#7113 |
EX-86 Supercharged God
Drives: '16 Series.HyperBlue BRZ
I just replaced the pump yesterday. It was pushing fluid too. I had to refill the bottle 3 times... And now the lines are just empty.. No coolant anywhere lol. I plan on not driving the car tomorrow to work and Saturday I'm heading 3 minutes down the roads to a buddies to try and get it looked at.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ |
#7114 |
Drives: 2013 Scion FRS
Good luck man. Sounds like a leaky line
ScreamingElectron - SnakeShit |
| The Following User Says Thank You to riboyster For This Useful Post: | Rifle (04-29-2016) |
#7115 |
But there's no coolant anywhere... :|.. it's like it's evaporating..
295WHP/220TQ |
#7116 |
Maybe it is? Cracked intercooler?
#7117 |
295WHP/220TQ |
| The Following User Says Thank You to Rifle For This Useful Post: | riboyster (04-29-2016) |
#7118 | |
Drives: Toyota 86 with supercharger
So having it open "more" and "sooner" would have no impact to the torque at lower RPMs? I figured it was just designed the way it was to stop fuel wastage when idling. I pretty much cannot feel much if any difference the supercharger makes under 3000 RPM over stock and figured it may have an impact there if it was more open. Sorry I am not so educated on this topic. |
#7119 |
If you had it more open, you would lose vacuum and brake booster, as well as throw the entire air fuel ratio off. If you mash the throttle, it will open all the way.
If it's open on idle, your motor will have unlimited access to air, giving you too much oxygen and therefore not a good combustion ratio. The ecu would compensate by putting even more fuel into the mixture to keep the motor running, and eventually you'd have a runaway motor. Throttlebodies are very important. There's never any need to apologise bud, I'm sure most of us are just glad you asked here before doing something.
#7120 |
That having been said, don't mash the throttle under 3k with stock internals. Usually at low rpm under high load, the forces on the pistons are so high that they have the chance of bending the rods or even forcing the rods through the heads.
Always play it safe. If you're gonna go hard at low rpm, do it on first gear so the system has as little resistance as possible. If you do it right, each up shift should have you at around 3.5k rpm starting - good to go as far as Wide Open Throttle is concerned.
#7121 | |
295WHP/220TQ |
#7122 | |
That's where you'll find me. Just cruising around at 5k in second waiting for someone to race me hahaha
| The Following User Says Thank You to riboyster For This Useful Post: | Dream20b (04-29-2016) |
#7123 | |
Drives: Subaru BRZ with Delicious Innovate
#7124 |
Drives: FRS innovate supercharged
335 on stock motor
I have the 210 innovate stage 2 kit, but i am looking to upgrade to the 335, Has anyone done this on stock internals reliably?
Also if anyone wants to sell their 335 hmu! |
#7125 | |
295WHP/220TQ |
| The Following 2 Users Say Thank You to Rifle For This Useful Post: | Jeremiahlee34 (04-30-2016), riboyster (04-30-2016) |
#7126 |
Drives: 2014
80mm pulley and e85 will get you a long ways look at moto Mike. of course you will need injectors, pump, and clutch. Don't go hard under 3k rpm
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 11:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 07:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 01:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-18-2012 12:38 AM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 06:14 PM |
