Old 07-14-2021, 10:24 AM   #71
abyssFT86
Drives: 2020 BRZ Limited
Sorry to bring this one back from the dead, but two questions:
1. Is this issue likely to happen if you don't swap wheels frequently? I'm going to put on some Apex 17x9s and leave them on year round. I'll torque them down between runs at the track by hand, probably 1-2 track days /mo. Probably only doing one or two removals per year for tires/pads.
2. Have the newer model years rectified this issue at all? I have a 2020 just bought earlier this year.
Happy to upgrade to the ARP lugs if needed but from the above not really clear that it is necessary.
abyssFT86 is offline   Reply With Quote
Old 07-14-2021, 04:23 PM   #72
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Somebody early on in my ownership overtorqued all of my lugs. Was it the tire company or a dealer or the factory? I don't know, but I've replaced maybe ten bolts in 30k miles. They have been failing one or two at a time. Currently one is bad. I'll be replacing all the lugs and nuts soon, with upgraded parts. Pain in the fucking ass.
The Following User Says Thank You to EAGLE5 For This Useful Post:
Lonewolf (07-15-2021)
Old 07-14-2021, 05:44 PM   #73
cjd
cjd's Avatar
Drives: 2017 BRZ
I just carry spares and the tools to do the job. Eventually I'll probably find the energy to just swap them... Maybe. Think I should just go standard length though, half my spares are extended...
Old 07-14-2021, 06:10 PM   #74
Ultramaroon
not playing cards
Ultramaroon's Avatar
Bummer. Once they've been stretched, they're done. I've had zero issues but I keep them clean and have been careful from day-1.
Not saying others aren't. I've been expecting a failure but it just hasn't happened.
Old 07-14-2021, 06:27 PM   #75
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I just preventively swapped all studs when it was time for me to change rotors.
I was super-careful with them, but still one of them started falling apart before that.
timurrrr is offline   Reply With Quote
Old 07-14-2021, 06:35 PM   #76
DarkSunrise
DarkSunrise's Avatar
I’m surprised I haven’t had this issue yet. I’ve got a 2013 MY. I try to be careful with my studs, but I wonder if it’s because I switched out to black gorilla lugs early on.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
NLSP (07-14-2021)
Old 07-14-2021, 06:45 PM   #77
Ultramaroon
not playing cards
The stubby acorn nuts don't have very deep threads.
minimum aspect ratio is minimum.
Old 07-14-2021, 07:17 PM   #78
cmiovino
cmiovino's Avatar
Drives: 2017 BRZ PP, 2004 WRX
2017 here. I ended up finding a completely crossthreaded lug nut this weekend at an autocross event 3 hours away. I will admit, I was the last one to touch them, but have only rotated the wheels ONCE myself on this car this autox season. Shop installed the tires earlier this year.
Last year I had the wheels off maybe 5 times max. I doubt the previous owner was swapping them. I'd say a total of 15 times on/off and the wheels studs are disintegrating all around, not just with that one.
Every time you remove a lug nut, little sparkles come off and over time, you have less and less material there, which leads to crossthreading. It appears not to be fixed with the newer models.
On my 2004 WRX, which I've some years swapped tires 20+ times a year, I still have all the stock studs. I've never crossthreaded or broken one. I've changed wheels in the rain, when hot after driving, in garages or out at the track/autocross. Zero issues. BRZ studs are not the same material at all IMO.
I'd recommend changing them all to ARP or at least the Dorman ones. THe Dorman ones are cheaper at $50 for a full set of 20 vs $180ish for ARP normal length ones. I'll probably go the Dorman route all around myself. You can tell the ARP and Dorman ones are a different material as they are yellow-ish looking vs the stock silver color. I talked to a few autocrossers using the Dorman ones with good results.
cmiovino is offline   Reply With Quote
Old 07-14-2021, 09:40 PM   #79
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
+1 on being surprised...I have a 2014 with 92k miles. Original studs (and original TOB lol) still, using McGard Splinedrives most of its life.
NLSP is offline   Reply With Quote
Old 07-15-2021, 01:19 AM   #80
DarkSunrise
I'm more shocked that your original TOB is still going strong!
2022 BRZ Build
2013 FR-S Build
NLSP (07-15-2021)
Old 07-15-2021, 08:28 AM   #81
steverife
Drives: 2016 Scion FRS
I don't think it is really cross threading, unless you are gunning nuts on without hand starting them. The threads get contaminated with dirt/grime/shaving or get deformed from dragging wheels across them.
I couldn't get ARP's at the time that I needed to swap, but I actually swapped out to M12x1.5 Dorman. Part number 610-414 has the same knurl diameter and basically the same length. I also started carrying a die/chaser, so I can be proactive about things if I spin a nut on and it feels bad.
steverife is offline   Reply With Quote
The Following 3 Users Say Thank You to steverife For This Useful Post:
NoHaveMSG (07-15-2021), strat61caster (07-15-2021), Ultramaroon (07-15-2021)
Old 07-15-2021, 09:13 PM   #82
soundman98
ProCrastinationConsultant
soundman98's Avatar
i really think this is what really does it. the only times my wheels get an air gun is when getting new tires(3 times now, but about 10 times changing wheels overall). every other time, it's by hand, with a 4-cross lug wrench.
and i've already lost/replaced 3 studs.
The Following 2 Users Say Thank You to soundman98 For This Useful Post:
NoHaveMSG (07-15-2021), Ultramaroon (07-15-2021)
Old 07-15-2021, 09:29 PM   #83
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I carry a small nylon brush in my tire changing kit. I brush the studs off before putting the wheels on. No issues here.
The Following User Says Thank You to NoHaveMSG For This Useful Post:
soundman98 (07-15-2021)
Old 07-16-2021, 08:24 AM   #84
steverife
Hasn't proved to be enough for me, but yeah, I brush/wipe studs and try to make sure nothing is in the nut.
WTB WHEEL STUDS TomShugoy Want-To-Buy Requests 0 02-08-2016 07:44 PM
ARP Wheel Studs FR-S Matt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 11-09-2015 07:50 PM
ARP Wheel studs and 10mm hubcentric wheel spacers S1CNSTY_SUBIE Wheels and Tires 3 04-17-2015 09:31 AM
WTB OEM Wheel Studs Anthony Want-To-Buy Requests 8 08-27-2014 04:22 PM
Meeting with Subaru field engineer in two weeks Subie Issues | Warranty | Recalls / TSB 35 02-25-2013 02:50 PM
