| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
#57 | |
Be Kind
Drives: 2020 86
#58 | |
Drives: 2013 BRZ Sport-Tech
I am however curious about your claim that because this is a boxer motor there's no need to do any dampening. horizontally opposed or not, there's always going to be vibrations and such. If there was no need to dampen them then the OEM would have saved themselves the extra material and cost of making the harmonic damper. That said it may not reduce the engines life by a noticeable amount for most people. |
| The Following 2 Users Say Thank You to CrowsFeast For This Useful Post: | Baldeagle (10-01-2020), LimitedSlip (08-20-2020) |
#59 | |
Drives: 22 BRZ limited
I have read on this very forum that the OEM crank pulley is not a harmonic damper. |
| The Following 2 Users Say Thank You to dragoontwo For This Useful Post: | Baldeagle (10-01-2020), daiheadjai (08-20-2020) |
#60 | |
Drives: 2003 S2000, 2008 Fit
| The Following User Says Thank You to daiheadjai For This Useful Post: | Baldeagle (10-01-2020) |
#61 |
#62 | |
I can't really answer that but here goes anyways. The pulley is a 3 pc design with 2 metal pieces connected my a thin layer of rubber. It is probably as light as 2 mass produced cast metal pieces and a strip of rubber can be. It is probably much cheaper to produce than machined aluminum pulleys are. |
#63 |
LWFW made a huge improvement for throttle response. Slight blip is all it takes on downshifts.
I'm also on an E85 tune and whenever I go back to stock tune, I notice the throttle response is not great (yes, after the adjustment period). Love the throttle response on the car now!
2022 BRZ Build 2013 FR-S Build |
#64 |
Drives: Red 2019 Subaru BRZ
If you are seriously using the car, you will be over 4500 RPM at the least. You may find the harder you drive it the better it feels.
In drive to the store mode, it has many peccadilloes.
#65 | |
#66 | |
In the quantities that they are done, it may still be cheaper than machining a bunch of 1 pc pullies. I agree that it is likely just a slight dampener, and not a balancer. |
#67 | |
I was actually speaking from my experience when I worked at continental on valves for evap systems (making million of parts) about overmolding being 'expensive'. |
#68 | |
Drives: VW GLI 6MT
However it seems that at high rpm, an H4’s crankshaft incurs flex and that flex causes a vibration. The OEM two-piece pulley with the rubber ring is designed to absorb some of that vibration. If the rubber in the pulley were not present, the crankshaft’s bearings would absorb more of those flex-vibrations. Over time, that could increase wear on the crank bearings and reduce the engine’s lifespan. To what degree does this have an impact? I am clueless. But it seems there is a purpose for that rubber ring. |
| The Following User Says Thank You to Baldeagle For This Useful Post: | Ultramaroon (10-03-2020) |
#69 | |
#70 | |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
| Throttle Response | CamryDS | Northern California | 27 | 03-31-2015 04:35 AM |
| poor throttle response | Djen | Engine, Exhaust, Transmission | 21 | 06-14-2014 02:22 AM |
| poor throttle response | Djen | Electronics | Audio | NAV | Infotainment | 5 | 06-18-2013 08:31 PM |
| Does the throttle response improve? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 12-01-2012 02:06 PM |
| How's the throttle response? | SFTiofoso | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-14-2012 12:50 PM |
