Old 07-04-2017, 12:23 PM   #771
mrk1
Drives: Sterling BRZ Ltd
Originally Posted by Brzzee View Post
I noticed the 3.7 water-to-oil cooler is off the engine. Could you please post a picture of its rear (i.e. the mating surface between the cooler and its mount on the engine)?
I'd like to compare it to the 2012+ 5.0 Boss Mustang cooler kit I have on my bench for my BRZ oil system cooler project (2 qt accusump install, filter relocate, and cooler).
The Mustang cooler has water inlets that are bent as well as the block mounting flange has a 270 degree lip that protrudes from the mounting flange's surface. The straight inlet/outlet and a flat rear flange would make my life much easier.
Appreciate the help as I can find nothing on the Net that shows the rear of the cooler.
If it will be a better fit for my adapter, and you're not going to use it I'll buy it from you.
Thanks
My cooler flange looks just like the photos posted above. If you want it its yours. I did damage the center bolt thing as I didn't have an allen big enough, I bet you can just reuse yours.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 07-04-2017, 01:15 PM   #772
Brzzee
Brzzee's Avatar
Drives: 2015 Subaru BRZ WRBP Limited 6MT.
Thanks for the quick come back!
That flange is such a pain. But I might be able to make better use of the straight tube configuration.
I don't have a spare coupler bolt. Just the one that comes with the $140 Boss kit.
I can get another bolt for $12 or so. Normally the bolt comes with the cooler for a total of about $95 shipped for the best on-line Ford price.
My commercial address zip 75088. What do want for the cooler shipped to me?
I can process the order through your website if you tell me how. Or I can just mail you a check to keep costs at a minimum. I'm not in a hurry, as I must finish healing from last week's gut surgery before I bend over a fender in the garage. A couple of weeks.
Brzzee is offline   Reply With Quote
Old 07-04-2017, 01:36 PM   #773
mrk1
PM'd
The Build Thread
Old 07-04-2017, 01:52 PM   #774
mrk1
Pretty impressive these stock manifolds flow over 300hp, still need to go.
The last test fit showed the pan still needed trimming, this is all I can take out of it so have to make it work from here.
The Build Thread
Old 07-08-2017, 07:54 PM   #775
mrk1
Shaved a few inches and gained a mile
The Build Thread
Old 07-08-2017, 08:59 PM   #776
Cloud
Porsch-AH
Cloud's Avatar
Drives: 2007 Porsche Cayman S
Interesting, I don't think I've seen this swap yet..
Cloud is offline   Reply With Quote
Old 07-22-2017, 07:54 PM   #777
mrk1
With the motor in place its obvious the factory clutch master wont work at all. I made the call to ditch the stock brake setup in favor of a manual non ABS setup.
I made a mockup bracket to mount both the brake and clutch master cylinders. A pair of Tilton master cylinders will do the trick.
With the clutch master now moved over about 5" I had to dissect the pedal box and shorten that 5" to match.
The Build Thread
Old 07-23-2017, 05:32 PM   #778
mrk1
New motor won't let me run a normal strut brace so I came up with these WRC inspired supports.
The Build Thread
Old 07-24-2017, 10:17 AM   #779
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Thought about getting rid of ABS as well. Doesn't work on my car anyway haha. Really enjoying these updates. Looks great as always.
DustinS is offline   Reply With Quote
Old 07-24-2017, 10:32 AM   #780
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Clean work.
venturaII is offline   Reply With Quote
Old 07-24-2017, 04:47 PM   #781
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
pretty nice man, keep it up.
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 07-24-2017, 06:34 PM   #782
mrk1
So much clutter, if it wont work no sense in keeping it around.
The Build Thread
AMR Performance: How to remove the factory bumper (walk-through images inside) AMR Engine, Exhaust, Transmission 9 04-10-2013 07:45 PM
86 Modelista walk around and GT Limited SoCal_86 Scion FR-S / Toyota 86 GT86 General Forum 3 04-24-2012 11:53 AM
