Old 05-10-2014, 09:34 PM   #71
ZeHeadBanger
Stuck like Glue
ZeHeadBanger's Avatar
Drives: WRB BRZ Limited
Originally Posted by drewbot View Post
Hey,
Can you post a pic of your wheels from the top/rear? Just want to see how much tuck is there with the setup that you are running. I'm planning on getting the same set of wheels with the same config as yours. Just wanted to know how far off I would be for a flush finish.
From what I read on this thread, some are happy with the 'flush' finish you get with 17x8 +48, while some are not. Looking at a few more pics will help me decide as I haven't seen one in person yet!
Also, I'm assuming this is stock setup with no coilovers or drops, right?
Thanks!
ZeHeadBanger is offline   Reply With Quote
Old 05-10-2014, 10:01 PM   #72
nosi9frs
nosi9frs's Avatar
Drives: Raven FR-S
Originally Posted by ZeHeadBanger View Post
Hey,
Thanks!
These are mine: 17x8 +35
nosi9frs is offline   Reply With Quote
Old 05-10-2014, 10:31 PM   #73
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
OZ Ultraleggeras / Michelin Pilot Super Sports
Hey,
Thanks!
My setup is bone stock suspension except front crash bolts at -1 camber, stock tires.
The front at 17x8 +48 is close enough to being flush for me. At -1.0 camber with 215 wide tires, you will stick out just a tad more than stock (0.5") since the rim is wider by 1".
The rears are wider than stock for the same reasons above, but are not very close to being flush. You'd have to add 25+mm spacers to get it flush. For me, I'm not too concerned since it would be a ridiculous hassle to be flush in the front AND rear (spacers and studs, staggered, etc)
You could get the 17x8 +35, but I only found them in black on TireRack. But you'll have to bring some negative camber around -1.5 ish to get the fronts not to poke.
My car is getting detailed tonight so I'll get some good pics tomorrow.
drewbot is offline   Reply With Quote
Old 05-10-2014, 11:01 PM   #74
FRSKEV
Drives: FRS
Like some said here, you can get in 35 offset. I have a thread on this section with some pics for anyone that wants to see how they look.
FRSKEV is offline   Reply With Quote
Old 05-11-2014, 10:29 AM   #75
ZeHeadBanger
Stuck like Glue
17x8 +35 is the setup I'm looking for as I think that sits really well on the car and gives it a flush look, but they are NOT available in the color I want (Gold).
It seems TireRack offers only Black and Silver in +35 and not Gold.
Old 05-11-2014, 04:38 PM   #76
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
This topic had 17" and 18" Ultraleggeras mixed together... I split the 18" stuff to this topic:
http://www.ft86club.com/forums/showthread.php?t=12693
This topic is for 17x8.0 +48 fitments only now.
Old 05-11-2014, 06:03 PM   #77
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
@ZeHeadBanger
DSCF6288 by Drewbot 95, on Flickr
DSCF6290 by Drewbot 95, on Flickr
Old 05-15-2014, 11:14 AM   #78
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Do you guys think a 17x8 +48 will fit with a 245/40/17?
Nevermore is offline   Reply With Quote
Old 05-15-2014, 12:04 PM   #79
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
In the back yeah no problem.
In the front it will be tight on OE suspension, especially if you run negative camber through bolts and not plates
Old 05-15-2014, 12:19 PM   #80
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
If I kept the stock suspension I wouldn't be running any camber. I might lower it on RCE yellow springs, if I lower it at all though.
Old 05-15-2014, 12:55 PM   #81
F1fletch
F1fletch's Avatar
Drives: 13 FR-S AT
17x7.5 and 17x8 Stagger
Though I would contribute :-)
17x7.5 225/45-17 SS's
17x8 245/40-17 SS's
F1fletch is offline   Reply With Quote
Old 05-22-2014, 07:52 PM   #82
ZeHeadBanger
Stuck like Glue
Looks like no one here has the OZ setup in gold, so here is my contribution to the thread.
OZ Ultraleggera Gold - 17x8 +48
Michelin Pilot Super Sports - 22545/R17
Satisfied with the setup! Wanted light wheels and in 17s and this looks great too. Michelin PSS are great tires and I'll be taking them to my first track day this weekend. Got a random 'awesome wheels bruh' from a STi guy on my way to work today too! Made my day!
Old 05-23-2014, 09:58 AM   #83
ZeHeadBanger
Stuck like Glue
Quick question for all you guys who are NOT running the stock 215/45/R17 setup. How do you determine your ideal tire pressures? I'm assuming it will not be the recommended 35psi as those are for the stock tires. So what pressures do you guys run and how did you decide on running that pressure?
Old 05-23-2014, 11:38 AM   #84
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Regardless of the tire size or type, it would depend on your goals.
OE 35 psig is a decent starting point, but you will need to fine tune based on how you want your car to behave.
Hypermiling extremists pump up to 40+ psig to get great gas mileage on the highway.
AutoX guys measure front/back pressures to get the car to behave a very specific way for the layout that day.
See a good summary from TireRack: http://www.tirerack.com/tires/tirete....jsp?techid=58
oz ultraleggera
Wheel Directory: XXR 527 17x8.25 +35 MF_DEUCE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 41 12-25-2019 06:37 PM
Wheel Directory: Forgestar F14 17x8.5 +38 cycleboy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 08-20-2016 03:13 PM
Wheel Directory: SSR Competition 17x8.0 +38 Enigmus Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 08-07-2015 06:38 PM
Wheel Directory: XXR 535 17x8.25 +35 PineappleFriedRice Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 32 10-24-2014 08:27 PM
Wheel Directory: XXR 522 17x8.0 +48 STEVEOSTI Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-13-2012 12:39 AM
