Old 01-10-2015, 06:41 PM   #71
Fonzie517
Autocrosser
Drives: Asphalt 6-speed FR-S
Originally Posted by Brofessor View Post
So the standard 6 pin harness doesn't physically fit into the 8 pin harness size-wise at all - I'm confused about how re-pinning it will work? Wouldn't you have to also buy an 8 pin harness? Sorry if I'm just having a dense moment here.
It has been some time since I installed the Series 10 lights, so excuse me if my memory fails me. I removed the connectors from the OE headlights and pinned the wires from the new headlights into the OE plug. I left the plug and everything on the car side of that connection as it came from the factory.
Fonzie517 is offline   Reply With Quote
Old 01-12-2015, 09:15 AM   #72
Brofessor
Drives: 2015 Halo FR-S
I am having a lot of trouble removing the pins from the stock FRS headlight wiring harness - is there a trick to doing this? Or specific tools to do it?
Brofessor is offline   Reply With Quote
Old 01-17-2015, 10:03 AM   #73
dchan8
Drives: Toyota Celica
I want to confirm the series 10 wiring.
to simplify this, what color wires on car side harness connect to the wiring harness on the HID headlamp side?
can someone provide a simple color code?
dchan8 is offline   Reply With Quote
Old 04-12-2015, 07:54 PM   #74
dezmoondo
dezmoondo's Avatar
Drives: Whiteout FRS
to get the DRL to work, which white wire does the 12V has to be connected to. I am a little confused. I see two white wires from the 6 pin plug coming from the vehicle (passenger side). Driver side only has a one white wire
dezmoondo is offline   Reply With Quote
Old 03-17-2016, 10:55 PM   #75
steve4
Drives: FRS
Help? l cant get the DRL to turn on. Can someone advise on what I did wrong?
I removed the resistor and made a connection from both headlights
i tried connecting by cutting male harness from the resistor and connecting the DRL to the positive end (green wire assume to be live wire). But no success. what am i suppose to do with the negative end?
steve4 is offline   Reply With Quote
Old 03-17-2016, 11:22 PM   #76
NahumCC
Drives: 2013 FR-S 10 Series
I'm going over the wiring diagram right now and will provide you some information in a minute or so.
NahumCC is offline   Reply With Quote
Old 03-17-2016, 11:53 PM   #77
NahumCC
Never mind, I'm getting twisted up in the diagram. I'll try and read this thread later and put it together with the diagram.
Old 03-18-2016, 04:00 PM   #78
steve4
Drives: FRS
To clarify, what I did was leaving the female harness as-is on the car and cut the male harness from the resistor then hook both the DRL pin from the headlights together and connect to the positive side of the male harness. This is what I assume the OP means by tapping both to the live wire. But he didn't mention anything about the negative or grounding anything. I tried without grounding but no success.
Old 03-18-2016, 04:06 PM   #79
NahumCC
You have to ground it or there won't be any flow of electricity.
Sent from my SAMSUNG-SM-G870A using Tapatalk
Old 03-18-2016, 05:36 PM   #80
steve4
Drives: FRS
Thanks, but according to the OP's DIY how come they have nothing to ground. Does this mean that the negative wire from the male harness will be extended to the body of the car? (I'm assuming the positive side will have 2 wires going to each headlight and the negative will be connected to the body of the car?)
Old 03-18-2016, 06:38 PM   #81
NahumCC
I'm going to have to assume yes that the ground is extended because in your original setup the DRL shared the same ground as the high beam circuit but with less power applied via that resistor.
Now you're powering an entirely different circuit that has a separate grounding wire in its OEM install. If you haven't looked at the color wire diagram yet it's here in the DIY section for download. Take a look what held me up from answering last night, and still, is how the main body ECU plays into this when switching to the 10Series/Monogram setup.
Going back through here if you pinned your 6 pin connector like his pictures are shown then your LED is grounded. Have you taken a multimeter out and turn the car onto accessory power with the headlights on and tested to verify your getting 12 volts? You say you tapped a solid green wire but earlier in the thread someone mentioned a white-green striped wire they tapped. Is it possible you tapped the wrong wire? I'm also confused from reading where they are tapping that wire they run from the resistor to.
