Old 09-04-2012, 01:42 AM   #771
Furtive
Furtive's Avatar
Drives: 13' SSM BRZ
Originally Posted by Jidonsu View Post
Video.
I think I just fell more in love with this exhaust
Furtive is offline   Reply With Quote
Old 09-04-2012, 03:21 AM   #772
Neilus
Neilus's Avatar
Drives: GTS 86 6M
Any Overseas customer have tracking numbers yet for their exhaust??????
I was one on the first 20 and still don't have it yet.
I thought they might have been sent out the end of last week.
Neilus is offline   Reply With Quote
Old 09-04-2012, 09:03 AM   #773
VSGTS14
987 Motorsports
VSGTS14's Avatar
Drives: '13 WO FR-S
is there a no cat option? a good resonator in the midpipe helps a lot.
are the mufflers at the ends pretty much hollow?
VSGTS14 is offline   Reply With Quote
Old 09-04-2012, 10:15 AM   #774
Borden
Drives: 2017 BRZ
SRT you have done a nice design, the dyno result is very impressive! But I have a quick question for you. According to some online guide, there's some experiential rules, said there's a best ID of pipe, fit about 60HP per inch^2 for NA engine, for best flow velocity.(http://www.team-integra.net/forum/bl...sure-area.html)
I've read your exhaust uses 2.5" pipe, so I wonder without regard to owner's favor, if your shining head-back exhaust with the stock sized 2.1" OD pipe can actually get a greater power gain? or at least keep current gain(with a lighter weight compare to your current 2.5" one)?
Borden is offline   Reply With Quote
Old 09-04-2012, 11:26 AM   #775
ruskymx
ruskymx's Avatar
Drives: 13 HotLava FRS, 93 4Runner, 97 Taco
Thanks a lot Mo....you just gave me a reason to go into work EARLY! DAMN YOU! lol Just got a text from a guy in my parts dept (I had it shipped to my dealership to avoid possible signature issue) and
ruskymx is offline   Reply With Quote
Old 09-04-2012, 04:52 PM   #776
ruskymx
ruskymx's Avatar
@mike2100, @2forme, @serial gixxer, @Hix, @civicdrivr
For you guys that installed the exhaust already, did you re-use the stock gasket at the header or did you buy a new one? I tried to read through all of the posts again, but it was too many and I started skimming. Just remember someone posting about having a leak at first.
Thanks for the help!
Ruskymx
Old 09-04-2012, 04:58 PM   #777
2forme
I re-used. But I only had like 1500 miles on the car.
Old 09-04-2012, 05:08 PM   #778
serial gixxer
Same.
serial gixxer is offline   Reply With Quote
Old 09-04-2012, 05:13 PM   #779
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Ruskymx
I reused the gasket. I had about 10.3k miles on the car when I installed the exhaust, but figured that it shouldnt fall apart. So far, no leaks.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 09-04-2012, 05:26 PM   #780
ruskymx
ruskymx's Avatar
OK...thanks for the responses. List of the gasket is $31+ but my cost is around $15 or so. Would have to order it and it would be a few days. I only have 3300 on it now so, I 'll just re-use it and see how it goes.
Ruskymx
Old 09-04-2012, 05:29 PM   #781
Jidonsu
Drives: Scion FR-S | 6MT | Ultramarine
I had SRT install mine. I'm guessing they just reinstalled it. How do you know if you have a leak?
Jidonsu is offline   Reply With Quote
Old 09-04-2012, 05:30 PM   #782
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
From what I recall, the gasket problem stems from the removal of your stock exhaust and the installation of your new one in a rushed manor or done too many times.. Mo mentioned that if it has been used too many times, then it is probably warped/done/leaky/whatever the proper word would be.
Ruskymx
Old 09-04-2012, 05:52 PM   #783
ruskymx
ruskymx's Avatar
I'm guessing you would get a ticking like sound by the area where the two pieces connect.
Makes sense. I'll probably order one to have it one hand just in case.
Thanks,
Ruskymx
Old 09-04-2012, 06:00 PM   #784
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
Youd hear and/or smell it.
When I first installed it, I started the car and ran my hand over all the connections while the car was still in the air. I didnt feel any air escaping.
Just make sure you start at the front of the car and don't actually touch the piping, it could be hot.
Parting out HERE
Exhaust System/Exhaust Manifold Removal and Replacement GrimmSpeed DIY (Do-It-Yourself) Guides 52 11-11-2015 09:30 PM
AIRAID FR-S / BRZ Cold Air Intake system Sneak Peak / Development Information AIRAID Engine, Exhaust, Transmission 396 10-04-2012 07:27 AM
Anyone going to Pike's Peak Hill Climb to see Gushi? terrypm Other Vehicles & General Automotive Discussions 3 06-21-2012 02:06 AM
Toyota TMG EV P002 to race at Pike's Peak madfast Other Vehicles & General Automotive Discussions 4 06-08-2012 09:09 PM
Exhaust system: dual or single KiingDavid Engine, Exhaust, Transmission 162 05-04-2012 01:33 AM
