#71 |
Drives: Forester 2007, BRZ Limited '13
Guys, relax. OP is in SoCal, which means 91 octaine fuel. We simply don't get higher 93 octain in Cali.
The fact that engine shook and RPM dropped prior to the light appeared, lead me to believe that its a detonation. Why? DI + port injection switching. Give both companies some time to gather more cases and stats. Demo cars had 10K + miles on them during some reviews we read back April. I'm sure it would come up if it was THAT big of a deal. Take notes and bring those to your dealers. Meanwhile get gas only from reputable gas stations.
I am busy. Do not disturb. http://youtu.be/I58ZSqwFlWw?hd=1
#72 |
Drives: 2013 Scion FR-S Firestorm Red MT
While that may be a contributing factor, it shouldn't start throwing CELs from 91 vs 93. Even the lowest grade fuel should 'work' but just not optimally. This is a 2013 car, I doubt it's that sensitive to fuel grade to the point it starts having idling issues and throwing codes.
Also, to Toyota's credit, they've beat Subaru in reliability for the last decade on both year-old and 10-year old cars.
#73 |
We don't know anything about OP fuel. Numbers written on the wall are nothing. Deponation could trigger CEL and its a nasty one to figure out via codes - they are all over the board.
#74 | |
Reverse Burnouts
Drives: 2013 Argento FRS
toyota was in charge of 1. money 2. exterior 3. D4S( injection) 4. the Diff 5. transmission(both manual and automatic) 6. intake 7. keyless 8. power steering(its actually tech trickled down from the LFA!!) 9. interior design 10. electronics(buttons, ergonomics of the cabin) 11. areo dynamics 12. exhaust tuning/development 13. all the glass window( thicknesses, auto up down, uv protection) 14. airbags 15. frame design(types of metals used/crash testing) subaru 1. suspension 2. engine donor 3. chassis 4. homelink 5. driveshafts 6. brakes 7. wheels 8. making the car 9. carpets 10. Frame design (ring shaped designed)
![]() 2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x |
| The Following 7 Users Say Thank You to carbonBLUE For This Useful Post: | BlaineWasHere (06-29-2012), excited86 (06-28-2012), gdi2290 (08-29-2012), Linseal (06-28-2012), rice_classic (06-29-2012), Sciontissst (06-29-2012), Septic (06-29-2012) |
#75 |
That guy
Drives: Ultramarine mt FR-S
Cam sensors/alignment/engine internals (sans DI) are from Subaru, not Toyota. Don't try to be a fanboi and pin things on the other "parent". The twins belong to both companies and the most important thing is they work together to settle the issues quickly and efficiently.
#76 | |
Drives: 2011 BMW 328i Coupe M-Sport 6MT
The JGC had all of the above going for it. |
#77 |
When you mention a Chrysler from that era, it says it all to me. My dad had one of those Chrysler vans from that same time period, eugh..
#78 |
Drives: Raven FR-S
I've put over 3500 miles on my FR-S, driven all over the southwest....giving her all the chances I could to break on me.
| The Following 2 Users Say Thank You to Pscylo For This Useful Post: | eriktherod (06-29-2012), Spartan65 (08-12-2012) |
#79 | |
[I 86 I]
Drives: Toyota 86 GT
I wonder if there is a difference between quality of US vs AUS/JPN fuels or if the US market cars have been de-tuned to suit etc.. |
#80 |
I believe the fuel trims (ECU maps) are different for each region.
I remember when I would reflash the ECU on my Si, the Hondata stock maps for various regions were different and even some of the ECUs themselves were different.
#81 | |
#82 | |
#83 |
6/22/12-2/6/24
The octane discussion is entertaining but it doesn't address the problem.
It says in the manual that 91 will do the job fine - most likely the ECU has been tuned to it then. |
#84 |
Grip>Drift
Drives: FRS
I never had this problem when I lived in MI, but out here in CA I find if I stray from Shell or Chevron you can get bad fuel. Stations like Rotten Robbie and other cheaper stations would throw CEL in my GTI, which is a DI motor.
| My car is in and still 1,304 miles away! | joshua | BRZ First-Gen (2012+) — General Topics | 16 | 06-28-2012 08:02 PM |
| Some Miles | White_OUT_FR-S | Scion FR-S / Toyota 86 GT86 General Forum | 0 | 06-22-2012 02:00 PM |
| Check Engine Light | b.e | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 06-17-2012 09:50 PM |
| Check Engine Light directly after pickup | Stu L Tissimus | BRZ First-Gen (2012+) — General Topics | 27 | 06-15-2012 05:07 PM |
| Check engine light code reader | FRSCoupe | Engine, Exhaust, Transmission | 14 | 06-13-2012 05:06 PM |
