Old 06-03-2014, 03:28 AM   #799
JD86
Drives: 2013 Toyota 86 GT
Just be thankful it was only 15 I recently modified my 3 inch exhaust and had my tune updated. There's supposed to be a boost cut in there for 13psi... So I took it to a high speed track for a shake down the next night and saw 20psi on the gauge down the back straight before wussing out lol. Keep in mind this was on stock injectors and fuel pump... But I have access to high octane fuel.
I also had a cracked dump pipe... But that was mostly my own fault. I was running a custom 3 inch front/overpipe setup but had taken out the flex joint in between the front pipe and catback... SO I had no flex at all and when I was pushing it hard at a track day I damaged the turbo gasket and cracked the weakest point in my exhaust system (being the dump pipe).
All part of the fun of running a heavily modified car hard at the track
JD86 is offline   Reply With Quote
Old 06-03-2014, 02:19 PM   #800
protpibe
protpibe's Avatar
For those that are looking for an oil cooler solution, I just installed the Full Blown Motorsports setup and it fits without any ssues.
Old 06-03-2014, 06:24 PM   #801
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
This is an important point - if the exhaust system has no flex joint in the system, the stress of the system flexing from front to rear will likely cause a crack somewhere in the exhaust eventually. One end of the pipe is connected to the engine which moves quite a bit on the mounts, while the rest of it is fixed in place to the body.
AVOturboworld is offline   Reply With Quote
Old 06-03-2014, 10:24 PM   #802
brz2013
brz2013's Avatar
Drives: 2013 wrb brz
For those of you that have the upgraded 8psi actuator....I can make my target boost but spool is much slower than before I installed it....maybe it's to loose?
brz2013 is offline   Reply With Quote
Old 06-04-2014, 06:05 AM   #803
onzippy
Drives: 2014 FRS
I didn't create it but this video was helpful to me in adjusting preload and getting the rated psi of the actuator. In the end I also added a boost controller because getting to the avo turbo for adjustments is a PITA. The boost controller also helped reduce the spool time which is another reason people install them.
[ame]http://youtu.be/p12g1PpIcjE[/ame]
onzippy is offline   Reply With Quote
Old 06-04-2014, 09:44 AM   #804
brz2013
brz2013's Avatar
Thanks. Ya I think I need to tighten it a couple threads
Old 06-04-2014, 11:20 AM   #805
protpibe
protpibe's Avatar
Here's a couple shots of the FBM install
Old 06-04-2014, 11:22 AM   #806
nataku
Negative Mass
nataku's Avatar
Drives: Orange Metallic AVO Turbo GT86 6MT
Nice thanks for the pics. How's the airflow if you have foglights?
Build thread for my Lovely Lady.
nataku is offline   Reply With Quote
Old 06-04-2014, 11:33 AM   #807
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
This is what I did.
http://www.ft86club.com/forums/showthread.php?t=63231
blackfireball5 is offline   Reply With Quote
Old 06-04-2014, 11:33 AM   #808
protpibe
protpibe's Avatar
I'm assuming it should be fine. I banged on it pretty hard last night on the highway and barely broke 95c (200f). I'm taking it to the track this weekend so we'll see if heatsoak becomes an issue.
Old 06-04-2014, 11:40 AM   #809
nataku
Negative Mass
nataku's Avatar
Originally Posted by blackfireball5 View Post
Thanks for the info. I want to preserve the fog lights if I can but that is pretty cool.
Old 06-04-2014, 11:47 AM   #810
blackfireball5
Thanks!
I ended up buying some LED switchbacks for my turn signals so that I could preserve more of a foglight look while still having those holes for vents.
Wheelwell Profile
Use code TWW-BOO5TED when shopping at Wheelwell to receive 10% off your order.
Old 06-05-2014, 01:25 PM   #811
GeekB
Drives: 2013 BRZ Limited
I recently got my v1 kit installed back onto my car with full 3" turbo back exhaust from AVO. The left exhaust tip is sticking out about an inch or two more than the right exhaust tip. Sent Paul pictures and he forwarded them to the factory.
I'm currently running the base map given to me from Paul, but had some issues when I tried to take it to get tuned. It seemed to run fine over the weekend but the day I drove to the tuning shop, my CEL came on. The code was P0171 and the tuning shop spent about 4 hours trying to diagnose the issue. They swapped the MAP sensor with other aftermarket ones but the code would not go away. I ended up reflashing back to Paul's base map and the code went away. Drove home and my car ended up dying when I exited the freeway. I was able to start it back up after and drive the rest of the way home.
I'm taking my car back to the shop that did the install and they're going to take a look over everything. I think there's a turbo header gasket leak, so Paul is sending me a gasket and hopefully fixing the leak will fix the issue. Then it'll be back on the dyno.
GeekB is offline   Reply With Quote
Old 06-05-2014, 01:36 PM   #812
protpibe
protpibe's Avatar
What was the shop using to try and tune it? Are they running ECUTEK?
Also, does the exhaust have any sort of adjustment on the hangers? I know the Perrin I run has hanger locks to be able to adjust the position of the exhaust.
edit: Also, that code means that it was running too lean, I'm guessing it may be a problem with the install. Have you tested for boost or vacuum leaks?
avo, avoturboworld
Innovate (Sprintex) Supercharger Owners Topic DarrenDriven Forced Induction 9139 12-29-2023 10:58 PM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
Not another need to drive topic Sargy Mid-Atlantic 5 11-27-2012 12:18 PM
Can you close the topic please? Standardsuspension Brakes, Suspension, Chassis 14 06-26-2012 05:14 PM
