Old 09-25-2013, 10:35 PM   #1
Element Tuning
Drives: Hydra EMS Powered FRS Raven Black
Global Time Attack Winning Lap Video at Road Atlanta..Momentum!
So I ran this race back in May but was just so busy getting the FRS into boosted trim I never put it together. It's was really fun because I don't normally race low power NA setup nor do I race on street tires.
So the car basically had only a few mods at the time. This was my first race full race with the Hydra EMS as we really had just dialed it the week prior to this race so I was eager to torture test it.
Element Tuning Hydra EMS Full Stand-Alone EMS, plug and play (direct injection, port injection, and full CAN support)
Element Tuning Custom Valved BC BR Coilovers
Tanabe front pipe and Muffler delete (OEM midpipe, and headers)
Hankook RS3 275/35-18
Brembo STi front brakes
I had dynoed the car after the race at 168 whp, with my baseline at 153 whp. I was able to get dialed into the track and set the winning time and new class lap record of 1:43.92 in Enthusiast RWD.
[ame]http://youtu.be/QlEX2a6jf-M[/ame]
What I enjoyed most was the challenge and difficulty that comes from not having excessive HP. You have to use every inch of the track and more as you can see in the video. Being aggressive is absolutely required but at the same time you can't slide and scrub your speed!
Anyways I really enjoyed the few times I raced this car in NA trim!
Thanks,
Phil Grabow
Element Tuning is offline   Reply With Quote
Old 09-25-2013, 11:58 PM   #2
u/Josh
Drives: GBS Limited 6MT
Any thoughts on rear lift at high speed with the muffler delete?
u/Josh is offline   Reply With Quote
Old 09-26-2013, 09:50 AM   #3
Element Tuning
It's more about the lack of rear weight more than anything else. Removing the muffler while saving weight overall, unbalances the car so it's very hard to work heat into the rear tires. Junk out of the trunk and no muffler drops a ton of weight which helps your lap time if you can hang onto the rear end.
I'm sure replacing the gap with even a basic homemade diffuser would help rear DF. Cornering at 110 mph + is the only time I felt the rear had some high speed lift but I can't say it was worse without the muffler as I didn't do enough testing before putting a wing on.
Old 09-26-2013, 10:03 AM   #4
DarkSunrise
DarkSunrise's Avatar
Did you feel there were any significant weak points in that state of tune? Other than power of course.
2022 BRZ Build
2013 FR-S Build
Old 09-26-2013, 10:25 AM   #5
Element Tuning
Can you clarify a little? Do mean all aspects such as chassis and engine tuning?
Old 09-26-2013, 10:26 AM   #6
DarkSunrise
Yep. If you were going to keep going with a NA build, what would your next steps have been? Speaking hypothetically of course
2022 BRZ Build
2013 FR-S Build
Old 09-26-2013, 10:39 AM   #7
Element Tuning
My wheel and tire package is too large for NA. A smaller rolling diameter and a little less width would save weight and improve acceleration.
I forgot to add I don't run a rear sway bar so that's more weight off the rear end. It's a struggle to get heat back there if you're only running 3 qualifying laps.
With the Hydra EMS I wasn't having the issues my competitors in his FRS had, which was the traction and stability control turning back on. Now more power is good so if staying NA a header and intake is something I would add. I would also make an air damn up front to block more air going under the car and I would also build a diffuser.
I also had race brake pads and a fuel pump in the saddle tank to prevent fuel starvation at low fuel levels.
Old 09-26-2013, 10:59 AM   #8
DarkSunrise
Interesting point about running without the RSB (presumeably because of the Torsen LSD), and not the first time I've heard that. Do you have to run much higher rear spring rates to compensate?
2022 BRZ Build
2013 FR-S Build
Old 09-26-2013, 12:26 PM   #9
Old 09-26-2013, 12:29 PM   #10
I'm assuming the certain red FRS didn't use the pedal dance?
Old 09-26-2013, 12:50 PM   #11
Element Tuning
I think he did or he did and had brake issues...not sure
Old 09-26-2013, 12:55 PM   #12
Element Tuning
Yeah if you have enough grip the bar picks up/unloads the inside. So I can get on throttle way earlier since the diff doesn't unload. There is also more grip and use the front bar and spring rate to fight roll. Also more front roll stiffness digs rear in more.
Video - Why We Race: Testing Project FR-S at the 2012 Global Time Attack Hotchkis FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 30 05-13-2015 04:31 PM
We will be competing in Global Time Attack next weekend in Palm Beach, with our FRS! Arsenal Autosport Tracking / Autocross / HPDE / Drifting 10 12-18-2012 08:40 PM
2013 Redline Time Attack enthusiast class winning lap CSG Mike Tracking / Autocross / HPDE / Drifting 12 12-02-2012 12:46 AM
FR-S on track at Palm Beach Intl Raceway w/Global Time Attack Arsenal Autosport FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 32 06-11-2012 03:53 PM
Formula D/Global Time Attack, PBIR June 1-2 Arsenal Autosport Southeast 4 05-25-2012 07:39 PM
