Old 04-12-2016, 10:22 AM   #799
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Originally Posted by rhythmM View Post
Hey guys, what tune is everyone running on their cars with this kit? Just wondering because I recently took mines off to take my car into warranty. Hoping to reflash back with something someone thinks is better.
Edit: or most efficient
I'm running shivs e 85
Installed Mods:
Old 04-12-2016, 11:59 AM   #800
WNDSRFR
Drives: FR-S,GTI
Originally Posted by Gums View Post
Check the 3 connections to the compressor motor.
My voltmeter wasn't dropping below 26v yesterday. Noticed the black connector wasn't connected properly and black deposit on the terminals.
Red connector, whilst fully connected, was getting hot enough to melt the cable cover.
Will see how it goes tomorrow.
Totally agree with Gums. This is exactly what happened to me. Meter wouldn't drop below 26 and no power. I reconnected the wire AND taped them and no harm done.
The Following User Says Thank You to WNDSRFR For This Useful Post:
Gums (04-12-2016)
Old 04-12-2016, 01:04 PM   #801
Urmyson
I recalibrated the throttle and that helped somewhat, drops down to 24v now. I hooked up the OFT and monitored the boost and it never went over 1.5(would always hit a little over 4 with the switch). Keep in mind everything worked fine with the foot switch yesterday. I want to try editing the map to run the ESC at 100% when it's WOT the entire time just to check if it's the map.
Is there a guide on how to edit the activation points?
Urmyson is offline   Reply With Quote
Old 04-12-2016, 01:26 PM   #802
DAEMANO
Time Traveller
Also running Shiv's e85 ESC tune. It's pretty darn good.
Old 04-12-2016, 01:34 PM   #803
Urmyson
Figured out the edit map part going to test it out and see what happens.
Old 04-12-2016, 02:00 PM   #804
Urmyson
Originally Posted by Sojhinn View Post
That means the throttle is not mapped correctly.
There's a way to do that in the procede app.
So it feels like it's pulling really hard, but the volt meter is still not dropping past 25-26. All the connections look good. Does your volt meter go down to 18-22 when going WOT?
Old 04-12-2016, 02:01 PM   #805
Sojhinn
Sojhinn's Avatar
Phantom FTS Electric Supercharger Owners Thread
Mine drops to 22. What's your boost? That's important
Installed Mods:
Old 04-12-2016, 02:53 PM   #806
Urmyson
Boost is still not going much over 1
Old 04-12-2016, 03:01 PM   #807
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
I think people are running the Open Flash tune, you'll have to contact sales@openflashperformance.com
with your Cal ID and ask for one.
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post:
rhythmM (04-12-2016)
Old 04-12-2016, 03:10 PM   #808
Urmyson
There have been multiple people utilizing usb to serial adapters. Several of whom o have helped.
The procede checks the files after loading, so it should be fine. But if you don't trust my word for it you can wait for @Shiv@Openflash . (Not trying to be mean or anything here. I understand being conservative.)
As for my procede tune here you go!
https://drive.google.com/open?id=0B1...kxNcUdvWGtqMG8
Since you have the serial procede follow this after loading the map.
https://drive.google.com/open?id=0B1...VlGOG5lV1dqWE0
https://drive.google.com/open?id=0B1...G5NRC10a2FoenM
I just found this post you put up a few months ago. I have not changed the Fuel Control like you have in the pics. Could that be the problem?
Old 04-12-2016, 03:21 PM   #809
Sojhinn
Sojhinn's Avatar
Possibly give it a shot.
Installed Mods:
Old 04-12-2016, 04:07 PM   #810
Urmyson
I think the only boost I'm getting is from the drag reduction vacuum tube. I'm going to resolder the signal wire when i get home and see what that does.
Old 04-12-2016, 04:15 PM   #811
Sojhinn
Sojhinn's Avatar
What version of procede do you have? Does it have a serial port or usb?
Installed Mods:
Old 04-12-2016, 04:59 PM   #812
Urmyson
Serial
Resoldering it didn't help. Right now I don't think its engaging the esc at all. Not sure where to go from here. The procede software reads the rpm's and and throttle.
Jackson Racing Supercharger Owners Thread enivid Forced Induction 6049 06-25-2026 10:40 PM
Full throttle Electric Supercharger Build Thread fenton Forced Induction 11315 04-07-2025 06:42 PM
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
phantom supercharger restrictions? Shinigunz Forced Induction 12 05-13-2014 03:28 AM
Drift-Office : Phantom Supercharger - Tuned! Drift-Office Forced Induction 67 10-25-2013 09:51 AM
