangle with brakes (flashing or not flashing, I don't care) is what I prefer. That seems to be how everyone likes them to function.
2016 Scion FR-S
1991 Acura NSX
2012 Mazda Miata (Track)
2019 Triumph Bonneville Bobber
2007 Suzuki SV650 (Track)
akiranakayama is offline   Reply With Quote
Old 08-16-2016, 04:16 PM   #78
continuecrushing
I show how in the video here:
I have NOT had consistent luck with trying to keep the "flashing". But method 3 has been solid so far.
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 08-16-2016, 04:21 PM   #79
akiranakayama
Third option is also a very good solution! Any quirks to the third wiring method? Does the second method stop flashing after a while or something?
2016 Scion FR-S
1991 Acura NSX
Old 08-16-2016, 05:22 PM   #80
continuecrushing
the issue with the 2nd method is that for some reason, it doesn't always work on cars. But, its a "works or it doesnt" situation. So if you kinda wanted the flashing, you could always try it.
I THINK something is different between some of the lights (internally on the board), and so I ran into the issue of the "brake" light not lighting up (well, it does, but its very very dim).
The 3rd method has always worked, on every single unit I've tested/modified.
Old 08-16-2016, 08:25 PM   #81
akiranakayama
Well, at least there is a solid option! Thanks for making the guide. Will have to crack open my Valenti light soon and do some soldering.
2016 Scion FR-S
1991 Acura NSX
Old 08-16-2016, 08:36 PM   #82
continuecrushing
No prob! The other "electrical/light" guru and I were stumped-we would literally get different results with the 2nd method. We would bench test, and it would be fine. But install it, and issues. Something with ohms, resistance and phase of the moon (lol). It seems to be light specific however. I would modify 3-4 at a time, and only 1 would have the problem. But 25% is too much when we're shipping.
Old 08-21-2016, 08:08 PM   #83
NRXRaptor
I installed these and the only thing not working is the reverse lights. Help?
NRXRaptor is offline   Reply With Quote
Old 08-23-2016, 01:41 AM   #84
continuecrushing
Sounds like something got tweaked-trace the green/real wore from the connector to the light. If that's good, something inside the light got disconnected/wired wrong.
rear fog, valenti
Wiring BRZ rear fog light to only come on with front fogs Scenic Driver DIY (Do-It-Yourself) Guides 4 09-12-2015 09:36 AM
Valenti Japen LED Reverse Tailight USDM Wiring Furtive DIY (Do-It-Yourself) Guides 12 08-21-2015 09:31 AM
Valenti 3rd brake light wiring SPCorBUST Southern California 4 09-24-2013 11:57 AM
Valenti Tail Lamps and Tommy Kaira Rear Spoiler harajukukei Cosmetic Modification (Interior/Exterior/Lighting) 19 06-04-2013 07:01 PM
Alternate TRD Rear Bumper Possibilities Breeze Loo Cosmetic Modification (Interior/Exterior/Lighting) 3 05-06-2013 01:06 PM
