| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#71 |
Drives: SUBARU BRZ Limited
Toyota GT 86 Traction Control Demonstration
[ame="http://www.youtube.com/watch?v=j8qggahGNH0"]Toyota GT 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame] |
| The Following User Says Thank You to brzltd For This Useful Post: | TSY (08-26-2012) |
#72 |
Sarcastic SOB
I is resenfull you say that. Lotsa FR-S owners is edutated.
#73 |
Registered you sir
Drives: 99 impreza coupe
#74 |
Drives: CBS BRZ Limited 6MT
Good thing I don't plan on turning it off when there's a torrential downpour on a slick surface?
Back in (Crystal) Black.
| The Following User Says Thank You to Zadkiel For This Useful Post: | SuperDave (08-26-2012) |
#75 |
Drives: WRB MT-BRZ LMTD
So I went and redline the car last night as I entered the highway, first gear then clutch in to 2nd gear... boom! Traction control light kept flashing and prevented me from accelerating any further.
BYE: WRB MT-BRZ LMTD
Drove the car off the lot at 8/6/12 @ 8:06 PM Traded for Black 2013 Camaro 2SS RS |
#76 |
Drives: 13 BRZ - 90 Miata - 07 FXT -05 Mini
My BRZ isn't used as a daily driver and I never commute to work in it, the car (my Miata) I usually commute in is RWD with no stability control, traction control, or ABS. When I drive the BRZ I'm out to have fun on the roads, or I'm driving it somewhere (autocross) to have fun, but I don't take unnecessary chances or put anyone elses life in danger. If the roads are dry every thing gets turned off as soon as I remember to do it, if the roads are wet, I leave traction and stability control on.
Been driving for 26 years, owned 20+ cars (about half RWD), been autocrossing for 13 years, this is my first car with stability control, and only my 3rd car with any sort of traction control. If I had my choice I'd prefer to be able to buy a new car with no traction control, stability control, airbags, TPMS, and ABS would be user-defeatable with a switch.
17x7 Kosei K1-TS w/ 215/45-17 Dunlop Star Specs
Nameless Track Pipe - Strano front sway bar |
#77 |
Drives: 2013 BRZ Limited SWP
My apologies. Yoo'r rite.
Past Subarus: 08 STI, 05 Legacy GT, 98 Legacy L wagon, 97 SVX LSi
Daily Driver: 2013 Acura MDX |
#78 | |
![]() But seriously, the TCS kicking in was probably because you were about to spin your rear wheels and you wouldn't be accelerating anyway. Either that or because you hit the rev limiter.
#79 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
In sport mode, you shouldn't see the lights unless you're driving like a jackass and something is actually slipping/sliding. In other words, a situation where you are liable for a stunting or careless driving ticket. There is no excuse for that on a public street (not saying I haven't done it - but I'm ready to pay as well...) My tune might change this winter - we'll see. |
| The Following User Says Thank You to Khyron686 For This Useful Post: | SuperDave (08-26-2012) |
#80 |
Drifter-Wannabe
#81 |
Drives: Acura, Subaru BRZ - GBS MT Limited
Nope, plain simple common sense. That's why it is called an accident. Something happened you did not expect and now it is time to pay the piper. I only hope when some of the larger ego's mess up that no one has to pay the price with an injury or worse.
I am just saying that you reduce the odds of something unexpected causing an issue with the nannies engaged, even if your name was Stirling Moss. Good luck. |
#82 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I just want to add the VSC and ABS system has absolutely no idea what to do ON TRACK if you leave it in Sport mode and have actual sticky tires mounted....very annoying having ABS going off (or more precisely trying to go off while not really doing anything but pumping the pedals for effect only because the tires have at no point come close to loosing grip...) and engine cutting out a little screwing up corner exit speeds. With everything off the car brakes better and handles better. Does the same thing on the street to a much much lesser extent. But there is a difference you can feel between everything off and the systems on if you are in tune with the chassis and it has nothing to do with being even remotely close to driving recklessly on the road. It has everything to do with how the car is communicating with you... I want as free, and pure a communication from the car as possible verses artificial barrier's/filters which take some of it's soul/character away. It is a tangible difference you can feel after taking you first turn from a stop...and is the difference between being one with the car and just driving the car.
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
| The Following User Says Thank You to Vracer111 For This Useful Post: | neutral (08-25-2012) |
#83 |
I think because it spun. I was in 2nd gear just after shifting when the TCS light came on. I thought it was the CEL light at first and scared the crap outta me.
#84 |
Drives: 4 wheels
So for everybody except for 25 Year Driving Instructor Guy, this should be the most relevant statement. If you're driving around with everything on and the nanny intervenes, then you were most likely over-driving. Sure, you probably wouldn't have crashed, but you also were not driving optimally...try taking that corner again without triggering VSC. If you feel that the electronic aids are an insult to your Driving God Ego, then think of them as a cup full of water that makes you drive just like Takumi.
| The Following 2 Users Say Thank You to bucket For This Useful Post: | michaelahess (08-27-2012), TSY (08-26-2012) |
| Is this idle noise normal? | robo_robb | Engine, Exhaust, Transmission | 288 | 01-25-2022 10:40 AM |
| Vsc sport mode and trac off | RWD-boxer | Engine, Exhaust, Transmission | 94 | 02-25-2020 10:23 PM |
| Scion goes normal | terrypm | Other Vehicles & General Automotive Discussions | 21 | 05-02-2012 11:16 AM |
| Question about VSC and Trac? | Liquidsnake | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 04-24-2012 12:24 AM |
| G-sport FT-86 driving during GT5 | dalli | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 12 | 10-17-2010 04:16 AM |