Did you pick up 10 series/monogram lights which are 6 pins in a 8 pin connector or the GT86 EDM spec with the 7 pins? This might make a difference to.
Old 03-18-2016, 09:10 PM   #82
steve4
Drives: FRS
I'm working with a GT86 JDM with 8pins, so the wire coloring is somewhat different and I pretty much improvised the repin part by trying out each pin . I'm currently ordering a voltmeter online so haven't tested but I did try reversing to the other black wire instead with no luck. On the resistor harness as mentioned on previous post, only has a green wire and a black wire no green/white wire. Also I was somewhat confused with which wire to tap; according to their wording is to tap the live wire of the resistor harness? I wired the DRL as they instructed on page 2 of this thread only difference is instead of connecting directly to the harness, I cut the resistor out first and connecting to the wires where the harness used to be (example on my second photo).
Is there other way to connect the DRL if this doesn't work
Old 03-18-2016, 10:48 PM   #83
NahumCC
Well let me tell you that the wiring diagram doesn't make it any less confusing deciphering the 10 series and base being laid on top of each other lol.
So unfortunately the FR-S diagrams won't show me the GT86 which have 7 pins going into them.
What your base series shows is that the OEM has 4 wires running into your headlamp assemblies from the car harness. Now here is where things get funny and why I'm confused by what they are calling the hot side of the resistor circuit in this thread
Looking at the diagrams the resistor looks like its in line with the flow after the high beam bulb and that both the resistor and high beam ground are shared. It's just a relay that determines which path the flow is going to...resistor wired ground for lower output of DRL and non resisted ground for high beam at full output.
If I've read the diagram correctly this is how I think the power is flowing for your stock headlights and may explain what you need to do with the resistor.
DRL's
When you've got the power on and lights on auto and drop the E-brake pin 21 on the main body ECU is left open allowing the resistor to be part of the ground circuit for the DRL.
The main body ECU then supplies 12+ via pin 23 to the DIM relay grounding out via pins 11 and 3 on the main body ECU which causes it to close its contact with 12+ from the battery circuit to the high beam fuses and grounds out via the resistor to provide the lower output DRL.
Low beams:
When you select low beams or the car does based on light level outside then the main body ECU grounds out pin 21 energizing the circuit on the DRL relay to switch over to ground without the resistor engaged.
The main body ECU then cuts the 12+ via pin 23 leaving the DIM relay unenergized diverting no power to the high beam. The power that was going to the high beam fuses instead finds it was to the low beam fuses as now the main body ECU has supplied 12+ to pin 2 which completes the circuit with the Headlamp Relay energizing it and closing the circuit to the low beam fuses.
High beams:
When you engage the high beams the main body ECU leaves the DRL relay energized cutting the resistor out and takes the 12+ from pin 2 of the main body ECU and sends it back to pin 23.
Personally, having seen the wiring for the resistor being inline with ground I don't understand why you wouldn't just jump the pins together in the car side of the harness for the resistor instead of running all this extra wire. Wish I had the diagram for the 7 pin's GT86 lights to give you a better answer on how to move forward. This is also independent of any thought toward programming of the main body ecu and if they differ between the cars. I think there would have to be for the car to allow power all the time on the low beam circuit for the HID vs. how a halogen set up shuts of the low beam halogen when a high beam halogen is turned on.
Old 03-25-2016, 03:11 PM   #84
steve4
Drives: FRS
Does anyone know if it works if I hook the drl to the wire behind the cigarette lighter thing in the glove compartment or maybe the ignition wire? Since the resistor is not working for me
WTT: FR-S headlamps for BRZ Nothing Southeast 2 03-30-2013 06:41 AM
Auto-Off Headlamps nktech Scion FR-S / Toyota 86 GT86 General Forum 12 12-10-2012 09:51 AM
Purple/Blue headlamps BMWDavid Other Vehicles & General Automotive Discussions 0 11-24-2012 01:40 PM
Installing GT86 AC unit? SupraLove Cosmetic Modification (Interior/Exterior/Lighting) 10 09-07-2012 02:08 PM
limited 86 headlamps SuperDave FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 08-04-2012 03:41 AM
