| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: Scion FRS Firestorm
DIY: Making Air Vents Out Of The OEM Fog Light Bezels
I purchased the OEM foglight bezels and thought over how I wanted to go about making these vents. The purpose mainly was for my oil cooler on the passenger side, but this could just as easily be used for brake ducts.
OEM Fog Light Bezels ![]() First thing I did was trim off the small lip on the inside of the bezel. I wanted to make a flat surface to work with on the inside. ![]() I used a box cutter. It sliced very easily. ![]() I purchased some mesh gutter guard from Lowes. It was 3 bucks for a sheet like this. ![]() Next I cut a square out of the mesh large enough to cover the hole and have some extra around it using some tin snips. The hole is 4 inches across. ![]() Next thing I did was use the small tab on the inside of the fog light bezel as a fixing point. I cut a small hole in the mesh for it. It actually did a lot to keep the mesh from moving around. ![]() Then I molded the mesh to the shape of the inside of the bezel so it sat flat. I also trimmed some of the mesh that was in the way, making sure not to cut off the corners of the square, as that is how I secured it to the inside of the bezel. ![]() I used three large globs of liquid nails at each corner of the mesh. The tab on the inside of the bezel is also still helping stabilize the mesh. ![]() Finished product after the liquid nails dried. ![]() On car! ![]() Close up! ![]() Hope this helps someone.
| The Following 8 Users Say Thank You to blackfireball5 For This Useful Post: | glamcem (04-13-2014), hmong337 (04-15-2014), J. O'Grimm (04-21-2014), Lonewolf (12-06-2020), Mikepage (04-21-2014), neutron256 (04-15-2014), OjiGeorge (04-19-2014), tato.valverde (09-09-2016) |
Drives: 2022 BRZ Limited
very cool, I recently purchased some ducting hoses and spindles for my BRZ and was wondering where I could get some mesh
Thanks again
No problem! That mesh works perfectly. Sturdy, painted black, yet moldable and easy to cut and shape. And cheap. Haha.
| The Following User Says Thank You to blackfireball5 For This Useful Post: | jeepmor (01-22-2021) |
#4 | |
| The Following User Says Thank You to blackfireball5 For This Useful Post: | glamcem (04-13-2014) |
Looking very subtle and good
it seems like you have an Fmic, what kind of FI setup are you running?
Full blown kit.
| The Following User Says Thank You to blackfireball5 For This Useful Post: | glamcem (04-15-2014) |
Drives: Moped
Thanks for the pics! I always wondered why no vendors offered something ready-made like this because there are so many folks putting on auxiliary coolers (like oil/tranny coolers) now...
For sure.
Drives: Asphalt 2013 FR-S
Looks nice, good job
Where did you buy the oem fog light bezels from, the dealership? The FRS has the T (space invaders) pseudo vents, which are a pain in the ass to cut. I had my FRS bumper off yesterday while working on my oil cooler and I tried to do this as well with the stock vents. I started with a dremel and various bits but the plastic would just melt and gunk it up. I ended up scuffing the plastic pretty badly using the dremel before switching to a box cutter. I should've started with the knife first
#10 |
You can get the OEM bezels from diode dynamics for 40 bucks. Yeah, i didn't want to have to deal with all the work of cutting those shapes out.
Edit: Updated link. http://www.diodedynamics.com/store/2...ezels-set.html Sent from my Nexus 5 using Tapatalk
| The Following User Says Thank You to blackfireball5 For This Useful Post: | MINOCIN (04-15-2014) |
#11 |
#12 |
Drives: White 2013 FRS
This is exactly what I was looking for. Thanks you!
| The Following User Says Thank You to OjiGeorge For This Useful Post: | blackfireball5 (04-19-2014) |
#13 |
I've been noticing that they have been pushing in a little from the wind. Either i didn't let the liquid nails dry long enough or i should have used another glue of some type.
Anyone have any better ideas than liquid nails ? Sent from my Nexus 5 using Tapatalk
#14 |
I'm planning to use epoxy when mine come in
| **Toyota 86 Fog Light Bezels $34.9, 86 Arm Rest, GT86 Badge, Fog Light Set for $112.9 | nigel-jdmparts | Exterior Parts - The Rest | 524 | 02-28-2016 11:24 AM |
| WTB: fog light bezels | natesparxxx | Exterior Parts (Aero, Lighting, Etc.) | 1 | 03-20-2014 12:44 PM |
| Pair of FR-S fog light bezels | speedrye | Exterior Parts (Aero, Lighting, Etc.) | 2 | 02-21-2014 02:28 AM |
| Installing JDM Fog Light Bezels | knewsom32 | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 01-22-2014 02:29 PM |
| Color matched fog light bezels | NyC Zn6 | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 06-05-2013 01:10 AM |
