Old 06-06-2017, 03:52 AM   #71
Sleepypistonracing
Sleepypistonracing's Avatar
Drives: GT86 Road legal time attack car.
Kinnekulle race report:
The Friday started of excellent. I'd been given the opportunity to have Robin Antonsson ride along throughout the day and I totally had a blast! After my first session with him, I cut 1 second off. After the next, I cut another second. I have a totally different mind in regards to work with the car rather than trying to force it to obey me. My driving have become immensely smoother thanks to Robin! I'd really recommend anyone, no matter what level you're on to have him ride along!
On the Saturday, the rain started early in the morning. On our first qualifying session, one of my competitors and friend crashed his car quite badly and we had yellow flag in one section during the entire session. On the second qualifying sessions, I start to get a hang of how smooth I need to be in the rain. Just as I pass the finish line on my third lap, Harry's clocks a low 1,09 time which would have been enough for a place in the finals, however, as I exit under the bridge I feel the back is starting to slide and as I start to parry it, it feels like its already too late and I just jump on the breaks. A rookie misstake perhaps, that could have been avoided had I not thought it was just a minor slide. As the car hits the sidebars it springs up in the air and is thrown around 180 degrees. The rest is censored automatically by the GoPro
I throw my self out of the car as I become slightly chocked with the smell of gun powder and white smoke everywhere. The driver's side airbag and knee airbag as well as the passenger side airbag popped, ripping the dash apart.
We have today started to strip the car apart to see what has been damaged and what has not. It looks like I've been really lucky as just one frame beam has been slightly bent, almost at the front most part. A cross measurement says that everything is all right up until the front mounting point of the right side control arm. Now we need to get some parts quick to get the car back on track as soon as possible!
To get a proper alignment done we need some frame parts that I've found in Poland. Hopefully I can get them here quickly!
In our Facebook group you can see the GoPro video!
We shall overcome!=)
Sleepypistonracing is offline   Reply With Quote
Old 06-06-2017, 08:04 AM   #72
dattran86
Driver
Drives: 2013 Whiteout FRS
sucks to see that happened. hope you come back stronger!
dattran86 is offline   Reply With Quote
Old 06-12-2017, 11:44 AM   #73
Sleepypistonracing
Chapter 2: "Get knocked down, get up again"
The car is now, just a week after the crash, properly aligned!
Old 08-07-2017, 12:42 PM   #74
Sleepypistonracing
Its been a while but not everything is standing still. The interior is ripped out and I got a cage lying next to the car waiting for someone to weld it in The engine runs smooth and I've just got a new Mishimoto cooler.
I have 17 error codes in airbag system. The Swedish MOT equivalent requires 0 fault codes. If I ver want to be street legal again I need to get rid of these. Does anyone have any clue if it's possible to reprogram the ecu in anyway or trick the airbag ecu in any way? I've got no airbags in it at all know and won't put any in again.
Also I think I will go rocket bunny now. Some cheap as kit, mainly to cover all the dents on the rear fenders😆
Old 08-08-2017, 03:20 AM   #75
thetyrant
Drives: 2012 gt86 Cosworth charged
Im not 100% sure if it will work on this setup but I know on other cars with airbag deletes you can fit a resistor in its place to trick the ecu its there, I doubt you can easily reprogram the ecu to ignore them missing with it being a safety feature.
if you have a working air bag you could measure its resistance but carefully as it may go off! then fit a corresponding resistor on the car and see if it stops the error, if so repeat with all the bags.
thetyrant is offline   Reply With Quote
Old 08-08-2017, 03:23 AM   #76
thetyrant
Found this for steering wheel airbag delete which might work with all others ? http://www.ft86club.com/forums/showthread.php?t=86415
Old 08-08-2017, 04:13 AM   #77
Sleepypistonracing
I know about this bit This is not just one airbag. This all of ren + additional error codes.
Old 08-08-2017, 04:44 AM   #78
thetyrant
Yes i know that, what im saying is it might be possible to fit a resistor at each air bag connector then you can clear the codes ?
Hopefully our system allow the codes to be cleared as i know on some cars if airbags are activated the complete airbag Ecu needs to be replaced which is sometimes very expensive!
Old 08-08-2017, 04:45 AM   #79
Sleepypistonracing
Ah well I will definatley try😆
Old 08-09-2017, 04:03 AM   #80
Sleepypistonracing
For those of you interested, here is the TV episode were my crash is featured! I'm amazed how much the rails flex, the probably saved the car from being totaled!
And this is my substitute car for now! Had a leak from the differential and the oil hit the exhaust. Looks cool😂
It's a 328 with torsen differential, bilstein coils and harder bushings.
Toyota GT86 2013. Swedish Time attack 2015 Fricke Member's Car Journals 25 02-05-2016 03:31 AM
Road Atlanta X Evasive Motorsports Video Global Time Attack Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 8 05-31-2014 02:10 PM
Global Time Attack: Road Atlanta x Evasive FR-S Evasive Motorsports FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 11 05-15-2014 03:00 PM
Global Time Attack @ Road Atlanta May 9th & 10th. Thongpocket Tracking / Autocross / HPDE / Drifting 23 04-24-2014 03:29 PM
Global Time Attack Winning Lap Video at Road Atlanta..Momentum! Element Tuning Tracking / Autocross / HPDE / Drifting 11 09-26-2013 11:55 AM
