Old 08-05-2014, 03:18 PM   #57
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
just made the changes and will flash before i drive home from work, hopefully will get enough driving in to datalog...
DAN_BRZ is offline   Reply With Quote
Old 08-05-2014, 05:55 PM   #58
Silver Ignition
APEXHNTR
Silver Ignition's Avatar
Drives: 10 Series FR-S #1867
okay so here's a pull with the 91 octane tune and still the same tank of 93 as all my previous logs
http://www.datazap.me/u/silver-ignit...g=0&data=1-2-5
I think it looks pretty good, what do you guys think?
2013 Sc10n FR-S 10 Series
#1867 of 2500
in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer]
Silver Ignition is offline   Reply With Quote
Old 08-05-2014, 08:35 PM   #59
Walla Walla
Hicas Thread Basher
Drives: Subaru BRZ 13, Hyundai Genesis 15
already a lot better! (i think!)
but maybe between 6000 and 7000 you could remove a degree of advance, since your flkc is a between -1 and around -2 ?
Walla Walla is offline   Reply With Quote
Old 08-06-2014, 09:02 AM   #60
steve99
Agree with @Walla Walla needs a bit more pulled 6000-7000 maybe -1,
seems strange to have to remove so much on 93 USA, maybe you got a bad batch, happend to a mate of mine a couple of weeks ago, tune was fine then filled up at normal supplier outlet (98RON OZ fuel)) and soon after knocks like crazy IAM about 0.6 where its usually solid at 1. Suspect station had filled tank with lower octane fuel (he checked his receipt and was correct octane), after he filled up again a couple of days later at different outlet all ok same fuel.
http://www.datazap.me/u/silver-ignit...7-12&solo=6-12
Old 08-06-2014, 10:54 AM   #61
Silver Ignition
APEXHNTR
So between 6000-7000 I want to subtract a degree of advance from the Ignition Timing - Advance folder in the Base Timing B map, correct?
#1867 of 2500
Old 08-06-2014, 12:36 PM   #62
steve99
Yes correct,
unless you want to wait and try different fuel or octane booster ?
its strange 93 octane should be better than that
Old 08-06-2014, 06:32 PM   #63
Hagbard
Hagbard's Avatar
I've had the same spot, running 94 octane in canada, now i don't have my BPB installed yet so i don't if that's anything but our gas has a bad reputation.
I might just switch to the 91 rom just cause our gas sucks and i cant get 94 everywhere i might end up.
Running A01C 93octage Stage 2 UEL
This log has 4 3rd gear pulls each had the same area of knock,
http://www.datazap.me/u/hagbard/aug3...om=15553-16183
http://www.datazap.me/u/hagbard/aug3...om=14039-14594
http://www.datazap.me/u/hagbard/aug3...om=12709-12874
http://www.datazap.me/u/hagbard/aug3...om=11037-11289
Pulled some timing and got this now.
http://www.datazap.me/u/hagbard/aug-...zoom=5427-5808
http://www.datazap.me/u/hagbard/aug-...zoom=6997-7287
just the od -.65 in the lower rpm
Hagbard is offline   Reply With Quote
Old 08-06-2014, 06:49 PM   #64
Silver Ignition
APEXHNTR
Yes correct,
http://datazap.me/u/silver-ignition/...=0&data=1-4-12
there's a lot of knock correction happening now...
#1867 of 2500
Old 08-06-2014, 08:42 PM   #65
Walla Walla
Hicas Thread Basher
how much km/miles since you flashed?
there is a lot, but it seems like small correction, as @steve99 said, under -.07 you should not really worry about it. The correction is bigger than the knock itself as i understand, (to be sure to "stop" the knocking situation, that it wont knock multiple times)
i'm doing a long term datalog to see the evolution of those knock, and also to spot tendency of know (where and how strong) and it's seems that, with time, your short term and long term fuel trim seems to developp, and produce less knock. i'll post my results in a few days. maybe it will help to build some kind of guideline, of what is normal, and what is not!
Old 08-06-2014, 08:51 PM   #66
Walla Walla
Hicas Thread Basher
it's really better, you've worked at the right spot!
how much timing did you remove?
for the gas, if it's 94 petro can, it really have a bad reputation. it contain ethanol, and it seems to produce more knock. but, there are some debate on this...
Old 08-06-2014, 09:16 PM   #67
steve99
But the negitive amount is less than before, its a bummer to have to remove the timing. That area is where the new tune added timing over the old one 2 or 3 degrees in places. We have same issue here in OZ our fuel just not as good as where shiv is. But we do find that different brands of fuel can effect knock even though it same octane rating and with no ethanol content.
I rearly would try a different brand of fuel then if no luck, pull a bit more at the effected load/rpm points where the knock is try just over half of what the ecu is removing. The fuel trim and knock learning is pretty quick usually minutes unless you have big fuel trims which you dont.
Old 08-06-2014, 09:59 PM   #68
Silver Ignition
APEXHNTR
this was shortly after the adjustments and re-flash…maybe more miles on the flash will smooth it over a bit? I'll drive to work tomorrow and do a pull on the way home to see
#1867 of 2500
Old 08-06-2014, 10:03 PM   #69
Silver Ignition
APEXHNTR
I'm on a new tank now…that last tank was Shell V-Power 93 which I understand is a favorite among sports car tuners. This tank is from Valero, 93 octane. Still on the 91 tune with a degree pulled from the 1.10 and 1.20 load columns between 6000 and 6800
I'll put a few more miles on it and try another log. Wish the almighty @Shiv@Openflash would chime in and tell me if I'm on the right track...
#1867 of 2500
Old 08-06-2014, 10:06 PM   #70
Walla Walla
Hicas Thread Basher
i don't know, but from what i've logged, 2 days after flash (yesterday), on a 20 min drive (home to work, 8 km highway, 9 km downtown with light traffic) i had 13 knock reccorded.
today, same drive, 4 knock issue.... so it seems that it could get better with time... but still, not a lot of data to back this up!
with @steve99 comment, i'm starting to think I should try this long run log with different gas brand each week, just to see!
Vishnu Tuning's Tales From The Dyno: Crawford Billet Power Blocks Shiv@Openflash Engine, Exhaust, Transmission 129 11-24-2017 07:58 PM
Crawford Billet Power Blocks smbstyle Engine, Exhaust, Transmission 799 01-18-2016 05:01 PM
Crawford Billet power blocks Triumphrider Engine, Exhaust, Transmission 0 08-01-2014 01:39 AM
FS: One set of barely used Crawford Billet Power Blocks Robert@Openflash Engine, Exhaust, Bolt-Ons 1 06-07-2014 04:13 PM
**Crawford Power Block Install Special -- R/T Tuning -- Call Today** R/T Tuning Engine, Exhaust, Bolt-Ons 3 05-21-2014 11:18 AM
