#71 |
Stuck like Glue
Drives: WRB BRZ Limited
Hey,
Can you post a pic of your wheels from the top/rear? Just want to see how much tuck is there with the setup that you are running. I'm planning on getting the same set of wheels with the same config as yours. Just wanted to know how far off I would be for a flush finish. From what I read on this thread, some are happy with the 'flush' finish you get with 17x8 +48, while some are not. Looking at a few more pics will help me decide as I haven't seen one in person yet! Also, I'm assuming this is stock setup with no coilovers or drops, right? Thanks! |
#72 | |
Drives: Raven FR-S
These are mine: 17x8 +35 |
#73 | |
( ͡° ͜ʖ ͡°)
Drives: '13 Whiteout FR-S A/T
OZ Ultraleggeras / Michelin Pilot Super Sports
My setup is bone stock suspension except front crash bolts at -1 camber, stock tires. The front at 17x8 +48 is close enough to being flush for me. At -1.0 camber with 215 wide tires, you will stick out just a tad more than stock (0.5") since the rim is wider by 1". The rears are wider than stock for the same reasons above, but are not very close to being flush. You'd have to add 25+mm spacers to get it flush. For me, I'm not too concerned since it would be a ridiculous hassle to be flush in the front AND rear (spacers and studs, staggered, etc) You could get the 17x8 +35, but I only found them in black on TireRack. But you'll have to bring some negative camber around -1.5 ish to get the fronts not to poke. My car is getting detailed tonight so I'll get some good pics tomorrow. Sent from my iPad using Tapatalk |
#74 |
Drives: FRS
Like some said here, you can get in 35 offset. I have a thread on this section with some pics for anyone that wants to see how they look.
#75 | |
Stuck like Glue
![]() It seems TireRack offers only Black and Silver in +35 and not Gold. |
#76 |
NW Region Moderator
Drives: FR-S No More
This topic had 17" and 18" Ultraleggeras mixed together... I split the 18" stuff to this topic:
http://www.ft86club.com/forums/showthread.php?t=12693 This topic is for 17x8.0 +48 fitments only now.
#77 |
( ͡° ͜ʖ ͡°)
#78 |
Wayward Member
Drives: Hot Lava 86
Do you guys think a 17x8 +48 will fit with a 245/40/17?
#79 |
( ͡° ͜ʖ ͡°)
#80 |
Wayward Member
Drives: Hot Lava 86
If I kept the stock suspension I wouldn't be running any camber. I might lower it on RCE yellow springs, if I lower it at all though.
#81 |
Drives: 13 FR-S AT
17x7.5 and 17x8 Stagger
Though I would contribute :-)
17x7.5 225/45-17 SS's 17x8 245/40-17 SS's |
#82 |
Stuck like Glue
Looks like no one here has the OZ setup in gold, so here is my contribution to the thread.
OZ Ultraleggera Gold - 17x8 +48 Michelin Pilot Super Sports - 22545/R17 Satisfied with the setup! Wanted light wheels and in 17s and this looks great too. Michelin PSS are great tires and I'll be taking them to my first track day this weekend. Got a random 'awesome wheels bruh' from a STi guy on my way to work today too! Made my day! ![]()
#83 |
Stuck like Glue
Quick question for all you guys who are NOT running the stock 215/45/R17 setup. How do you determine your ideal tire pressures? I'm assuming it will not be the recommended 35psi as those are for the stock tires. So what pressures do you guys run and how did you decide on running that pressure?
#84 | |
( ͡° ͜ʖ ͡°)
OE 35 psig is a decent starting point, but you will need to fine tune based on how you want your car to behave. Hypermiling extremists pump up to 40+ psig to get great gas mileage on the highway. AutoX guys measure front/back pressures to get the car to behave a very specific way for the layout that day. See a good summary from TireRack: http://www.tirerack.com/tires/tirete....jsp?techid=58 |
| Tags |
| oz ultraleggera |
| Wheel Directory: XXR 527 17x8.25 +35 | MF_DEUCE | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 41 | 12-25-2019 06:37 PM |
| Wheel Directory: Forgestar F14 17x8.5 +38 | cycleboy | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 08-20-2016 03:13 PM |
| Wheel Directory: SSR Competition 17x8.0 +38 | Enigmus | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 25 | 08-07-2015 06:38 PM |
| Wheel Directory: XXR 535 17x8.25 +35 | PineappleFriedRice | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 10-24-2014 08:27 PM |
| Wheel Directory: XXR 522 17x8.0 +48 | STEVEOSTI | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 12-13-2012 12:39 AM |
