#57 | |
I would agree with much of this statement. I have heard qualified, people state "the faster you go the more they blow" And, usually you will lose reliability when adding much power (more shop time) for the average driver/enthusiast. Usually when people add 50 Plus percent of power torque something(s) will break. then you change the things that break and something else breaks. Last time in my pursuit of this I broke many parts and my wallet. Some people buy their cars with power like my friend with a SS Camaro or 911 porsches, BMW M3's. They have said things like I am proud I bought this set up. But that is also the fun of it, making something faster, that is kind of the cool thing about this car, we can customize or "paint on a blank canvas" I'm not sure if you considered running maybe 4-5 psi and get a conservative tune.? |
#58 |
Drives: Turbo BRZ Limited 6MT
Hey guys,
After the swap the car threw a P0011 CEL (using the stock ECU out of my 2013 car with the 2015 motor, I assume flashed back to stock). They swapped my ECU with a Motec one out of their racecar to see if there was actually something wrong with my motor or if my ecu had gone bad, and with the Motec one the car worked fine. I went and bought the ECU out of the 2015 totalled car since a new one is much more expensive. I have yet to try it in the car with the 'new' motor. Wondering if anyone has seen this code and knows anything about it, or why my ECU would throw the code but not a motec? Thanks |
#59 | |
Drives: 2013 Asphalt FRS
Very smart idea going back stock until you can build a motor. The sure sign of insanity is doing the same thing over and over and expecting different results..... Albert Einstein
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
#60 | |
Yeah, great idea. I test drove a 370 Z the other day it makes over 300 hp and a lot of torque. They come with a warranty. It was fun. I might be buying one someday. I was going to go forced induction on my FR-S but making power reliably, within warranty and legally wasn't going to work for me as a daily driver. I would just try to take a couple hundred pounds of the Z and I would be a happy daily driver : ) I know it is kind of apples and oranges but both cars are fun. I love my FR-S I just don't trust this thing being built with my engineering. I've done that before... I should of just bought a car built |
#61 | |
It is a hard choice to make, you will have to figure out exactly how much you want and what it takes to get there. If it a 1/4mi time I can help you.
#62 | |
Yeah, thanks for the response! I know it is a hard choice, that is always the catch. Making a "slow" (relatively speaking of course) fast is always tempting. It really is the beauty of modifying a car or hot rodding it. I would love to make this a 50K or 70K toy. But for me with my limited resources and money I would have to just purchase a car built. And still I couldn't afford a 50-70k car. The blank canvas of this car is appealing and a beautiful thing. I like having this motor stock as I trust it in this form!!! I could see myself spending easily 15-25 k more on this car with a highly modified forced induction car if I was to keep a 300hp rwhp FR-S in this form for 5-8 years. I don't know how many items I would break. I drive this car with maximum acceleration almost everday at least for just a moment. With 300 plus rwhp I don't know how long it would last... If I could afford it I would but an extra 20 K in this car for me isn't the best idea for now. |
#63 | |
If anyone wants an update, I towed the car to evasive to have them swap the blown motor with a working stoco one. The car sat there for a few weeks while they were working on other projects and while I had to buy a new motor. I bought a motor out of a 2015 rollover crashed frs with less than 10k miles (mine is a 2013) on it from a local junkyard. I got a good deal on it since some pieces had battery acid on them, but I was assured it's all cosmetic and I got a 6 month warranty. My luck kinda ended there. The motor got delivered on the 8th, they started work on the car about a week later I think, and got the motor in the car a few days after, but then I started having trouble with the ECU. My stock ECU was throwing a P0011 Code, but when they used the Motec ECU out of their racecar (to check if it was a problem with the motor or the ECU) the motor ran perfect. So they told me I needed a new ECU. A new ECU is around 700, so instead I went and bought the ECU out of the same 2015 rollover FRS for 100, and dropped it off at Evasive. They then dropped the car off to the dealer to get the key programmed to the new ECU. Apparently now the new ECU isn't communicating with the instrument cluster, and the car is starting up in limp mode as a result I guess the 2015 ECUs aren't compatible, or maybe it's an FRS vs BRZ deal... who knows...I could keep messing with junkyard ECU's, but I really need to return the rental I've had to get for a month now, so I opted for a new ECU from subaru. Hopefully it will work and I can get my car back... I'm guessing $5500 all together for the motor, new ECU, labor, and programming the keys, if there arent more issues. Not including the rental I had to drive. I wonder how much more money would it have been to get Full Blown's built shortblock instead... |
#64 |
Drives: UK GT86
AFAIK there are differences in the 2015 hardware, people who tried to update older ECUs got the communication DTCs. I doubt a new ECU will fix this, you will likely need a new dash cluster. Quite why a newer engine won't run on an older ECU is past me, resolving that would be easier than a 15 ECU in an older car. A P0011 code is to do with the cam position/sensor are you certain that isn't something that can be sorted, perhaps change sensors over from the old block?
.: Stealth 86 :.
#65 | |
It could be pinned different. My suggestion would be use the old harness old ecu and reflash. You might have to use a lot of the old sensors like the throttle body map, Just try to go back as "stock" as you can. The ecu shouldn't know what year the motor is and it should run just fine if everything is back the way it was. It sounds like the ecu and the can bus aren't communicating fully. Was the 2015 push button start and yours a key little things like that can cause havoc in a system. good luck brother
#66 | |
They said the motor has no issues with their Motec ecu so they think the P0011 code is due to a faulty ECU, and they think that might be why the motor went in the first place. They even called subaru asking if they would warranty just the ECU, and Subaru said no because it was flashed. I'm sure they tried troubleshooting it before testing the ECU but idk if they tried to swap the sensors. They seem convinced that the ECU is faulty.. They also said a 2013 ECU and 2013 tune will work fine for the 2015 motor. |
#67 | |
Like I said they don't think this is a physical problem, they think the ECU is bad. The 2015 ECU didn't work for some reason, so I'm going to have to return it. They think a new 2013 one will solve the issue. Edit:sorry for the double post |
#68 | |
Did you have that code before the engine blew or after the swap. Either way I don't think that was the reason for your motor giving up the ghost. when things fail like that (cam sensor) they go back to a factory default that is designed to save a motor not finish it off. If you bypassed the factory ecu and it had no codes its in the electrical system has to be. I hate seeing you having to dump that kind of cash on a ecu..
#69 | |
Benched 86lb
Drives: Ultramarine FR-S
Reducing DCR to have a sane SCR in a boosted application seems wise, unless you want to take the above approach and be miles away from an ideal setup. |
#70 | |
| Help! New Car Engine Blew Up. What are my rights? | Obsidiank | Scion FR-S / Toyota 86 GT86 General Forum | 53 | 12-11-2014 11:43 AM |
| so my motor blew up on dyno today jdl kit gtx3071 | kingkai23 | Forced Induction | 62 | 07-24-2014 09:09 PM |
| So my engine blew up.... | alliedcam1 | Engine, Exhaust, Transmission | 57 | 12-28-2013 02:50 PM |
| What would You do if your motor blew? | TyperRspec789 | Forced Induction | 58 | 07-02-2013 10:54 PM |
| Coverage of Subaru BRZ Debut at Re-Mix Night at Tokyo Night Club and Music Video | mockngbrd | BRZ First-Gen (2012+) — General Topics | 36 | 01-04-2012 06:15 PM |
