Old 04-29-2016, 01:35 AM   #7113
Rifle
EX-86 Supercharged God
Rifle's Avatar
Drives: '16 Series.HyperBlue BRZ
Originally Posted by riboyster View Post
Is there any way you can bypass the pump for now? If you could flood the system before getting the pump on, then flood the pump, it'll have something to push and that'll help get the rest of the air out
I just replaced the pump yesterday. It was pushing fluid too. I had to refill the bottle 3 times... And now the lines are just empty.. No coolant anywhere lol. I plan on not driving the car tomorrow to work and Saturday I'm heading 3 minutes down the roads to a buddies to try and get it looked at.
Sprintex 210 Supercharged HyperBlue BRZ "HI MOM"
295WHP/220TQ
Rifle is offline   Reply With Quote
Old 04-29-2016, 01:44 AM   #7114
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Good luck man. Sounds like a leaky line
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following User Says Thank You to riboyster For This Useful Post:
Rifle (04-29-2016)
Old 04-29-2016, 01:49 AM   #7115
Rifle
Rifle's Avatar
But there's no coolant anywhere... :|.. it's like it's evaporating..
295WHP/220TQ
Old 04-29-2016, 01:50 AM   #7116
riboyster
riboyster's Avatar
Maybe it is? Cracked intercooler?
Old 04-29-2016, 01:56 AM   #7117
Rifle
Rifle's Avatar
I'll find out Saturday.
295WHP/220TQ
The Following User Says Thank You to Rifle For This Useful Post:
riboyster (04-29-2016)
Old 04-29-2016, 03:06 AM   #7118
SlowShifter
Drives: Toyota 86 with supercharger
Originally Posted by Rifle View Post
what valve? On the throttle body..? you mean which controls the amount of air you let in relative to your pedal..?
Is it the pedal or the RPMs? Even though they are somewhat linked I guess.
So having it open "more" and "sooner" would have no impact to the torque at lower RPMs? I figured it was just designed the way it was to stop fuel wastage when idling. I pretty much cannot feel much if any difference the supercharger makes under 3000 RPM over stock and figured it may have an impact there if it was more open.
Sorry I am not so educated on this topic.
SlowShifter is offline   Reply With Quote
Old 04-29-2016, 03:15 AM   #7119
riboyster
riboyster's Avatar
If you had it more open, you would lose vacuum and brake booster, as well as throw the entire air fuel ratio off. If you mash the throttle, it will open all the way.
If it's open on idle, your motor will have unlimited access to air, giving you too much oxygen and therefore not a good combustion ratio. The ecu would compensate by putting even more fuel into the mixture to keep the motor running, and eventually you'd have a runaway motor. Throttlebodies are very important.
There's never any need to apologise bud, I'm sure most of us are just glad you asked here before doing something.
Old 04-29-2016, 03:19 AM   #7120
riboyster
riboyster's Avatar
That having been said, don't mash the throttle under 3k with stock internals. Usually at low rpm under high load, the forces on the pistons are so high that they have the chance of bending the rods or even forcing the rods through the heads.
Always play it safe. If you're gonna go hard at low rpm, do it on first gear so the system has as little resistance as possible. If you do it right, each up shift should have you at around 3.5k rpm starting - good to go as far as Wide Open Throttle is concerned.
Old 04-29-2016, 03:25 AM   #7121
Rifle
Rifle's Avatar
Also don't bang first gear like me unless you wanna replace axles every 1k.
295WHP/220TQ
Old 04-29-2016, 03:31 AM   #7122
riboyster
riboyster's Avatar
Admittedly it's very tempting. But that's what 2nd is for.
That's where you'll find me. Just cruising around at 5k in second waiting for someone to race me hahaha
Dream20b (04-29-2016)
Old 04-29-2016, 06:22 PM   #7123
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
This is exactly how dissel engines work. They have no throttle body and change fuel to add power. The combustion is always fuel limited and runs as lean as possible. They also generate a lot of heat.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 04-29-2016, 09:03 PM   #7124
Jeremiahlee34
Drives: FRS innovate supercharged
335 on stock motor
I have the 210 innovate stage 2 kit, but i am looking to upgrade to the 335, Has anyone done this on stock internals reliably?
Also if anyone wants to sell their 335 hmu!
Jeremiahlee34 is offline   Reply With Quote
Old 04-29-2016, 09:42 PM   #7125
Rifle
Rifle's Avatar
You'll need an oversided pulley. You can push maybe 2 more psi than the 210 on stock internals (safely), and that's about 14psi.. You can always try turning it up until it pops, I guess. Or just build the motor before you do anything, then upgrade. Because even @smudge blew a hole in his block with the 335.. and his car was built. Admittedly, he had a faulty part.. but still. The 335 is a beast!
295WHP/220TQ
The Following 2 Users Say Thank You to Rifle For This Useful Post:
Jeremiahlee34 (04-30-2016), riboyster (04-30-2016)
Old 04-29-2016, 10:22 PM   #7126
walletsr
Drives: 2014
80mm pulley and e85 will get you a long ways look at moto Mike. of course you will need injectors, pump, and clutch. Don't go hard under 3k rpm
walletsr is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
