| GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#71 | |
If the latter, I'd certainly hope you have a more open mind. The DTC's only real selling point is price (up front). |
#72 |
Drives: '12 C63 P31, '23 GRC
I run XP10s on my C63 and I think (?) they've been good to me. I had heat dissipation issues first time at VIR and while I didn't experience pad fade, the end result was repeated boiling brake fluid, baked my piston seals and destroyed the rotors. Used up around half the thickness of the pads. (This was with 35° ambient weather)
Went back in February with the same pads but better rotors, removed rotor heat shields (prob should have done that first go around!) silicon piston seals and Ti shims for the pads. Much better results. ABS would occasionally engage (esp after some jackwagon spilled oil on the front straight). I was tracking with stability and traction control disengaged. (all comments above are in reference to the front brakes. Rears were fine.)
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
| Brake pads to swap between for DD and Track Days | jim985 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 12-25-2020 08:12 PM |
| Brake compound for Track Days | fer3d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-31-2018 08:47 AM |
| Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
| NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days | 86_Insider | Brakes, Suspension, Chassis | 1 | 09-26-2013 01:39 AM |
| Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
