Old 04-24-2013, 03:19 PM   #57
captain_jack
captain_jack's Avatar
Originally Posted by CBR600RR View Post
Rear seat removal?
Which portion? The bottom or all of it? The bottom is easy, if you watch the system 400 install video it shows you how to remove the lower portion.
Sent from my SPH-L900 using Tapatalk 2
Old 05-23-2013, 02:11 AM   #58
mit_peid
Boosted Noob
mit_peid's Avatar
Drives: '13 FRS MT KW SC, '05 4Runner 4WD
How about a DIY for bottom rear seat re-installation? They were really easy coming off, but now I'm not able to get them back in. There must be a trick I'm not getting.
mit_peid is offline   Reply With Quote
Old 05-26-2013, 03:57 PM   #59
BatStig
Some say.....
BatStig's Avatar
Drives: 2007 Subaru Impreza 2.5i
Cheap GoPro tow hook mount:
http://www.ft86club.com/forums/showthread.php?t=35635
BatStig is offline   Reply With Quote
Old 08-20-2013, 06:27 PM   #60
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
DIYers if you would like your Write Ups on the front page of the Directory, please PM your details so i can add it.
Thank You!
-Josh
WingsofWar is offline   Reply With Quote
Old 08-22-2013, 05:35 PM   #61
mit_peid
Boosted Noob
mit_peid's Avatar
Hey, I think some forum members might find my DIY on cutting OEM struts and installing Koni yellow inserts to be useful: http://www.ft86club.com/forums/showt...i+installation
Old 08-22-2013, 06:59 PM   #62
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
It is the bible for doing it correctly!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline   Reply With Quote
Old 09-12-2013, 12:36 PM   #63
JR007
JR007's Avatar
Drives: Ultramarine FR-S
many thanks for sharing!
JR007 is offline   Reply With Quote
Old 12-21-2013, 02:34 PM   #64
nalc
Drives: 13 BRZ Limited 6MT GBS
Could you add my two DIY articles to the first post (if they're deemed worthy)
How to make physical switches for your BRZ HU
How to take apart your whole interior
nalc is offline   Reply With Quote
Old 02-14-2014, 11:51 AM   #65
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
@DarrenDriven @WingsofWar
STi strut bar install
http://www.ft86club.com/forums/showthread.php?p=1528401
Old 04-19-2014, 10:23 PM   #66
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Needs added for quick find:
Mod/Interior How to replace scion airbag emblem with toyota emblem.
http://www.ft86club.com/forums/showt...=airbag+emblem
Old 05-02-2014, 01:07 PM   #67
blackfireball5
blackfireball5's Avatar
Drives: Scion FRS Firestorm
DIY: Making Air Vents Out Of The OEM Fog Light Bezels
For use with an oil cooler in front passenger wheel well / foglight area.
http://www.ft86club.com/forums/showthread.php?t=63231
blackfireball5 is offline   Reply With Quote
Old 05-29-2014, 10:08 AM   #68
ML
ML's Avatar
Drives: 13 White MT FR-S
What happened? Hasn't been updated since January.
Old 09-03-2014, 04:33 PM   #69
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
Clutch replacement that a member made. Please add to directory
http://www.ft86club.com/forums/showthread.php?t=25054
Ryaquinn is offline   Reply With Quote
Old 01-11-2015, 02:42 PM   #70
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
homemade windshield washer fluid tank RH relocation
http://www.ft86club.com/forums/showthread.php?p=1669660
brz diy, fr-s diy, frs diy, scion fr-s diy, scion frs diy, subaru brz diy
FR-S / BRZ Wheel Directory, Gallery and Fitment Guide Chart DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 632 12-22-2023 08:49 AM
NW Shop Directory: Tuners, Tinters & Audio DarrenDriven Northwest 129 10-14-2022 02:29 AM
