Old 11-26-2020, 12:04 PM   #813
Originally Posted by pallen View Post
I have read the entire thread, but curious if anyone has tried venting heat out the fake side vents on the front fenders?
There are some threads on it someplace. Was a pile of work for almost zero overall effect. The resulting vents were just simply too small to make any real difference.
Old 11-26-2020, 12:54 PM   #814
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by Gamace View Post
I would like to vent heat though the fender garnishes but I don't see any garnish that's made with mesh anymore since the Prova one got discontinued.
C-West, T-Craft and Sard replacement garnishes are vented and still sold. It is still cheaper to buy a 2nd-hand set of stock ones and just cut them though...
Not too small of a difference. It's been a nice addition for the turbo crowd. Useless for the stock group though. It is still a good mod for anyone wanting to keep the OEM hood. The mod along with removing the rear hood seal and replacing the lower aluminum underpanel are really your only options.
Read this whole thread: https://www.ft86club.com/forums/showthread.php?t=70815
https://www.ft86club.com/forums/showthread.php?t=139387
Old 11-26-2020, 09:20 PM   #815
pallen
pallen's Avatar
Drives: 2017 Toyota 86
Sorry, typo - I meant to say I haven’t read the whole tread
pallen is offline   Reply With Quote
Old 11-27-2020, 09:39 AM   #816
pallen
pallen's Avatar
Looks nice. I would think the effect would be measurable. Looks like more than a simple swap of the trim piece with an open piece though, so I can see why its not common.
Old 11-27-2020, 09:55 AM   #817
ML
ML's Avatar
Drives: 13 White MT FR-S
Buy one of these and be done with it.
https://racelouvers.com/brz-fr-s-86-...-86-2012-2019/
Old 11-28-2020, 01:54 PM   #818
Lonewolf
Lonewolf's Avatar
Drives: Moped
Well to combat the heat with my setup (HKS Super Manifold Boxer Spec) I just installed the Laile Beatrush Underpanel and that totally takes care of the Headers. I would like to vent heat though the fender garnishes but I don't see any garnish that's made with mesh anymore since the Prova one got discontinued.
Toyota 86 in the building!
I know that Lunatic used to have an FRS he used to track with functional fender vents. He said that he could feel the air be evacuated from the engine bay once the fans turned on. Since it is a high-pressure area, I'm not sure how objectively well they work, but the pragmatist in me think it probably helps vent some heat and pressure from under the hood.
Go see Page 46 in this thread for some fender vents used by The Racers Line, Lunatic, and Jetbill: https://www.ft86club.com/forums/show...unatic&page=46
Old 12-02-2020, 07:01 AM   #819
TurboBRZ_UAE
Drives: 2015 GT86 SC; 2014 BRZ turbo (sold)
Adding my two cents here. Ambient temps are from 20C/70F in winter to 50C/120F in summer so this may be the best test environment for heat issues.
Temperatures are absolutely fine during DD, stop and go traffic, and spirited driving. During a series of hard street pulls can just about get the oil temp to 100C/210F. All of this is with the Air Conditioning on at all times.
On track however, oil touches 120C/250F after 5 laps (8 minutes ish) forcing me to do a cooldown lap or pull into the pits for 5 minutes.
Basic engine setup:
Avo Stage 2 turbo setup, built motor, 13-18psi depending on map, Redline 10W-40 oil.
FMIC in front of radiator
Turbo blanket
Heat wrapping from turbo to midpipe
Cooling setup:
Koyorad radiator & high pressure rad cap
Samco / Mishimoto hoses (rad and heater)
OEM fans (Middle East spec fans seem to be more capable than other markets)
Custom oil cooler with thermostatic plate mounted in cut open fog light area
Custom vented hood
Gold heat shielding on areas near headers
Further parts installed but not tested:
AEM Water/meth injection
Water misting kit for FMIC and oil cooler (operating but have not gathered data)
To me it seems the vented hood makes all the difference. During traffic I can literally see the heat haze rising out of the hood.
