Old 11-18-2014, 03:14 PM   #7897
TM
TM's Avatar
Drives: DGM BRZ 6MT
Originally Posted by fenton View Post
Are you guys still using e85?
I'm back on 93 now. I just checked again and the washer seems a little loose. Not sure if it happened while I was tugging on it earlier, but I'm going to torque it down when I get home.
TM is offline   Reply With Quote
Old 11-18-2014, 03:19 PM   #7898
robwbright
Drives: '13 BRZ Limited WRB Phantom ESC 1.5
Never was on E85.
'13 BRZ Ltd MT WRB Phantom ESC 1.5
2012 Honda Accord Coupe
2006 Saab 9-3 2.0t
1997 Honda Accord Coupe
1995 Honda Prelude VTEC
robwbright is offline   Reply With Quote
Old 11-18-2014, 03:27 PM   #7899
jwvand02
Drives: 2013 SWP BRZ Limited
I'm still on e85. Had to jump my car this morning as well, and even using about a 1:9 ratio of e85 to gas, I had to crank the car over a ton of times this morning to finally get it to start. The battery was only good for about two full cranks before it wouldn't turn over anymore. I'm thinking about going to 93 when this tank is out as well just to give me the best chance to get moving in the morning.
I checked the terminals and added the washers yesterday, and it didn't really help. One common thread I'm seeing here is aftermarket stereo. I noticed that pulling the fuse helped get one extra crank in this morning, but that really still wouldn't have been enough.
I'm thinking about running a trickle charger on an extension cord through the night. I've ordered an odyssey battery to replace the starter battery but I've gotta get through this week first, as it won't come in until Friday.
2013 SWP BRZ Limted
Innovate Stage 2
E85, Tuned by Moto-East
jwvand02 is offline   Reply With Quote
Old 11-18-2014, 03:28 PM   #7900
robwbright
About 15 minutes of 6 amp charging and it weakly started. Need to figure out what's going on as I can't be charging everytime it gets below freezing.
2006 Saab 9-3 2.0t
Old 11-18-2014, 03:39 PM   #7901
TM
TM's Avatar
Drives: DGM BRZ 6MT
I don't have an aftermarket stereo.
In the meantime, this is what happened to the city an hour west of me: http://www.syracuse.com/news/index.s...ke_effect.html I can't wait to get out of the NE.
Old 11-18-2014, 03:42 PM   #7902
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I don't have the phantom, but I do have an OFT tune with ignition cranking tables that I tweaked myself and I am planning on running e85 straight through winter like I did last year. It is currently a first try start at 35°F in the morning, and the worst it ever has been is a two try start in the single digits.
Luckrider is offline   Reply With Quote
Old 11-18-2014, 03:43 PM   #7903
robwbright
Neither do I, although I do have the sub hooked up. I'm unhooking it completely overnight to see what happens.
2006 Saab 9-3 2.0t
Old 11-18-2014, 03:51 PM   #7904
jwvand02
Any chance you could point to a how-to for this? I have trouble starting even when it's not very cold.
2013 SWP BRZ Limted
Innovate Stage 2
Old 11-18-2014, 03:52 PM   #7905
jwvand02
When I say aftermarket stereo I'm primarily referring to subs or amped speakers. Headunit shouldn't matter.
2013 SWP BRZ Limted
Innovate Stage 2
Old 11-18-2014, 03:53 PM   #7906
robwbright
Gotcha.
2006 Saab 9-3 2.0t
Old 11-18-2014, 04:10 PM   #7907
fenton
Gotcha.
You guys are leaving he SC turned off as well right? Or are you using the auto on feature.
If it really does come down to the battery you can always disconnect your 1.5 conversion and run a bigger starter battery. This is what I did last year.... Its weird because @Bu-Tang has been using the little battery and hasn't had any problems yet.
I'm pretty sure it started in below -10C which is colder than what you guys would experience.
I'll let butang chime in to see if he has been having trouble.
fenton is offline   Reply With Quote
Old 11-18-2014, 04:22 PM   #7908
Luckrider
Luckrider's Avatar
No specific how-to, but:
Start Here: http://www.ft86club.com/forums/showthread.php?t=67310
Check this post which is linked in the first post of the thread above: http://www.ft86club.com/forums/showp...1&postcount=40
Or this one just above that in the same post: http://www.ft86club.com/forums/showt...21#post1444921
For further help, here is a copy of my current ROM. You can try copying the tables I have in mine.:
https://drive.google.com/file/d/0Bz4...ew?usp=sharing
That is based on the 1.42 ROM but the cranking tables are the important part and have my revisions.
Old 11-18-2014, 05:25 PM   #7909
robwbright
It was 15F here last night. That's about -10C. That's really cold for this time of year (it's supposed to be in the 50s again in a couple days), but it's not unheard of. Last winter was particularly bad and temps got below 0F a couple nights.
If it continues to be an issue with the Amp unplugged, it's going to be a little frustrating because when I raised the issue back in the spring before purchasing, everyone that responded assured me it wouldn't be an issue... but hey, every car and battery are different, I suppose.
2006 Saab 9-3 2.0t
Old 11-18-2014, 05:28 PM   #7910
robwbright
Originally Posted by Bu-Tang View Post
This was my cold start after sitting in -30C for 5 days without starting.
I drove mine all winter and when it was -40C with windchill it was a slightly weak start but still fired right up. you will not run into a single issue if you drive your car on a regular basis and dont leave it parked for long periods of time EG: several days outside in -30 or colder in windchill condiditons.
These batteries in -15 will perform just like the factory battery.
Originally Posted by Sojhinn View Post
Honestly guys we argued this a long time ago. You don't need to swap out the starter battery. Its fine. Give it a shot and I know it will work. Im so confident in it that IF I were a little richer I would offer you your money back on the starter battery if it did not work out. I had it sit for 2.5 weeks and it fired up on the first try. Gary had it sit in cold weather multiple times and it worked, and I think Bu-tang is running a audio system on it.
Trust me its fine.
Guess I shoulda pushed for that money back guarantee. LOL.
I'll figure it out.
2006 Saab 9-3 2.0t
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
