Old 05-02-2017, 03:24 PM   #71
Da Brz
Drives: 2016 Subaru BRZ
I still occasionally catch myself looking for 7th.
I do on my bikes, for sure, lol.
Da Brz is offline   Reply With Quote
Old 05-02-2017, 03:44 PM   #72
Ultramaroon
not playing cards
Ultramaroon's Avatar
Da Brz (05-02-2017)
Old 05-02-2017, 05:11 PM   #73
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
@jsimon7777 is perpetually lugging his engine.
Originally Posted by humfrz
I'm old and lazy
Ultramaroon (05-02-2017)
Old 05-02-2017, 05:23 PM   #74
humfrz (05-02-2017), Ultramaroon (05-02-2017)
Old 05-02-2017, 07:11 PM   #75
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Again a change in criteria of the statement. Your first statement implies that the revs should always be low and does not say anything about cruising down the highway with cruise on.
There is nothing wrong with cruising at 3,000. Nothing at all. I cruise at 3,200 in 6th to go 70. Should I have another gear to keep revs down?
I do the same! Hahaha. Sometimes higher if I want to have fun. :P
Sent from my SM-G920I using Tapatalk
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
Old 05-02-2017, 07:13 PM   #76
Exrald
Exrald's Avatar
I'm​ going to invent a tranny that will have endless gears to keep the rpm under 3k! Wait for it!
2013 Scion FRS
2022 Toyota GR86
Old 05-02-2017, 07:37 PM   #77
humfrz
Waaaaay toooo late.
Back-in-the-day, my engine stayed below 3000 rpms AND the transmission (which consisted of a idler pulley, that when manually tightened up against the belt between the pulley on the driveshaft and the pulley on the drive axle) would make the car go faster .....or less fast. Did ya get all of that .....??
I started with a auto transmission (called a centrifugal clutch) and converted it a manual transmission (described above) ........because ......
A MANUAL TRANSMISSION WAS MORE MANLY in my roadster .....
humfrz
Exrald (05-02-2017)
Old 05-02-2017, 07:44 PM   #78
humfrz
NOW wouldn't THAT just drive the newbies to a MT over the edge .......
Reminds me of a story ....... uhhhhhh ..... it's too embarrassing ...... but the moral of the story is to NEVER forget which side of the transfer case or rear axle you are in ......
humfrz
Tcoat (05-02-2017), Ultramaroon (05-02-2017)
Old 05-02-2017, 08:25 PM   #79
Some CVTs already come damn close. My wife's old RVR (Outlander Sport) would hit 3,000 and just sit there as the CVT spooled up through the pulley. No shift points. No fluctuations in RPM. Just hit 3k and keep going faster and faster until you took your foot off the pedal and it leveled out at 1,500 to cruise. Weirdest sensation ever.
Old 05-02-2017, 08:28 PM   #80
humfrz
I probably clocked 500K miles in one version of that or another. If you only have one story about forgetting which side of the case you were on then you did way better than I did.
Old 05-02-2017, 08:39 PM   #81
humfrz
Oh ...... that sounds like a boooooring transmission ......
humfrz
Old 05-02-2017, 08:47 PM   #82
humfrz
The one time that I remember most was in a semi-tractor trailer hauling bulk milk. Coming off of a Interstate off ramp at night, waaay too fast, went to gear down, got all tangled up in the gears, a stop sign with a "T" ahead, I panicked and locked up the trailer brakes to stop ...... while I sorted out where I was gear wise.
The fellow behind me WAS NOT impressed with my trucker skills.......
humfrz
Old 05-02-2017, 09:02 PM   #83
Ultramaroon
not playing cards
I knew something was up. My car was never the same after we traded, that day.
Clipdat (05-02-2017)
Old 05-02-2017, 09:05 PM   #84
Exrald
Exrald's Avatar
I used to like CVTs or Dual Clutch trannies. However, they never gave the same sensation as a manual. My FRS is my first manual car. I was really planning on getting an Automatic, but that changed when I drove my friend's Si. I wanted that feeling, but even better! And I sure did get that with my FRS!!!
2013 Scion FRS
2022 Toyota GR86
Low RPM rattle when "lugging"? topazsparrow Issues | Warranty | Recalls / TSB 61 05-31-2018 02:10 PM
