Old 07-19-2013, 03:29 PM   #71
mad_sb
Drives: 2013 Asphalt FR-S
Originally Posted by Gen View Post
Appreciate it... I haven't a clue what could be wrong. Everything seems to be in order aside from the dyno.
Compression check done?
Leak down test?
Is the turbo internally gated?
Did you check the IC inlet for debris that may have gotten stock during shipping / manufacturing?
I understand what your saying about the maf reading, but given the high fuel trims i assumed the maf scaling was stock. And based on the stock maf scale table it is fairly close to stock if not stock:
4.297v 167.6g/s
4.492v 194.4g/s
Anyway, if the motor is sound, and the tuner is good, you might just need to turn up the boost and re tune. Might get a different tuner to re tune it as well and see how that goes.
Old 07-19-2013, 04:00 PM   #72
Gen
Drives: Scion FR-S
Leak down test?
4.297v 167.6g/s
4.492v 194.4g/s
When I've mentioned compression and leak down tests, the general reaction I have received is one of skepticism. Do you feel it is worth looking in to?
Gen is offline   Reply With Quote
Old 07-19-2013, 08:47 PM   #73
mad_sb
If everything else checks out and your still down on power then it's either low compression or a weak tune.
If your only down 10 - 15 whp from what other are making with the same mods, same tuner, same dyno then i would not worry about it and just do more supporting mods (free up the exhaust) and re tune with a couple psi more boost if it will take it.
If your down more than that then it's time to check the health of the internals and a leak down is probably the first step. Hard to say when spectating over the internet if you really are down on power or if people are just assuming you are etc etc....
Have the plugs ever been changed?
Old 07-19-2013, 08:58 PM   #74
Gen
Drives: Scion FR-S
Stock plugs. They haven't been touched
Old 07-20-2013, 12:40 AM   #75
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Think I did something wrong.... 1121 HP and 964 torque. I figured out my problem; my car is so powerful the dyno just can't accurately read it. I'll tinker around with it
What you did wrong was spend any time using virtual dyno, the Subaru AWD crowd's favorite bragging tool.
Old 07-20-2013, 07:11 AM   #76
mad_sb
BTW, you can use the XML 2forme made for virtual dyno car definition
Old 07-20-2013, 07:45 AM   #77
Calum
That Guy
Drives: 2013 asphalt FRS MT
Leak down test?
4.297v 167.6g/s
4.492v 194.4g/s
How would go about doing a leak down test on this engine? I'm guessing the engine would have to be lifted.
Old 07-20-2013, 12:07 PM   #78
mad_sb
No Clue lol... I do know a leak down is a better measure of health than a compression check as it will help spot issues with valves not fully seating etc.
Old 07-20-2013, 12:36 PM   #79
Calum
That Guy
Agreed, I just don't know how I'd do one on this engine.
Old 07-20-2013, 04:45 PM   #80
jamesm
i didn't read back through the whole thread, but you've run this on more than one dyno to confirm the numbers, right?
Old 07-20-2013, 05:25 PM   #81
Gen
Drives: Scion FR-S
Mustang and dyno dynamics.
The Following User Says Thank You to Gen For This Useful Post:
jamesm (07-20-2013)
Old 07-22-2013, 10:26 AM   #82
King Tut
NASA SpecE30 Racer
King Tut's Avatar
No different then changing the plugs. You disconnect the exhaust and motor mounts (there are some other things as well) and raise the engine up to get the spark plug holes above the frame rails. It really isn't that bad.
Old 07-22-2013, 04:35 PM   #83
Calum
That Guy
Coming from an engine where I could gap the plugs while watching TV, run out during a commerical & change them, and still be back inside before the show started again, that still seems pretty involved for a plug change. But it's certainly worth it.
Old 07-31-2013, 04:11 PM   #84
Gen
Drives: Scion FR-S
FR-S with the Avo turbo just came in at 198 on the same dyno dynamics dyno. Only thing I can say is that I think my car is fine, just need to adjust expectations for CA gas and the inflated dynojet numbers.
whataboutbob (07-31-2013)
86 Dyno results Anban AFRICA 18 01-14-2014 06:54 AM
Dyno Compilation - dyno testing results and recommendations Illusive Engine, Exhaust, Transmission 82 02-08-2013 07:00 PM
Compilation of Dyno results somewhere??? Scooby South Engine, Exhaust, Transmission 3 01-08-2013 06:51 PM
Pocket Dyno App Results CBR600RR Scion FR-S / Toyota 86 GT86 General Forum 14 09-12-2012 10:45 PM
My Fr-s Dyno Results!! Surprising if you ask me track_warrior Engine, Exhaust, Transmission 36 07-02-2012 10:15 PM
