#71 | |
Drives: 2015 BRZ
#72 |
Drives: 2016 Subaru BRZ
I am in the process of installing them right now, just got my car up on jack stands. I will be done and aligned by Saturday afternoon if all goes well. Aiming for -1.5 front, -1.0 rear with zero toe. Only have camber bolts for the bottom hole on the front struts, don't want to mix and match a 14mm bolt into the top 16mm hole for more camber so I will be happy with -1.5 in the front.
| The Following User Says Thank You to Trueweltall For This Useful Post: | Vital (07-26-2018) |
#73 | |
Drives: 2015 BRZ
#74 |
Ran into a problem, I don't have a pass through torque wrench so I can't tighten down the top nut correctly.
I have SPC lower control arms getting install too. No crows foot either. Edit: Kind of ghetto torqued the top nut. Put the LCA on, jacked it up some to put load on it. Then I got a long pipe and just kept tightening the top nut while holding the allen wrench still, every so often I checked with my torque wrench to see if it would turn and repeated that until I got a click. ![]() Never forget those torque values now! Seriously, not sure why I didn't do this sooner. Last edited by Trueweltall; 07-27-2018 at 11:39 AM. |
| The Following 5 Users Say Thank You to Trueweltall For This Useful Post: | Lincoln Logs (07-27-2018), R2 (07-27-2018), Racecomp Engineering (07-27-2018), Tristor (09-08-2018), Vital (07-27-2018) |
#75 |
Decided to compress a front strut before I even put anything on it, a big ring of oil was left on the strut rod, honestly I don't know if it's because its brand new or because it's blown. Haven't touched the strut rod on it. The rod goes back out like normal. IDK.
Edit: I have lost a top hat to chassis nut(M8x1.25 flange nut), engine ate it. Took off the engine plates and did not find it. I have looked all around the engine bay. So frustrated, I am done for today. Last edited by Trueweltall; 07-28-2018 at 01:32 PM. |
#76 | |
#77 | |
The OEM crash bolts for the upper hole are the bottom bolts, so there's no safety concerns about running them.
#78 |
Finished the install, lowered the car, drove it 3 houses down and realized I forgot to torque down the front lug nuts. Walked back to my house in the rain, grabbed the torque wrench and got them torqued down. My alignment is so off I can't even give you an impression yet, the car rides so wonkey right now it's like riding over different sized speed bumps on each corner. I am sure that's because I switched out the rear LCA's for adjustable SPC's on top of lowering it 0.59 inches. I will get it aligned within the next 7 days and give an update then.
I measured each corner and I am at around 0.5 inches lower than stock. F: 26 and 1/4" to 25 3/4" R: 26 and 1/2" to 26 |
| The Following User Says Thank You to Trueweltall For This Useful Post: | TachyonBomb (07-30-2018) |
#79 |
Drives: 2015 BRZ
Got any pics of your car with them installed?
| The Following User Says Thank You to Vital For This Useful Post: | TachyonBomb (07-30-2018) |
#80 |
Think my rear toe and camber is off? (LOL) It's just as bad on the other side. Something like -4 with the worst toe in.
#81 |
Drives: 2014 GT86
Well, now it looks so bad that even is noticeable. But in general, due wished/common toe angles being so small, way narrower vs camber's, one needs tools/rig to properly check toe part of alignment. I wouldn't drive with toe off as much as in pic.
#82 |
Drives: '15 BRZ RA
Why some people don't pay a professional to do the job? Is it too expensive or something else? It seems a bit dump, especially when you've paid more to import a suspension from Japan.
#83 |
How would I learn to do it myself if I paid someone else? The whole point of modifying my vehicle was to do it myself and learn from it. I didn't "pay more" to import suspension from Japan either but keep making assumptions.
#84 |
Assuming you didn't touch the toe arm, dial out some of the camber with your adjustable rear LCA to make the car driveable. Borrow a camber gauge if you can. Getting the camber to a reasonable amount (-2-ish) should bring the toe back to a reasonable amount. Then take it to an alignment shop. The toe looks pretty bad from your pics and I wouldn't drive it far the way it is now.
For the new at home DIY-ers you should at least having a skilled friend with you for an install like this. - Andrew |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | Trueweltall (07-30-2018) |
| Suspension UPGRADE - Shock/Spring Pkg vs. Coilover System - Which to choose? | themajesticone | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 80 | 11-14-2014 07:01 AM |
| Rebuilding strut/shock dampers to be firmer than spring rates? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 10 | 04-16-2014 01:23 AM |
| Can shock-dynos tell you what the highest spring rate it can handle? | fooddude | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 02-16-2014 05:43 PM |
| Stock dampers on the BRZ are made by Showa. Same for FRS? | mrha | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 10-19-2012 06:40 PM |
