Old 12-26-2012, 12:01 AM   #715
rikdrt1
Hypnotic FRS Member
rikdrt1's Avatar
Drives: FR-S [Raven]
Haven't seen mention of Pilot Super Sports, which should come into the equation if we're talking about performance summer tires.
in the end, i ended up being talked into these tires. After all, if they are good enough for the Cayman -- they should be more than enough for this car ! 225-45/17s all the way around and slight drop in mpg too i noticed. sucks a bit but grip is amazing.
MotegiRacing - TRD Racing -OemAudio++- Michellin Pilot SuperSports- Greddy -FiveAxis - SparksScion - BlueBat Overlays -Pioneer -SWIFT Engineering Sports- Evasive Motorsports-
SoCAL
rikdrt1 is offline   Reply With Quote
Old 12-26-2012, 01:44 AM   #716
OrbitalEllipses
Drives: Attitude
What other tires have you driven on? I'm seriously considering these if I can get rid of my low mileage KDW2. I'd be interested knowing your thoughts on grip and DD-ability; are they noisy? Wet grip? Etc.
Old 12-26-2012, 04:50 AM   #717
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Originally Posted by i_4got View Post
I tried researching the forums and learning, but all these numbers are making my head hurt and I'm not entirely sure which numbers to match to ensure fitment.
Can anyone confirm if these will fit the stock tires?
http://www.ebay.ca/itm/17X9-ROTA-GRI...03d839&vxp=mtr
Wheel size: 17x9
Bolt pattern: 5x100
Offset: +30
If they fit the stock tires, does that mean the stock lug nuts will fit too? If not, how do I find out which aftermarket lug nuts to buy?
Rota grid 17x9.0 +42 5x100 is more ideal than offset +30 for this car, its been done already http://www.ft86club.com/forums/showthread.php?t=14934
adprokid is offline   Reply With Quote
Old 12-26-2012, 05:59 AM   #718
ill86
VehicleDynamicsSpecialist
ill86's Avatar
Drives: iG FR-S
Originally Posted by FRSGT86 View Post
All right experts here's what I'd like to run:
18x8.5 45mm offset with 235/35 front
18x9.5 45mm offset with 255/35 rear
Stock suspension until I can save up for a set of coilovers.
Comments, issues, concerns?
And thanks in advance for your input!
A fine selection.
Originally Posted by whataboutbob View Post
8) 17x9 RPF1 15.9lbs 255/40 RS-3 26lbs 41.9lbs
I'm going to dropping the car on RCE 20mm drop springs with a higher spring rate (OEM is 153lbs/in front and 131lbs/in rear, vs 250lbs/in all around) and adding new Whiteline front 20mm and rear 16mm adjustable sway bars (OEM is 18mm front and 14mm rear) with the adjustable end links. I'll also be running the Whiteline COMC tophats, front lower camber bolts, and new rear upper arm bushing with camber adjustment.
Nice setup.
I'm trying to decide if a wider wheel and tire is worth the additional weight and what, if any, change in the steering response will be present.
Yes, in my professional opinion it is worth it.
I'm also trying to decide if I should run staggered tire sizes as I think a wider rear tire might reduce the tail-happieness of the rear end.
Your call. Personal preference there.
ill86 is offline   Reply With Quote
Old 12-26-2012, 12:33 PM   #719
ill86
ill86's Avatar
Drives: iG FR-S
12mm (+42 vs +30) won't make or break it. I agree +30 is playing it more safe. Depends on how aggressive the owner wants.
Old 12-26-2012, 02:37 PM   #720
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
+42 is safer and he wont need to stretch tires, with offset +30 means it will stick out more than +42 by 12 mm.
Old 12-26-2012, 02:42 PM   #721
ill86
ill86's Avatar
Drives: iG FR-S
+42 is safer and you wont need to stretch tires, with offset +30 means it will stick out more than +42 by 12 mm.
Offset has nothing to do with stretching tires!. Please refrain from giving advice if you aren't sure how things operate.
I am aware of how +30 will stick out more, I've been providing professional advice throughout this thread.. Go back and take a look... Lol.. It is a personal preference and not right or wrong. Do you know how much 12mm is? It is less than a half inch.
Old 12-26-2012, 03:16 PM   #722
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Never said its wrong, but not everyone wants to do this setup.
This is how rota grid 17x9.0 +30 looks.
Old 12-26-2012, 03:25 PM   #723
ill86
ill86's Avatar
Drives: iG FR-S
Yep...
You think 12mm is going to make it tuck inside the guard and take out three + degrees of rear negative camber?
Old 12-26-2012, 03:46 PM   #724
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Yes 12mm will make it tuck better under the fenders.
Old 12-26-2012, 04:08 PM   #725
ill86
ill86's Avatar
Drives: iG FR-S
Lol. 12 millimeters is not going to make it that much better. You are completely missing the point.
It still needs an alignment.
It will still have three+ degrees of negative camber.
Take out a ruler and measure 12mm. 12mm isn't going to put it under the guard. It is aggressive at 30 or 42 because it's a 9" wide wheel!
But hey, at least you got over the tire stretching comment..
Old 12-26-2012, 04:24 PM   #726
adprokid
adprokid's Avatar
Drives: ZN6 / GDB-G
Grid 17x9.0 +42 on stock suspension, it allowed for a wider 245/40 tires, less stretch and tucks better as you can see.
Old 12-26-2012, 04:41 PM   #727
ill86
ill86's Avatar
Drives: iG FR-S
You should research and study more. Seriously.
The offset didn't allow for a wider tire!! The alignment did. Offset has very little to do with tire selection. The lower offset wheel moves it further away from the suspension components.
Alignment is what make it "tuck". Not 12mm of offset difference.
Old 12-26-2012, 04:44 PM   #728
ill86
ill86's Avatar
Drives: iG FR-S
The picture of the +42 is on stock suspension. Hence why there is not increased negative camber from lowering it... That is why it is tucked.. Not because of the +42. 12mm of offset is not going to negate 3+ degrees of negative camber because of the lowering spring causing the misalignment!
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
