Old 11-18-2014, 10:45 PM   #57
shif7i7down
Erected Member
Drives: frs
Originally Posted by Mike&Ike View Post
You are supposed to replace the spring that is in the BOV with the extra one that it came with.
What! I didn't see that in the instruction.
shif7i7down is offline   Reply With Quote
Old 11-18-2014, 10:46 PM   #58
shif7i7down
Erected Member
Drives: frs
Originally Posted by Boofneenee View Post
Does that sound occur at that rpm in every gear?
The sound occur at 6.5krpm in 4th. 5.5krpm in 5th and 3.5krpm in 6th gear
Old 11-18-2014, 10:47 PM   #59
shif7i7down
Erected Member
Drives: frs
Originally Posted by Fizz View Post
Umm....you didn't just place both springs together in the bov did you (if that's even physically possible lol)?
I don't think that's physically possible. O_o
One thing for sure though, it does sound like it's coming front the brake booster
Old 11-19-2014, 07:37 AM   #60
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
Drives: Toyota Scion FRS
Maybe it is just one of the plastic shrouds catching air? The fact its only happening at higher gears means your going fast enough for the wind to create enough force that it may just be the issue. If it was an engine issue wouldnt it happen in every gear?
Of course you could really test this if you found some way to blast through all six gears while the rear wheels were proper off the ground
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels
Boofneenee is offline   Reply With Quote
Old 11-19-2014, 08:25 AM   #61
shif7i7down
Erected Member
Drives: frs
I'm most likely gonna take it to a local shop and have them strap it on a dyno so that i can test the plastic piece catching wind vs mechanical error theory and most likely a power pull. 2 birds with 1 stone. Maybe even a custom tune.
Anyone know of a good tuner in Wisconsin that uses OFT?
But first. I think I'm gonna change the spring in the bov just to rule that out before spending money at a shop
The Following User Says Thank You to shif7i7down For This Useful Post:
Luckrider (11-19-2014)
Old 11-19-2014, 08:32 AM   #62
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
You don't need one that tunes via oft, just one that tunes using RomRaider. They would have ECUFlash and can tune quicker, and then give you the file to use with your OFT.
Luckrider is offline   Reply With Quote
Old 11-19-2014, 08:36 AM   #63
shif7i7down
Erected Member
Drives: frs
Great, also... was there ever a tuner list compiled by region? I thought i saw something like that awhile back.
Old 11-19-2014, 09:04 AM   #64
Mike&Ike
Drives: Brz
You can contact Chris at SBD to verify, but I did read that in the forum post in the marketplace.
Mike&Ike is offline   Reply With Quote
The Following User Says Thank You to Mike&Ike For This Useful Post:
shif7i7down (11-19-2014)
Old 11-19-2014, 10:31 AM   #65
shif7i7down
Erected Member
Drives: frs
Another thing, was tapping into the brake booster for vacuum a good idea? Where are you guys connecting your bov to?
Cause honestly it really does sound like the sound is coming from the booster
Old 11-19-2014, 11:18 AM   #66
shif7i7down
Erected Member
Drives: frs
Can you take a picture of where exactly you tapped into the brake booster line for the vacuum/boost source running to your BOV? Try removing and plugging that line to the BOV and drive the car to see if it makes any difference.
So plug the line coming from the brake booster and leave the bov without a vacuum line? Using only the spring in the bov to test if there's any noise still?
Old 11-19-2014, 02:43 PM   #67
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Yep. The BOV should stay closed and never open under this situation, so don't go crazy boosting it, but see if you get the same sounds.
Old 11-19-2014, 08:06 PM   #68
shif7i7down
Erected Member
Drives: frs
Okay, so i disassembled the bov and removed the yellow spring, then installed the plain spring and took the car out for a drive, still had the same noise.
Then i removed cheap hose i used and bought a 1/4" fuel line hose that is rated for 250psi and installed it, still had the same noise.
Then i final got under the car to check the plastic. It all looked flushed, but there were two bolts missing so i tighten the plastic #4 down in a previous post earlier and noise is gone.
Moral of the story, I'm stupid.
Old 11-19-2014, 08:24 PM   #69
Boofneenee
Go-Kart Enthusiast
Boofneenee's Avatar
happy to hear it was not something engine harming
FRS
The Following User Says Thank You to Boofneenee For This Useful Post:
Old 11-19-2014, 08:25 PM   #70
xwd
Hahah too bad I didn't see this thread until today, I would have told you it was exactly that from the beginning. You would be surprised how far the plastic shrouding will extend when it gets air under it. I lost one of the bolts long ago and the first time it started scraping like that it scared the crap out of me, it's so damn loud in the car. If any mechanical components like the turbo, engine, etc. was making that noise it would have grenaded in short order.
FBM Stage 1 Base Turbo Kit Starting @ $3995 Garrett or PTE Turbo Choices FullBlown Forced Induction 588 12-02-2015 02:41 PM
Toyota Trademarks: D4-S Turbo, More turbo, 9 Scion Names Veloist Off-Topic Lounge [WARNING: NO POLITICS] 9 08-27-2014 11:29 PM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 12:28 PM
