#785 |
USMC
Drives: 2013 FR-S 6-MT Raven
Agreed. I'll pay attention to it next time I press in the clutch. I think I might have thrown away my oem pulley.
#786 | |
PhoneFlash by EcuTeK
Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:27 PM. |
#788 | |
Professional Smartass
Drives: White Out FRS
P0452 and P0453 codes. I have a tune from a different vendor that shows EVAP as ready, in my current configuration with AEM connected to that wire, just need to get that on your tune. |
#789 |
That Guy
Drives: 2013 asphalt FRS MT
Any chance of getting my cold start rpm fixed guys?
#790 |
Drives: 2013 FRS, 2024 Trueno
Do the Stage 2 tunes have the EVAP system switched off? I need to get an inspection very soon and solving the issue with the CEL helps but with a not ready for both the header and EVAP I wont be able to pass inspection either. Possible to get a tune file that I could set for inspection then put the normal tune back in?
#791 | |
| The Following User Says Thank You to DeliciousTuning For This Useful Post: | texasbound972 (09-28-2014) |
#792 | |
#793 |
Calum,
Please send me an email with your full name, dongle id, and delicious user id. We'll get an update out. Sincerely, Delicious Tuning Last edited by DeliciousTuning; 04-11-2019 at 05:27 PM. |
#794 | |
That Guy
Also having a spread sheet with that info on it might make things easier for every one. |
#795 |
The Nameless Performance header and exhaust.
#796 | |
#797 | |
Because all clutch's, flywheel's, under drive pulleys have different masses to them there is no one end all solution to making sure the idle is perfect for all configurations. Just not possible. You can attempt a relearn, and the best way to do this is reset the ECU, then turn the vehicle ON and let is idle on it's own for about 5 minutes and never touch the throttle. Cheers, William Knose Delicious Tuning |
| The Following 2 Users Say Thank You to DeliciousTuning For This Useful Post: | MINOCIN (09-30-2014), texasbound972 (09-28-2014) |
#798 |
USMC
Okay so I guess I need to find someone with a stock pulley and buy a laptop to reset the ecu.
| Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 24 | 09-20-2013 03:04 PM |
| Delicious Tuning: EcuTeK Stage 1 or 2 on 91, 93 or E85 fuels | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-19-2013 05:58 PM |
| Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
| Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps | DeliciousTuning | Engine, Exhaust, Bolt-Ons | 1 | 09-13-2013 01:34 AM |
| Delicious Tuning and HG Motorsports: 86Fest Only Special - Take $100 off EcuTeK | DeliciousTuning | Announcements, Contests, Giveaways | 5 | 08-26-2013 02:33 PM |
