Old 03-13-2020, 02:14 PM   #1
Bach415
Bach415's Avatar
Drives: Whiteout FRS
Gauging Interest:Vented Fender Fins
Hi all,
Just trying to see if people were interested in creating fender fins that are similar to the GRMN 86 fender fins. On their fb, Verus engineering (@VerusEric) mention that if there was enough interest, they will consider designing and producing it. Will be made in carbon fiber as I was told.
The GRMN 86 fender fins are essentially made for aero + heat ventilation from the engine bay through the sides from the looks of it.
Based on the old vented BRZ fender trim thread (https://www.ft86club.com/forums/showthread.php?t=70815), having a vented fender trim does seem to have some effect on the heat situation in the engine bay. Not sure if having to cut out the actual fender vs just having the trim vented makes that much of a different in heat ventilation.
Even on Eric's previous account in that thread, he did mention that he thinks it should be functional based on their CFD research (https://www.ft86club.com/forums/show...3&postcount=32)
Bach415 is offline   Reply With Quote
Old 03-13-2020, 03:02 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
Don't you need a hole into the engine bay for it to vent?
Old 03-13-2020, 03:16 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Correct, you need to cut the fender a bit to maximize the heated air out from the engine bay. Even not cutting it, it does reduce a tiny bit.
Also need to make check off few things.
1. Rust - When you cut the fender, you need to make sure to treat the cut area, so rust won't happen.
2. Flow - Like you seen in the GRMN ver, it's a mix of TRD and STI. If you just do zenki BRZ style fender vent and hole, it create unnecessary flow (or whatever one of GRMN engineer told me).
3. Water/liquid coming in - Everyone wants this vents... but not everyone live or drives in the place that's ideal for this car. If we don't have close option, we'll not only get rust on the fender, but on the frame or even battery.
Just my 2yen
Old 03-13-2020, 03:16 PM   #4
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Would love this if it didn't mean taking a sawzall to my inner fender. Cheap options for a replacement garnish are always welcome though. I would I could afford $200 for better looking fender garnishes, but none are available.
Old 03-13-2020, 03:19 PM   #5
StraightOuttaCanadaEh
Wes
I'm in!
Instagram: @gt86ws
Old 03-13-2020, 03:35 PM   #6
amcp1
Drives: frs
Interested. If I keep mine its gonna be a track car so this would help cooling.
amcp1 is offline   Reply With Quote
Old 03-13-2020, 08:49 PM   #7
Bach415
Bach415's Avatar
Just my 2yen
Well maybe Verus can also make an attachable block off plate for those who live in conditions where it is needed.
See above in red. I'm pretty sure on the GRMN 86, that hole itself on the fender is not even widen/made bigger. still most likely the same default size. At the end, there will be some kind of functional effect which is better than nothing
Old 03-13-2020, 09:19 PM   #8
churchx
churchx's Avatar
Drives: 2014 GT86
I'd love such, if they had both design features, functional vents and fin to direct airflow more optimal around side mirrors.
These GRMN looked favorite to all the aftermarket fins out there that i've seen for twins, looks wise and functionality wise .. their price though is a bit .. slightly .. on high side .
(IIRC P/Ns 75041-18010 & 75042-18010 for $486 each, and possibly price w/o emblem & mesh, and that's before adding in importing fees).
With this design imho there will also be less issues with rain getting in. Most of that will be guarded off by fin when parked, and by pressure of air venting out, when driving.
Old 03-14-2020, 06:47 AM   #9
Kodename47
Kodename47's Avatar
Drives: UK GT86
It doesn't look like there is any modifications made and TBH, given the GR86 is just a mildly modified 86 I'd be surprised if there were any changes to the metalwork at all.
Interested depending on cost.
.: Stealth 86 :.
Kodename 47 DJ:
Old 03-14-2020, 10:20 AM   #10
Infinity
Drives: 2016 Scion FR-S
I am also interested. I would prefer just a vent, no winglet on the fender garnish, though.
Infinity is offline   Reply With Quote
Old 03-14-2020, 04:32 PM   #11
SuperTom
SuperTom's Avatar
Drives: C5, GT-86, '24 Colorado TrailBoss
Not committing but interested. I already have CF fenders so cutting an air release hole will be a little easier for me. Obviously cost will be a factor im not paying GRMN prices
SuperTom is offline   Reply With Quote
Old 03-14-2020, 05:06 PM   #12
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Interested depending on price. I am not above cutting anything on my car
Old 03-15-2020, 12:55 AM   #13
Bach415
Bach415's Avatar
Prova makes just the vented brz style fender trims. According to ichi, he said that grmn engineer says that just having a vent there will disrupt the airflow. How it does I can’t tell you. The grmn 86 fender fins are made to redirect that airflow and still have ventilation.
Even with interest. It al boils down to verus engineering. I’m pretty sure they can design something functional and possibly good looking.
Yeah I would be too. If I recall, the part number for that fender is the same as the original car. I’m pretty sure it will probably cost less than the grmn 86 fender vents which is like 1300 shipped.
Old 03-15-2020, 05:31 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
BTW, IF Verus will design/make .. i'd highly suggest to release some initial designs and put up to vote. I might be wrong, but i gauge that potential customers will decide to buy or not 80% by looks. And if they will look well/better then alternatives by taste of majority, not sure if it will pay off to make one by those way less numerous that are after function. There are many fender garnishes out there, i dislike looks of 3/4th of those. It would be unfortunate to see yet another made that will lay on shelves. While i am interested in GRMN-like designed at affordable prices, i don't think i'm commited to buy one i'd dislike looks of. And as looks are very subjective thing, there is no way to find out but public vote on several initial designs.
TRD Style Fender Garnish Aero Fins and Fender Blades Taco Man in HD Exterior Parts (Aero, Lighting, Etc.) 2 10-14-2018 06:25 PM
Gauging interest in ACE 150- Type B olsonpg Canada Classifieds 3 07-12-2016 07:10 PM
Gauging Interest ISC Suspension Announcements, Contests, Giveaways 17 04-03-2014 09:44 AM
Jdm headlights - gauging interest Hawk77FT Exterior Parts (Aero, Lighting, Etc.) 7 03-31-2014 09:38 AM
Gauging Interest: LED Side Fender Garnish Lamp 86_ZN6 Cosmetic Modification (Interior/Exterior/Lighting) 31 12-19-2013 10:39 PM
