#71 |
Drives: 2013 Raven Black FRS
Working on a kit on my car right now
#72 |
Drives: 05 Ford F150 Scrow
How about using something like this oil filter relocation with T-Stat.
#73 |
#74 | |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
20 minute session in Florida heat is hell hahah Sebring, nor I, were kind to this innocent beast :P
#75 |
Drives: Scion FRS
The weather for the next few weeks is going to be 100+ degrees and usually 50% humidity....
And i have some track days coming up if you need testers
#76 | |
Drives: 2015 GTI
But getting back on topic... I recommend the B&M as it has a cold temp bypass that is based on the viscosity of the fluid (Lower temp, thicker fluid) which helps if you live in a place that gets snow/gets really cold. I picked up a 13,000 BTU B&M for around $50. came with hoses and everything. |
#77 |
Drives: FRS
Can anyone think of any particular reason why an oil cooler would be a bad upgrade on a daily driver? I know it won't be needed for trips to the store or whatever. But I also plan to do a track day here and there... Just trying to help keep the car healthy with some preventative medicine. Opinions welcome.
#78 |
Drives: Subaru BRZ
The only problem is that your oil may take longer to get to normal operating temp (180 - 220 degrees F) depending on the sandwich plate you use. I had a 370Z with a small added oil cooler and in cool weather at times it wouldn't reach 180 at all. In the winter, many of us added a plate in front of the cooler to make it less efficient to get the temp higher.
#79 | |
Drives: 2015 GTI
This is true. However, a simple solution is to use cardboard and block off the oil cooler. :P
2013 GTI - Gone
2015 GTI |
#80 |
Drives: DGM BRZ, MR-S 3.5L V6 swap (sold)
or just use a thermostatic sandwich plate.
#81 |
#82 |
Drives: Subaru BRZ
On my 370Z I used a thermostatic sandwich plate with a 180 degree thermostat but it still had trouble getting up to 180. The reason being that this particular type of thermostat had an oil bypass and was never completely closed.
#83 |
Drives: 2013 Scion FR-S Raven
![]() Does anyone have a part number for that spacer only? The one to the right, the one in the clear bags below?
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
#84 | |
http://www.rhdjapan.com/trust-greddy...-zn6-zc6-68834 |
| Greddy oil cooler coming soon | DIG1992 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 11 | 08-20-2012 12:02 AM |
| Tomzilla's "That feeling when your car is far cooler than you" BRZ thread. | Tomzilla | Member's Car Journals | 1 | 06-19-2012 12:10 PM |
| Greddy Oil and Diff Cooler | pdreams | Engine, Exhaust, Transmission | 3 | 06-13-2012 08:41 PM |
| Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
