#71 |
Drives: Ap2
#72 | |
Drives: Hyper Blue BRZ
does anyone have the carson toyota part number for ordering ?
#73 |
Driver
Drives: 16 Subaru BRZ
did anyone else have a slight door misalignment? installed mine yesterday and my driver side door is slightly off than normal compared to my passenger side door.
BRZ Build Thread
See you space cowboy... |
#74 |
Drives: 2013 Scion FRS
#75 |
Drives: '15 Halo Scion FRS, 1999 Saturn SC2
My driver side door came out perfect, but my passenger door is slightly "off". I have not found a solution yet. Since it's on the passenger side I don't notice it every day, so it doesn't bother me as much. I'd be very happy to hear about a solution, though.
2015 Halo Scion FR-S 6MT new w/TRD exhaust, cold air intake, quick shifter, sway bars, lowering springs, & brake pads. Since then, TRD door braces, strut tower bar, & battery tie-down, Motul fluids in trans/diff & brakes, GrimmSpeed master cylinder brace, Stoptech stainless brakelines, OpenFlash Header 3 w/overpipe, OpenFlash Tablet on E85
#76 |
ಠ_ಠ
Drives: 860 SansOverspray
Didn't see it mentioned in the thread.
The Torx are T-40, if you don't already have a set you can get the right one. |
#77 |
Drives: 2005 SLK350, 2015 RS 1.0 FRS
Just got these not too long ago. Having trouble with the body side striker bolts. Have tried using 3/4" ratchet with socket bits, bits with breaker, and even a manual impact driver...But with no luck. Anyone had to use an electric impact driver to get these bolts out?
#78 |
Drives: 2016 Subaru BRZ
I had to use an electric impact, managed to get them out but stripped one in the process, not a big deal since I won't need them again. Passenger side door is slightly off with alignment but I don't want to go through the hassle of trying to get it right.
#79 | |
Proud of BOXER
Drives: Subaru Boxer
Hardly seems worth it.
#80 |
Drives: 2015 FR-S
Somebody needs to make it without the TRD logo and that will knock it's price in half. Then just say it's to make the car door close nicer/quiter
and not say it's a performance piece and that should knock it down another half. Then we will be where it should be in the first place, maybe $30-40. I'm tempted to do like somebody else said in here and just make a DIY wedge/shim. I mean if I am reeaallly bored one day since this is really stretching it for "performance". It's only after watching that video of the car door kind of moving a little that makes this sort of an attractive mod but in reality we all know that there is no way a human driving inside the vehicle can detect if that thing was on the door or not. It's like getting a 5 hp bump from an air filter and saying you can feel it on your butt dyno. |
#81 |
StreetKart
Drives: 2014 Scion FR-S Monogram
if you used an impact you did it entirely wrong. the proper sized bit on a 3/8" ratched pulled the bolts out with relative ease.
You could easily have a DIY version of the part but it's not going to be a nicely finished part that is an oem bolton replacement made by the same people who make a ton of other parts for the car. If you do something like a real 10-point cage it's a pointless piece. I'm entirely happy with mine on my daily driver, it makes the car feel more premium and helped get rid of some creaks and pops that my poor 77k miles chassis had.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
#82 |
Drives: 10 Series
#83 |
Drives: brz
please link to video?
#84 | |
Drives: brz
not better handling per se...
not better handling but driver input requirements will go down due to better chassis response, sort of the same thing but not really. not better handling due to better tires or better suspension, it's an improvement at the chassis so that the chassis responds better at the driver input level, if Toyota has convinced me they've done their research and I'm at the end/beginning of my project car mod cycle and had $200 in the budget I guess I would get these; we see and know flexing does happen, these reduce that flexing. |
| LED Door Sill? | joergasm | Cosmetic Modification (Interior/Exterior/Lighting) | 46 | 06-17-2014 07:37 PM |
| 8's in the door | cruzinbill | Electronics | Audio | NAV | Infotainment | 2 | 01-26-2013 05:10 PM |
| fs: TRD door stabilizers | narfy | Canada Classifieds | 12 | 11-15-2012 11:57 PM |
| out the door pricing | wallace03 | BRZ First-Gen (2012+) — General Topics | 6 | 06-12-2012 01:30 PM |
