Old 11-25-2014, 10:38 PM   #43
sittinSideways
sittinSideways's Avatar
Drives: '13 Firestorm FRS
These are made by TRD. They don't release parts unless they serve a purpose. The above videos do a pretty good job of proving what purpose they serve.
sittinSideways is offline   Reply With Quote
Old 11-28-2014, 12:28 PM   #44
xxBrun0xx
xxBrun0xx's Avatar
Drives: 2014 WRB BRZ Limited
Oh really?
xxBrun0xx is offline   Reply With Quote
The Following User Says Thank You to xxBrun0xx For This Useful Post:
wootwoot (11-28-2014)
Old 11-30-2014, 01:26 AM   #45
sittinSideways
Originally Posted by xxBrun0xx View Post
Oh really?
Yes really.
TRD claims no performance advantage from that gas filler cap.
But TRD does claim a performance improvement from the door stabilizers, so you best believe it does improve it. Otherwise why would they have bothered to develop it if it was just for looks, only to stick it in an area that is covered 99% of the time (unlike the always exposed gas cap). Just look at the videos posted above; you can clearly see the flex in doors.
The Following 6 Users Say Thank You to sittinSideways For This Useful Post:
chaoskaze (12-23-2014), Choco (11-10-2015), Tristor (03-05-2019), xxBrun0xx (12-01-2014), yo joshman (06-18-2015), YouShallKnow (01-30-2015)
Old 12-17-2014, 06:08 PM   #46
serialk11r
Drives: '06 AM V8V Coupe
Random question, does anyone happen to know if Toyota cars all use the same door latches? I want a set of these for my MR2 but the ones listed on the internet as fitting the MR2 cost more for some odd reason. If possible I'd like to get the ones for the FRS from Japanparts for 130 USD. Steep price but considering that my car stripped a door latch assembly's bolt threads from door flex, it just might do the trick. The pictures all look exactly the same to me so I get the feeling this is probably the case...
Old 12-22-2014, 09:24 PM   #47
gutbomb
Just make a shim yourself
gutbomb is offline   Reply With Quote
Old 01-29-2015, 04:53 PM   #48
YouShallKnow
Drives: Man
Send a message via ICQ to YouShallKnow Send a message via AIM to YouShallKnow Send a message via Yahoo to YouShallKnow
So this was a nightmare install for me and I wanted to share my experience for anyone else about these bastards.
As everyone says, the only hard part is getting the damned door latch bolts out, which are glued in with blue loctite.
I bought an impact driver like in op's instructions just for this job. It did absolutely nothing. Maybe I suck using it, I don't know, but I couldn't do shit with it. I hammered away at that driver and got absolutely nothing.
I ended up putting the bits in my electric impact wrench and trying to get them off that way.
It was partially successful. I managed to get the first three bolts out, but only by destroying all 3 of my Phillips head impact screwdriver bit.
I was left with one bolt still in and had to improvise. I tried hammering the flat head bits into the bolt, then using the impact driver, and nothing.
Eventually I just bought the biggest phillips screw driver I could find, attached some vice grips for leverage, and just muscled that bitch out.
If I had to do it over again, I would have just done this from the beginning.
I also had issues tightening the replacement torx bolts since the loctite was in the grooves. It takes a lot of torque to get passed all the loctite in the threads.
If you run into problems like I did, some words of wisdom:
- Don't use the impact wrench, it's way too much torque and if you're lucky, you'll just destroy your bit and bolt while loosening it. If you're unlucky, you'll accomplish nothing and have a really good chance of slipping and scuffing your paint.
- If you have just one bolt stuck, put the microfiber towel under the hanging old bracket so you don't mess up your paint while you work the last bolt. I failed to do this and now have some unslightly scuffs near my new TRD bling.
- If you have problems with door alignment after install, don't worry. You can almost certainly fix it. The piece of metal that you screw the torx bolts into that's inside the door is pretty flexible; it's easy to adjust it (I used a screwdriver in the door latch to twist it back to shape after I deformed it trying to get those loctite bolts out). Also, make sure that the new latch is pushed as far into the frame (towards the interior) as possible when you tighten it down, if it's sitting further out, it may make your doors not flush.
Good luck, the good news is it's a great install and if you know anything about how this car feels without them the improvement is obvious with hard cornering, MUCH STIFFER.
YouShallKnow is offline   Reply With Quote
The Following 4 Users Say Thank You to YouShallKnow For This Useful Post:
Choco (11-10-2015), Gums (02-03-2015), Hyper4mance2k (01-30-2015), Tristor (03-05-2019)
Old 02-04-2015, 08:57 AM   #49
crustol
Drives: Scion FR-S Raven
Regular places sold these for $250, but since I found out that I could get them for ~$140 including shipping, I decided to pull the trigger.
The installation:
I also tried to use an impact driver to loosen the bolts, and was unsuccessful. To be fair, it was my first time using an impact driver so maybe I wasn't using it properly.
I was successful using a regular 3/8 ratchet with a phillips bit. It wasn't that difficult.
The most difficult operation IMO was installing the torx bolt into the striker. It was cold outside, I had no gloves, you have to hold the damn slide all the way back throughout the entire process. The instructions stated to be careful of not letting the slide go while installing the bolts since you could damage the finish on it... I chipped some of that finish off so you can see a black spot on the edge.
Result:
In my case, the driver's side door seems to require more force to close now. Passenger side, not that different. Performance wise, didn't feel a lot different, but wasn't expecting night and day difference anyway.
crustol is offline   Reply With Quote
The Following User Says Thank You to crustol For This Useful Post:
YouShallKnow (02-05-2015)
Old 02-04-2015, 10:08 AM   #50
misterfly
Drives: Toyota 86 2017
Where do you find it at this price ??
The installation:
Result:
misterfly is offline   Reply With Quote
Old 02-05-2015, 10:16 AM   #51
crustol
You can google "buy ZN6 ドアスタビライザー"
I bought mine from an individual seller, so proceed at your own risk.
Old 02-05-2015, 01:51 PM   #52
YouShallKnow
Drives: Man
Japanparts has them for even cheaper.
https://www.japanparts.com/parts/detail/40799
Old 02-05-2015, 03:14 PM   #53
Timmy_Jones
Spun
Drives: 23' Supra
Much stiffer? How was this measured?
Timmy_Jones is offline   Reply With Quote
Old 02-05-2015, 03:48 PM   #54
YouShallKnow
Drives: Man
Butt dyno
The Following User Says Thank You to YouShallKnow For This Useful Post:
zlegend (03-22-2015)
Old 02-05-2015, 06:10 PM   #55
JB86'd
JB86'd's Avatar
Drives: JAWS
Butt dyno
It was much stiffer in his butt dyno.
JB86'd is offline   Reply With Quote
Old 02-05-2015, 06:56 PM   #56
YouShallKnow
Drives: Man
My butt dyno loves it stiff.
The Following 2 Users Say Thank You to YouShallKnow For This Useful Post:
juliog (03-21-2015), zlegend (03-22-2015)
LED Door Sill? joergasm Cosmetic Modification (Interior/Exterior/Lighting) 46 06-17-2014 07:37 PM
8's in the door cruzinbill Electronics | Audio | NAV | Infotainment 2 01-26-2013 05:10 PM
fs: TRD door stabilizers narfy Canada Classifieds 12 11-15-2012 11:57 PM
out the door pricing wallace03 BRZ First-Gen (2012+) — General Topics 6 06-12-2012 01:30 PM
