Old 10-01-2013, 08:28 AM   #71
MrSlay
Drives: Gx 460, FRS, Prius
Just logged a cold start and mine stays where its been set at 1.0. Drove about 100 miles on this current flash last night and IAM hasn't changed after the cold start this morning.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
MrSlay is offline   Reply With Quote
The Following User Says Thank You to MrSlay For This Useful Post:
feldy (10-01-2013)
Old 10-01-2013, 12:10 PM   #72
mad_sb
Drives: 2013 Asphalt FR-S
what is the initial value in the rom set too?
If it is set to 1.0 in the rom, it will reset to 1.0 so you may still be seeing a reset and not notice it. If you ever notice the IAM having worked down to a value lower than 1.0 then you can check again. Or set it lower than 1 in the rom and see if it persists after it works up.
Old 10-01-2013, 04:16 PM   #73
MrSlay
I have it set at one and it's never changed. Even during the long drives yesterday, just stays at 1.0 Going to drive the car hard tonight and see what happens.
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
Old 10-01-2013, 04:27 PM   #74
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
Here is mine from a drive home at lunch today. You can see that it was .94 whe car shut off and was there when I turned the key on. But it reset when I cranked the key.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 10-01-2013, 04:31 PM   #75
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Can a mod move this to the tuning section? @Sportsguy83 can you page them again?
Old 10-01-2013, 04:32 PM   #76
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Did you see any Knock Correction or Knock Learning Value changes or did those remain zero the entire time?
Old 10-01-2013, 04:38 PM   #77
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I would if i could, but paged them.
Old 10-01-2013, 05:56 PM   #78
MrSlay
The log this morning was just at idle, so no Knock Correction and not enough rpm to see any real difference in Knock Learning.
My Knock Correction Learning has never remained at zero. Below is a pic comparing a stock 2nd gear pull, to a 3rd gear that was done last night. The Knock Correction Learning curve is similar and the max variance in in correction is 1 even with the aggressive timing on e85.
Is everyone else seeing a similar curve?
15 FRS
12 Prius
12 ISF
15 Gx 460
My YouTube Channel
Old 10-02-2013, 03:40 PM   #79
mad_sb
Right, that's a good thing, but not what we are talking about here.
Try setting the initial IAM to .7 or .8 flash the rom, drive around letting it work up to 1.0. Shut off the car, start it up again the following day and then see if the IAM is still at 1.0 or dropped back to what you set the initial value to in the rom.
The Following User Says Thank You to mad_sb For This Useful Post:
MrSlay (10-03-2013)
Old 10-02-2013, 03:44 PM   #80
mad_sb
[quote=MrSlay;1244686]The log this morning was just at idle, so no Knock Correction and not enough rpm to see any real difference in Knock Learning.
The "curve" is equal to IAM * Ignition advance map for the most part. You will see some advance added and removed but you can't tell much of anything when the advance map is stock because it is all over the place.
MrSlay (10-03-2013)
Old 10-05-2013, 01:24 AM   #81
Circuit Motorsports
Circuit Motorsports's Avatar
Drives: 2013 Subaru BRZ
Send a message via AIM to Circuit Motorsports
After seeing this thread, I checked it out on our test BRZ premium (no push button). The IAM is persistent. This is EcuTek tuned.
Like mad_sb said earlier, having the car reset the IAM after each start is not how the Subaru knock system works. This is very much a Subaru ECU. Having the IAM reset after each start somewhat defeats the purpose of the system.
Why would you want the IAM to reset higher after a restart if the ecu had been seeing knock and had lowered the IAM to stop the knock? The IAM should always start where it left off and move up or down depending on how happy or unhappy the ecu is with regard to knock.
Sounds like the ECU is being reset after/during each startup, and may be a bug affecting only the FR-S.
I'll be tuning an FR-S tomorrow, I'll take note and post back.
-- Bob
Circuit Motorsports is offline   Reply With Quote
The Following 2 Users Say Thank You to Circuit Motorsports For This Useful Post:
feldy (10-05-2013), mad_sb (10-07-2013)
Old 10-05-2013, 01:47 AM   #82
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
FRS here. And IAM is definitely persistent.
Old 10-05-2013, 05:38 PM   #83
Circuit Motorsports
The FR-S I just tuned resets the IAM back to the default value upon every startup. The IAM rises to 1 within seconds of the first decent acceleration.
-- Bob
The Following User Says Thank You to Circuit Motorsports For This Useful Post:
mad_sb (10-07-2013)
Old 10-05-2013, 08:21 PM   #84
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
I've extensively logged, flashed (110 times!), and logged some more on my turbocharged FR-S over the last 20,000 miles of turboboostin', and the IAM has never reset itself. None of the cars I've seen or flashed personally has reset either, FR-S or BRZ.
AVOturboworld is offline   Reply With Quote
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 10:47 AM
Tein Street Advance 99c NR 86drift Australia Classifieds 0 05-23-2013 05:06 AM
Help NEEDED ASAP, Thanks in advance! FR_Soldier_77 Other Vehicles & General Automotive Discussions 9 03-20-2013 10:10 AM
YR-Advance ANREX Cosmetic Modification (Interior/Exterior/Lighting) 11 10-31-2012 09:08 AM
