Old 02-08-2016, 08:45 PM   #57
strat61caster
strat61caster's Avatar
Originally Posted by zeal86 View Post
Hope this helps...
Only a bit, was more interested in the spring/top hat cup interface, you've got pics of the top of the mounts, but not the bottom. It seems like the spring is located via a 60/65mm ID lip but I don't want to make a $300 gamble on that.
Totally see what happened to you though, the specs for damper shaft diameter are not published on any site that sells the Beatrush that I've seen (or I'm blind), seems like they're meant for OE or OE replacements and many damper manufacturers use a standard size across their lineup that may not match with OE.
Which agrees with your measurements, that spacer/bushing should fit an M10 thread which includes OE, Ohlins, Bilstein, KW, Koni, etc. but not brands like Fortune Auto, MCS, and RSR (which you're measuring just under 12 so I assume it's M12 like the others).
And if that bushing is threaded or there's a special nut that comes with it the thread pitch could also reduce the compatibility by a lot.
ineedyourdiddly
Old 02-26-2016, 02:53 PM   #58
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Beatrush Suspension Products (Unboxing, Install, & Review)
Beatrush Transmission Mount Bushing Spacer installation pics
__________________________________________
projekt zeal86 build
Hi just wonder how does the transmission spacer feel? And noise level?
I know Custco makes a metal spacer, but it seems beatrush one is much better for daily.
Mind sharing your thought? Thank you.
Old 02-26-2016, 04:57 PM   #59
zeal86
zeal86's Avatar
Drives:
So sorry I can't help you with your decision at this time... Since I have a daily driver and I have been waiting on some parts...I left my 86 on jacks after the install.
I'll be installing my HKS v3 supercharger and other performance mods soon as well as a couple more non-suspension Beatrush parts.
I'll post my experience with the transmission mount bushing spacer once I get her back on the road. However, I won't be able to give a naturally aspirated opinion about the part.
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
Old 04-14-2016, 12:05 AM   #60
zeal86
zeal86's Avatar
Drives:
It's been a while since I last posted in this thread... fortunately I feel that my 86 will be back on the road soon. Many of my Beatrush suspension upgrades will be subjected to more power so there should be a feeling out period perhaps some tweaking.
For now, check out this non-suspension Beatrush goodie... Pictured below is the Beatrush air intake duct. Because I am in the middle of my HKS supercharger pro kit v3 install, I do not know if I will be able to use this duct without modification... I will know soon though. Also, there could possibly be a fitment issue with my Beatrush front beam brace and my HKS intercooler... I'll know the answer to that soon as well.
This thing is beautiful!
The Following User Says Thank You to zeal86 For This Useful Post:
Koj (09-06-2016)
Old 07-02-2016, 05:20 PM   #61
zeal86
zeal86's Avatar
Drives:
The Following 4 Users Say Thank You to zeal86 For This Useful Post:
Irace86 (07-03-2016), Kami Speed (07-05-2016), Koj (09-06-2016), new2subaru (07-05-2016)
Old 07-05-2016, 11:20 AM   #62
Kami Speed
Kami Speed's Avatar
Drives: Scion FR-S
Send a message via AIM to Kami Speed
Great pic man! Love the listed parts in the background. Car has come out great!!
Kami Speed is offline   Reply With Quote
The Following User Says Thank You to Kami Speed For This Useful Post:
zeal86 (07-05-2016)
Old 07-05-2016, 02:08 PM   #63
zeal86
zeal86's Avatar
Drives:
The 86 has been running great... I will start opening her up soon... I got to test my suspension by accident last week. lol I had to avoid some debris in the road... My Beatrush suspension had me feeling like I was on rails... so solid, I felt no chassis roll! Awesome!
The Following 2 Users Say Thank You to zeal86 For This Useful Post:
Old 09-26-2016, 03:27 PM   #64
Gin Ryuu
Drives: 2015 BRZ Limited ISM
A big thank you to zeal86 for the detailed instructions. I installed the Beatrush rear member support rod and the front member support bar along with a Beatrush underpanel and Cusco front lower arm bar braces.
This post was a huge help in the install as well as my decision to go ahead and purchase the Beatrush products. They do improve the ride as well as go a long way to tighten up things as well. Very happy with all these products I put in. Thanks again for all the detail.
Gin Ryuu is offline   Reply With Quote
The Following 2 Users Say Thank You to Gin Ryuu For This Useful Post:
Kami Speed (09-26-2016), zeal86 (09-26-2016)
Old 11-11-2016, 07:04 PM   #65
zeal86
zeal86's Avatar
Drives:
I love the finish of all my Beatrush parts... In fact, I modified my build's theme to incorporate the Beatrush gold instead of painting or powder coating over the color.
Since I will be installing a harness bar from Essex Parts Services, I wanted to paint it Beatrush gold to go along with my theme and create some contrast in my interior.
For those interested, the output color code my friend's spectrometer spit out is shown in the accompanying image.
Instagram @zeal.eightsix
Old 07-14-2017, 12:35 PM   #66
JT.86
Drives: Scion FRS 2016
Hey @zeal86,
Does the rear bumper brace protrude less than the stock brace?
___________________
2016 MT|Varis Arising II body kit with carbon add-ons|Aimgain x Stancenation Spoiler|Valenti Japan Jewel headlights|Valenti 4th Brakelight|ST-X coilovers|SPC LCA|18x10 TE37RT|Hankook Ventus RS3 265/35|Work Chrome blue lugnuts|Corsa catback|JDM TOM's red taillights|JDM armrest|TRD carbon Fender garnish|Beatrush Rear bumper brace|Cusco front strut
JT.86 is offline   Reply With Quote
Old 07-14-2017, 12:59 PM   #67
zeal86
zeal86's Avatar
Drives:
Originally Posted by JT.86 View Post
Hey @zeal86,
I can't remember for sure but I'm leaning towards that it does protrude less.
JT.86 (07-14-2017)
Ohlins Road & Track for FRS/BRZ suspension install/review thread mav1178 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 628 01-30-2024 06:16 AM
OEM armrest unboxing/review supramkivtt2jz Cosmetic Modification (Interior/Exterior/Lighting) 508 11-22-2017 07:27 AM
The Ultimate LED Switchbacks VLED V3 Tritons Unboxing Install Review & Coupon Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 12 01-10-2014 06:59 PM
Sonar (Spyder) Tail Light Unboxing and Review Yruyur Cosmetic Modification (Interior/Exterior/Lighting) 28 10-20-2013 04:42 PM
DIY Unboxing and Install of JDM CLEAR SIDE MARKER LENS! MrGamer DIY (Do-It-Yourself) Guides 11 07-07-2013 11:19 PM
