Old 09-28-2014, 05:51 PM   #799
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Calum View Post
What's your email because I've sent bill two emails already.
Also having a spread sheet with that info on it might make things easier for every one.
Hi Calum,
I sent you an email on August 15th 2014. Please check your spam, as it has the latest version 5.33 and the evap codes are all active.
I am resending, but please check your spam and make sure my emails are not going into them.
Cheers,
William Knose
Old 09-28-2014, 05:59 PM   #800
Calum
That Guy
Drives: 2013 asphalt FRS MT
Originally Posted by DeliciousTuning View Post
Hi Calum,
Cheers,
William Knose
I got that email. My concern is that while running that file the car idles at 2500 rpm on cold starts.
Old 09-28-2014, 06:04 PM   #801
DeliciousTuning
Originally Posted by Shneegle View Post
Do the Stage 2 tunes have the EVAP system switched off? I need to get an inspection very soon and solving the issue with the CEL helps but with a not ready for both the header and EVAP I wont be able to pass inspection either. Possible to get a tune file that I could set for inspection then put the normal tune back in?
Hi,
OK, everyone starting immediately unless specifically told in your order, all check engine lights stay ON. I tried to be helpful and all it has done if cause more problems on our end. I will make a note on the website as such.
As for your tune, your current tune as I reviewed it has the EVAP codes active which was sent to you in August.
Cheers,
William Knose
Old 09-28-2014, 06:06 PM   #802
DeliciousTuning
Originally Posted by texasbound972 View Post
Okay so I guess I need to find someone with a stock pulley and buy a laptop to reset the ecu.
We can try playing around with getting to idle smoother, I assume when the load gets heavy is when it dips. Correct?
But we would need to charge a service to adjust it. Or if you want to come by the shop we can see about dialing it in person.
Cheers,
William Knose
Old 09-28-2014, 06:17 PM   #803
DeliciousTuning
Originally Posted by post_break View Post
From the looks of it, and my EVAP CEL for signal high and low signal, did you just turn on the evap? I have my AEM wideband connected to that signal, I just need evap to show ready. I still can't pass inspection with this tune.
P0452 and P0453 codes.
I have a tune from a different vendor that shows EVAP as ready, in my current configuration with AEM connected to that wire, just need to get that on your tune.
Hi,
I just checked your tune and it has everything active with respect to the EVAP codes as it should be from the factory. It looks as though we did shut off a couple other codes though that relate to Mass Air Flow Limits but that is about it. I am not sure how that would affect it.
Are you sure you are on the latest tune with the EVAP codes active? I will resend the email I sent on Sept 8th.
Cheers,
William Knose
Old 09-28-2014, 06:28 PM   #804
post_break
Professional Smartass
post_break's Avatar
Drives: White Out FRS
Hi,
Cheers,
William Knose
Yep that's the same tune I ran and threw those codes. I have the aem wideband analog signal wire connected to the rear evap sensor, which is why those codes are being flagged. Custom map O result.
I can't connect the wideband to the rear o2 input because I have flex fuel connected to that input.
Same car, same setup, your newest tune you resent vs other tune from someone else. As soon as I fire up the car it throws evap codes high low voltage. Which makes sense because there is no evap voltage, its the ethanol sensor voltage and the car is like wtf.
I will try the tune you just sent me and report back. Maybe the logic for the evap needs to be adjusted so any voltage is in the normal range? Maybe that's how the other tuner does it?
post_break is offline   Reply With Quote
Old 09-28-2014, 06:50 PM   #805
DeliciousTuning
The tune was throwing check engine lights for P0452 and P0453?
OK, understand now. Sorry I usually just shut off all the evap codes (14 in total) for FlexFuel as we have seen that down the road (1000 miles or more) you can possibly get other evap codes, such as P0451 or any of the other 11 evap codes.
In total there are 14 different codes, as we shut them all off because of the situations we have seen above. Rare but they happen.
Cheers,
William Knose
Old 09-28-2014, 06:53 PM   #806
post_break
post_break's Avatar
Cheers,
William Knose
Awesome! Sorry for being such a pain in the ass, I had no idea there were so many codes. My setup is definitely one of a kind which makes it annoying. I will flash this new tune and report back!
Old 09-28-2014, 06:59 PM   #807
DeliciousTuning
Well thank you for being patient, and same goes to everyone else. Thank you.
Things are bit stressful with the new baby arriving tomorrow. And basically I will be our of commission for the week. So I am trying to get whatever I can wrapped up before then.
When we return, we will have a lot of new stuff.
1. FlexFuel Kit Release (Coming SEMA 2014)
2. Android Head Units (for custom spec Delicious Android gauges)
3. Flash and Go Updates
4. Supercharged Stroller
Cheers,
William Knose
The Following 6 Users Say Thank You to DeliciousTuning For This Useful Post:
Calum (09-28-2014), fasteddy (10-23-2014), JDLAutoDesign (09-30-2014), Lawnik (09-28-2014), MINOCIN (09-30-2014), post_break (09-28-2014)
Old 09-28-2014, 07:21 PM   #808
Calum
That Guy
What's the chances of things like time alignment and active crossovers in that android head unit? Something like that might get me to finally finish my stereo install.
Old 09-28-2014, 07:52 PM   #809
texasbound972
USMC
texasbound972's Avatar
Drives: 2013 FR-S 6-MT Raven
Cheers,
William Knose
I will see you tomorrow afternoon then. Thanks!
texasbound972 is offline   Reply With Quote
Old 09-28-2014, 09:20 PM   #810
post_break
post_break's Avatar
Cheers,
William Knose
Well I thought we finally had it. Flashed the tune, no codes. Evap will still not go to ready. Turned the car off and on again, P1449 code (evap) came up. Cleared the code, didn't come back, Evap still won't go to ready. Now I've got a constant P1449 CEL.
I mean if we can't get this fixed, I guess I can take my glove box out, unplug my harness, go pass inspection, and then plug it back in. It's just those connectors are a bitch to get to.
We'll figure something out, I don't need to pass inspection soon so I'm not in a rush.
Old 09-29-2014, 11:06 PM   #811
texasbound972
USMC
Sorry Bill I really thought I'd be able to make it out today. Plans changed at the range and didn't get off until 5pm. When do you guys close?
Old 09-30-2014, 01:26 PM   #812
post_break
post_break's Avatar
Hope the baby and mom are doing good!
I decided to say screw it, I took the harness out and now evap is hooked up as if stock. The latest tune you gave me does not go to ready, but I think the tune before that will work just fine. I will test it and report the all clear. It just kind of sucks because I paid for the work so I could log my wideband in ecutek. But if I have to rip that thing out every time I need to pass inspection it just isn't worth it.
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-19-2013 05:58 PM
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) DeliciousTuning Announcements, Contests, Giveaways 6 09-19-2013 05:55 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK DeliciousTuning Announcements, Contests, Giveaways 5 08-26-2013 02:33 PM
