#813 |
There are some threads on it someplace. Was a pile of work for almost zero overall effect. The resulting vents were just simply too small to make any real difference.
#814 | |||
Drives: RX-7 / BRZ
C-West, T-Craft and Sard replacement garnishes are vented and still sold. It is still cheaper to buy a 2nd-hand set of stock ones and just cut them though... Quote:
Not too small of a difference. It's been a nice addition for the turbo crowd. Useless for the stock group though. It is still a good mod for anyone wanting to keep the OEM hood. The mod along with removing the rear hood seal and replacing the lower aluminum underpanel are really your only options. Quote:
Read this whole thread: https://www.ft86club.com/forums/showthread.php?t=70815 https://www.ft86club.com/forums/showthread.php?t=139387
//2018 Crystal White Pearl BRZ Ts 2.2l Harrop Supercharged |
#815 |
Drives: 2017 Toyota 86
Sorry, typo - I meant to say I haven’t read the whole tread
#816 | |
#817 |
Drives: 13 White MT FR-S
#818 | ||
Drives: Moped
I know that Lunatic used to have an FRS he used to track with functional fender vents. He said that he could feel the air be evacuated from the engine bay once the fans turned on. Since it is a high-pressure area, I'm not sure how objectively well they work, but the pragmatist in me think it probably helps vent some heat and pressure from under the hood. Go see Page 46 in this thread for some fender vents used by The Racers Line, Lunatic, and Jetbill: https://www.ft86club.com/forums/show...unatic&page=46 Last edited by Lonewolf; 11-28-2020 at 02:10 PM. |
#819 |
Drives: 2015 GT86 SC; 2014 BRZ turbo (sold)
Adding my two cents here. Ambient temps are from 20C/70F in winter to 50C/120F in summer so this may be the best test environment for heat issues.
Temperatures are absolutely fine during DD, stop and go traffic, and spirited driving. During a series of hard street pulls can just about get the oil temp to 100C/210F. All of this is with the Air Conditioning on at all times. On track however, oil touches 120C/250F after 5 laps (8 minutes ish) forcing me to do a cooldown lap or pull into the pits for 5 minutes. Basic engine setup: Avo Stage 2 turbo setup, built motor, 13-18psi depending on map, Redline 10W-40 oil. FMIC in front of radiator Turbo blanket Heat wrapping from turbo to midpipe Cooling setup: Koyorad radiator & high pressure rad cap Samco / Mishimoto hoses (rad and heater) OEM fans (Middle East spec fans seem to be more capable than other markets) Custom oil cooler with thermostatic plate mounted in cut open fog light area Custom vented hood Gold heat shielding on areas near headers Further parts installed but not tested: AEM Water/meth injection Water misting kit for FMIC and oil cooler (operating but have not gathered data) To me it seems the vented hood makes all the difference. During traffic I can literally see the heat haze rising out of the hood. Pictures below: ![]() ![]()
#820 |
poor man's evora
Drives: Turbod BRZ
i had issues for a while with all the normal cooling mods made. switched to spal fans and issues are gone.
#821 |
Drives: 2017 toyota 86
That’s not a lot of airflow to your oil cooler. You should try something like this, at least with the exhaust fans, worked wonders for dropping oil temps.
#822 |
Drives: Moped
Bump for newer members looking for more cooling discussion...
#823 | |
Sent from my ONEPLUS A5010 using Tapatalk |
#824 | |
He said he had oil overheating issues with that setup. But yes ducting (which doesn’t look like he has) and rear vents (which not sure if he has but is in the setup I recommended) would help. Still a small opening regardless. |
#825 |
Rust bucket enthusiast
Major necro here but this was the first time I've really beat on the car in its current form.
Did autocross on an 89 degree day. 15 runs with just a few minutes in between each. Each lap about 44 seconds and mostly redline 1st and second gear. Oil temps got up to 215f max, and coolant didn't reach 210f the whole day. Front mount JDL turbo, 3076r size. Considerations - Verus hood vents No oil cooler. Oil not returned to pan, it is vacuumed out of the turbo by the rear cam (fa20 wrx style) Entire a/c system removed, including condenser 3" thick bar and plate Garrett FMIC covering entries radiator, pushed back as close to the radiator as possible. FRS front bumper, plastic grille intact Truefocus fab crash bar, stock crash bar removed Stock radiator Stock coolant hoses Mishimoto slim fan shroud and fans Factory Toyota coolant PTP turbo blanket DEI black fiberglass wrap on whole downpipe Turbo manifold ceramic coated Turbo wastegate recirculated into exhaust. I believe that the top 4 largest impacts here are- Removing a/c condenser - much less air restriction in cooling stack Mounting intercooler close to radiator - Air doesn't go stagnant between them while in motion Hood vents - this is critical for this platform in any use capacity Recirculating wastegate - not dumping hot exhaust under the engine in open air is HUGE My car absolutely has not seen extended heavy load and I am not saying that my car would not overheat under other circumstances. But to be able to hotlap autocross on airport tarmac on a 90 degree day with not a cloud in the sky? This is a great recipe for a street build. Just wanted to give someone in the future some ideas.
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
#826 | |
Drives: 2013 Subaru BRZ Turbo
Just curious. |
| any serious benefit Heat Tapes? | Djen | Engine, Exhaust, Transmission | 22 | 02-18-2014 03:20 PM |
| Heat bad for your car? Ways to cool it? | BushMan | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 08-01-2013 10:15 PM |
| Misfire with heat? | bigjake | Issues | Warranty | Recalls / TSB | 2 | 04-28-2013 09:02 PM |
| Do I Need a Heat Shield? | arleewa | Engine, Exhaust, Transmission | 1 | 01-08-2013 06:37 AM |
| Overpipe Heat question | Amadeus | Engine, Exhaust, Transmission | 5 | 12-19-2012 01:18 AM |
