Old 08-01-2017, 02:11 PM   #743
Corley
Drives: 2014 Stock frs
Yea the dry sump would be mess and $$$. I was out on the car tried a -8 male to -8 female ORB. To close to the pan to turn the fitting in . I can get them cheep like $7. So looks like banjo bolts. I haven't contacted anyone yet to see what the flow is on them. Or machine the pan side to have ports and weld the bottom ones shut.
Corley is offline   Reply With Quote
Old 08-01-2017, 06:04 PM   #744
M1K3
M1K3's Avatar
Drives: vrooom...
I am going to have to tackle this issue too and I was looking at these ultra low profile 90 fittings:
M1K3 is offline   Reply With Quote
The Following User Says Thank You to M1K3 For This Useful Post:
DustinS (08-02-2017)
Old 08-01-2017, 09:48 PM   #745
wooly35
Drives: 2014 Scion FR-S LS3
@Dustin.... do the CAI, you wont be sorry. I had quite a bit of hesitation with where I had the MAF(right next to the air filter) during highway speeds, but had a decent amount more power during WOT. So I swapped back to our original design, just to see if I still had hesitation at cruising speed. Car drove smooth.
So, I reinstalled the CAI, move the MAF into a strait section...Car runs smooth at cruising speed...the increase in power was also more noticeable once I figured out the MAF problem.
Do the CAI, you wont be sorry. lol
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
The Following User Says Thank You to wooly35 For This Useful Post:
Old 08-02-2017, 05:30 AM   #746
cf6mech
Drives: FRS Silver LS1 swapped.
Dustin, watching in great interest with the sway bar delema.....i have been at this point for about a year now....
cf6mech is offline   Reply With Quote
The Following User Says Thank You to cf6mech For This Useful Post:
Old 08-02-2017, 11:27 AM   #747
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Yeah I am going to be working on moving mine out from behind the radiator. Looking at what bends I need. I need to grab a slim fan set-up. The factory one is quite large and looks out of place with everything else.
@cf6mech Will do! I am going to see if I can hold the engine from the top and drop the subframe. Take the oil pan off, check everything from underneath and modify the pan. Also going to ask a local shop about a tubular subframe to give me extra clearance all around.
DustinS is offline   Reply With Quote
Old 08-02-2017, 01:56 PM   #748
all4spl
Pretty sure someone is currently offering a tubular subframe already for the car
all4spl is offline   Reply With Quote
Old 08-02-2017, 02:13 PM   #749
mrk1
Drives: Sterling BRZ Ltd
TSS fab makes a tubular subframe with LS mounts
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Old 08-02-2017, 02:24 PM   #750
DustinS
DustinS's Avatar
I went and looked at their website. Kind of chuckled.
Old 08-02-2017, 03:20 PM   #751
all4spl
haha It's listed as V8 includes the urethane mounts that attach to the motor
Old 08-02-2017, 03:23 PM   #752
DustinS
DustinS's Avatar
Mhmm. I would still need to modify it as I am most certain the mounts are not in the same location as the vorshlag.
Old 08-02-2017, 03:24 PM   #753
wrxdriver2002
Drives: 2015 Subaru BRZ
TSS Does make a tubular subframe. It was built around my car. The placement of the engine is a little bit different than all of the other kits. If it doesn't work for you, it's easily modified.
wrxdriver2002 is offline   Reply With Quote
The Following 2 Users Say Thank You to wrxdriver2002 For This Useful Post:
all4spl (08-02-2017), DustinS (08-02-2017)
Old 08-02-2017, 04:51 PM   #754
all4spl
Can you shed some info on a few things with it?
A: heater hoses? still have them?
B: sway bar bolt up?
C: Height requirement?
Old 08-02-2017, 05:01 PM   #755
wrxdriver2002
My engine is an LSA (2013 ZL1 Camaro), so it required me cutting a hole in the hood for supercharger clearance. I can't answer height requirement for you.
Sway bar does not bolt up for two reasons. 1st being the long tube headers. I had to cut the sway bar bushing brackets off of the sway bar mount to get the sway bar on there. I don't know if an OEM sway bar would have fit because of the oil pan. I'm running a stock LS2 GTO pan with an improved racing baffle.
I absolutely still have heater hoses and will be finishing up the AC soon. The AC lines are going to require modification for a couple of reasons. First being the GM compressor, second because I am using the AC to cool the water for the supercharger, and third because the OEM lines hit the engine with how far they protrude from the firewall. As soon as we figure out the AC canbus stuff, we can get the cabin AC system working.
The Following User Says Thank You to wrxdriver2002 For This Useful Post:
Old 08-02-2017, 05:19 PM   #756
all4spl
Are you running a sway bar? What does that look like? Also what are you doing for transmission and transmission mounts?
Sorry for the thread jack! Hope this helps multiple people out
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
