Old 03-05-2015, 11:15 PM   #71
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Astroboy View Post
So what are going to do? Switch to a different grade?
I don't know yet...hoping some oil experts may be able to comment on the report and provide suggestions.
Fizz is offline   Reply With Quote
Old 03-19-2015, 03:32 PM   #72
Astroboy
Astroboy's Avatar
Drives: None
Any luck?
Astroboy is offline   Reply With Quote
Old 03-19-2015, 03:38 PM   #73
Koa
are you 2000% sure your turbo install and tune is up to par before determining whether or not the oil is to blame for most of that?
Old 03-19-2015, 09:08 PM   #74
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
I'm running a Sprintex kit, not turbocharged. Anyway I've checked and everything is good. The silicone levels are due to dirty air filter so I've replaced it. Fuel dilution was only minor, and likely caused when I was on a pretty rich (off the shelf) tune for a short period. The elevated oxidation is common when using ester based oils such as the Redline I was on. Apart from that all the other areas looked normal....and even the TBN was still in the healthy range so that's good.
Anyway I've replaced the oil to Penrite Racing 5w30 which has high zinc for added protection. Since I don't track the car I was advised that it's not necessary to go any higher than 30 weight. Will do another UOA in around 3000 miles time to see how it copes.
Old 03-19-2015, 11:06 PM   #75
Flashfire88
Flashfire88's Avatar
Drives: Limited Silver
Currently running 5W-30 of Castrol Edge Dexos Approved for street/spirited driving, track days I switch to 10W-40 to compensate for oil pressure drops.
Flashfire88 is offline   Reply With Quote
Old 03-20-2015, 09:33 AM   #76
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
how many ppl running a higher viscosity oil to maintain oil pressure at high temps is running an oil cooler?? if your running a cooler why is there a need of a xW/30-40 etc??
DAN_BRZ is offline   Reply With Quote
Old 05-14-2015, 05:20 PM   #77
Astroboy
Astroboy's Avatar
Drives: None
Should I invest in an oil cooler if my oil temp never exceeds past 104c? I usually
Lay off the throttle when I see it go to 104
Old 05-23-2015, 10:45 PM   #78
Astroboy
Astroboy's Avatar
Drives: None
How many miles on the 5w30 so far
Old 08-29-2015, 08:11 PM   #79
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
How is this oil holding up with the Penrite? Did your engine oxidation, etc. go away?
Can we get an answer to this?
@Astroboy did you end up getting an oil cooler and/or did you go with 5W30 oil? My Toyota manual shows no mention of 5W30, but I saw above apparently the Subaru manual does. I am installing my FI kit soon and I am looking to switch the oil at the same time. Trying to get an idea of the best oil type to choose.
Chad86 is offline   Reply With Quote
Old 08-29-2015, 08:50 PM   #80
Astroboy
Astroboy's Avatar
Drives: None
I switched to a 5w30 but have read by avo that a good 0w20 oil should be fine. I use motul and now have an oil cooler by avo to go with my avo kit. Avo-astic
Sent from my LG-D850 using Tapatalk
Old 08-30-2015, 11:21 AM   #81
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
5w30 Genuine Subaru Synthetic Oil - Every 3500 miles. Oil temp are very solid without oil cooler in south Florida.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 08-30-2015, 02:57 PM   #82
Astroboy
Astroboy's Avatar
Drives: None
How many miles on the charger
Old 08-30-2015, 03:56 PM   #83
Jonde875
Drives: GT86
Im using now Toyota 5W-30 C2 but thinking change to Castrol EDGE Professional 0W-30 C3 Titanium FST.
Jonde875 is offline   Reply With Quote
Old 08-30-2015, 08:27 PM   #84
R2RO
R2RO's Avatar
Drives: 2013 FR-S, 2013 FR-S(2JZ Build)
I'm using Motul 8100 0w20
R2RO is offline   Reply With Quote
Best oil for turbo engine whitefrs Forced Induction 36 10-09-2014 02:45 PM
Engine Noise on Turbo FRS whitefrs Forced Induction 23 04-18-2013 10:30 AM
1.6L DI TURBO ENGINE quik1987 BRZ First-Gen (2012+) — General Topics 39 11-30-2011 06:01 PM
FT-86 / FR-S engine will be Toyota 2l turbo!! Slide Engine, Exhaust, Transmission 114 07-07-2011 11:58 PM
Do you want a turbo engine for the FT-86? Read here Ramo BRZ First-Gen (2012+) — General Topics 86 06-23-2011 09:39 PM