Pictures below:
TurboBRZ_UAE is offline   Reply With Quote
Old 12-02-2020, 10:17 AM   #820
malubawla
poor man's evora
malubawla's Avatar
Drives: Turbod BRZ
i had issues for a while with all the normal cooling mods made. switched to spal fans and issues are gone.
malubawla is offline   Reply With Quote
Old 12-05-2020, 10:43 AM   #821
86TOYO2k17
Drives: 2017 toyota 86
Originally Posted by TurboBRZ_UAE View Post
Pictures below:
That’s not a lot of airflow to your oil cooler. You should try something like this, at least with the exhaust fans, worked wonders for dropping oil temps.
Old 12-23-2021, 11:49 AM   #822
Lonewolf
Lonewolf's Avatar
Drives: Moped
Bump for newer members looking for more cooling discussion...
Old 12-23-2021, 12:53 PM   #823
Ashikabi
Ashikabi's Avatar
Honestly that air flow should be fine. Possibly too much. He should be running ducting, which I dunno if he is. But properly ducted, the opening should be about 30% of the heat exchangers size. Ideally the air would be ducted out on the back side to that same 30% dimension. Usually there isn't room for that. But that's "ideal". As far as airflow with no ducting, I'm not sure it's even possible to know what's best without trial and error, since so much air is going to travel around the heat exchanger instead of through it
Sent from my ONEPLUS A5010 using Tapatalk
Old 12-23-2021, 08:06 PM   #824
86TOYO2k17
Necromancer.
He said he had oil overheating issues with that setup.
But yes ducting (which doesn’t look like he has) and rear vents (which not sure if he has but is in the setup I recommended) would help. Still a small opening regardless.
Old 08-05-2026, 07:32 PM   #825
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Major necro here but this was the first time I've really beat on the car in its current form.
Did autocross on an 89 degree day. 15 runs with just a few minutes in between each. Each lap about 44 seconds and mostly redline 1st and second gear. Oil temps got up to 215f max, and coolant didn't reach 210f the whole day.
Front mount JDL turbo, 3076r size.
Considerations -
Verus hood vents
No oil cooler. Oil not returned to pan, it is vacuumed out of the turbo by the rear cam (fa20 wrx style)
Entire a/c system removed, including condenser
3" thick bar and plate Garrett FMIC covering entries radiator, pushed back as close to the radiator as possible.
FRS front bumper, plastic grille intact
Truefocus fab crash bar, stock crash bar removed
Stock radiator
Stock coolant hoses
Mishimoto slim fan shroud and fans
Factory Toyota coolant
PTP turbo blanket
DEI black fiberglass wrap on whole downpipe
Turbo manifold ceramic coated
Turbo wastegate recirculated into exhaust.
I believe that the top 4 largest impacts here are-
Removing a/c condenser - much less air restriction in cooling stack
Mounting intercooler close to radiator - Air doesn't go stagnant between them while in motion
Hood vents - this is critical for this platform in any use capacity
Recirculating wastegate - not dumping hot exhaust under the engine in open air is HUGE
My car absolutely has not seen extended heavy load and I am not saying that my car would not overheat under other circumstances. But to be able to hotlap autocross on airport tarmac on a 90 degree day with not a cloud in the sky? This is a great recipe for a street build. Just wanted to give someone in the future some ideas.
Old 08-05-2026, 08:54 PM   #826
RongTurnRacing
RongTurnRacing's Avatar
Drives: 2013 Subaru BRZ Turbo
Considerations -
Verus hood vents
No oil cooler. Oil not returned to pan, it is vacuumed out of the turbo by the rear cam (fa20 wrx style).......
How are you vacuuming the oil? Are you using the automatic transmission vacuum pump or are you using some other contraption? I know PTuning has done this kind of thing but they won't sell any of their parts individually.
Just curious.
RongTurnRacing is offline   Reply With Quote
any serious benefit Heat Tapes? Djen Engine, Exhaust, Transmission 22 02-18-2014 03:20 PM
Heat bad for your car? Ways to cool it? BushMan Scion FR-S / Toyota 86 GT86 General Forum 35 08-01-2013 10:15 PM
Misfire with heat? bigjake Issues | Warranty | Recalls / TSB 2 04-28-2013 09:02 PM
Do I Need a Heat Shield? arleewa Engine, Exhaust, Transmission 1 01-08-2013 06:37 AM
Overpipe Heat question Amadeus Engine, Exhaust, Transmission 5 12-19-2012 01:18 AM
